Commit f91a1f35 authored by NICLAUSSE Nicolas's avatar NICLAUSSE Nicolas
fix plugin deps check version. + handle version arg without patch level
parent ef63402e
...@@ -117,6 +117,10 @@ inline bool checkVersion(const QString ref_version, const QString elem_version) ...@@ -117,6 +117,10 @@ inline bool checkVersion(const QString ref_version, const QString elem_version)
if(ve_ref_list.at(1).toInt() < ve_elem_list.at(1).toInt()) if(ve_ref_list.at(1).toInt() < ve_elem_list.at(1).toInt())
return false; return false;
else { else {
// no patch level specified in ref
if (ve_ref_list.size() < 3 || ve_elem_list.size() < 3) {
return true;
//if same minor level, compare patch level //if same minor level, compare patch level
if((ve_ref_list.at(1).toInt() == ve_elem_list.at(1).toInt()) && if((ve_ref_list.at(1).toInt() == ve_elem_list.at(1).toInt()) &&
(ve_ref_list.at(2).toInt() < ve_elem_list.at(2).toInt())) (ve_ref_list.at(2).toInt() < ve_elem_list.at(2).toInt()))
...@@ -87,7 +87,7 @@ template <typename T> bool dtkCorePluginManagerPrivate<T>::check(const QString& ...@@ -87,7 +87,7 @@ template <typename T> bool dtkCorePluginManagerPrivate<T>::check(const QString&
continue; continue;
if (checkVersion(ve_mitem.toString(), dtkCorePluginManagerBase::instance()->version(key).toString())) { if (!checkVersion(dtkCorePluginManagerBase::instance()->version(key).toString(), ve_mitem.toString())) {
dtkWarn() << " Version mismatch:" << na_mitem.toString() << "version" << dtkCorePluginManagerBase::instance()->version(key).toString() << "but" << ve_mitem.toString() << "required for plugin" << path; dtkWarn() << " Version mismatch:" << na_mitem.toString() << "version" << dtkCorePluginManagerBase::instance()->version(key).toString() << "but" << ve_mitem.toString() << "required for plugin" << path;
status = false; status = false;
Supports Markdown
