Commit c5b2e496 authored by NICLAUSSE Nicolas's avatar NICLAUSSE Nicolas
Merge branch 'hotfix/1.6.3'
parents 8beec1e8 8d4f2e7a
# ChangeLog # ChangeLog
## version 1.6.3 - 2018-11-08
- fix for conda and DTK_INSTALL_PREFIX
## version 1.6.2 - 2018-11-08 ## version 1.6.2 - 2018-11-08
- dtkScriptInterpreterPython enables release method (for real). - dtkScriptInterpreterPython enables release method (for real).
## version 1.6.1 - 2018-11-08 ## version 1.6.1 - 2018-11-08
...@@ -24,7 +24,7 @@ project(dtk) ...@@ -24,7 +24,7 @@ project(dtk)
set(dtk_VERSION_MAJOR 1) set(dtk_VERSION_MAJOR 1)
set(dtk_VERSION_MINOR 6) set(dtk_VERSION_MINOR 6)
set(dtk_VERSION_PATCH 2) set(dtk_VERSION_PATCH 3)
set(dtk_VERSION set(dtk_VERSION
${dtk_VERSION_MAJOR}.${dtk_VERSION_MINOR}.${dtk_VERSION_PATCH}) ${dtk_VERSION_MAJOR}.${dtk_VERSION_MINOR}.${dtk_VERSION_PATCH})
...@@ -28,7 +28,7 @@ int main(int argc, char **argv) ...@@ -28,7 +28,7 @@ int main(int argc, char **argv)
dtkDistributedGuiApplication *application = dtkDistributedGuiApplication::create(argc, argv); dtkDistributedGuiApplication *application = dtkDistributedGuiApplication::create(argc, argv);
application->setApplicationName("dtkComposerEvaluator"); application->setApplicationName("dtkComposerEvaluator");
application->setApplicationVersion("1.5.1"); application->setApplicationVersion("1.6.3");
application->setOrganizationName("inria"); application->setOrganizationName("inria");
application->setOrganizationDomain("fr"); application->setOrganizationDomain("fr");
bool no_gui = application->noGui(); bool no_gui = application->noGui();
...@@ -23,7 +23,7 @@ int main(int argc, char **argv) ...@@ -23,7 +23,7 @@ int main(int argc, char **argv)
dtkCoreApplication *application = dtkCoreApplication::create(argc, argv); dtkCoreApplication *application = dtkCoreApplication::create(argc, argv);
application->setApplicationName("dtkDistributedServer"); application->setApplicationName("dtkDistributedServer");
...@@ -114,8 +114,9 @@ namespace dtkComposer ...@@ -114,8 +114,9 @@ namespace dtkComposer
composer_settings.endGroup(); composer_settings.endGroup();
if (realpath.isEmpty()) { if (realpath.isEmpty()) {
QString dtk_prefix = DTK_INSTALL_PREFIX;
realpath = QDir(DTK_INSTALL_PREFIX).filePath("plugins/dtkComposer"); // ugly: remove null characters added by conda
realpath = QDir::cleanPath(dtk_prefix.remove(QChar::Null) + "/plugins/dtkComposer");
dtkDebug() << "no composer plugin path configured, use default:" << realpath ; dtkDebug() << "no composer plugin path configured, use default:" << realpath ;
pluginManager().initialize(realpath); pluginManager().initialize(realpath);
