GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
dtk
dtk
9dfebaa5
9dfebaa5
Julien Wintz
Output error string on plugin load/unload failure.
aad1fd07
2
src/dtkCore/dtkCorePluginFactory_t.h
9dfebaa5
@@ -24,8 +24,9 @@ template <typename T> dtkCorePluginFactory<T>::~dtkCorePluginFactory(void)
#pragma mark -
#pragma mark Type creator registration
// Type creator registration
template
typename
T
void
T
record
const
QString
key
creator
func
template
typename
T
void
T
record
const
QString
key
creator
func
@@ -37,8 +38,9 @@ template <typename T> void dtkCorePluginFactory<T>::record(const QString& key, c
this
creators
insert
key
func
this
creators
insert
key
func
#pragma mark -
#pragma mark Type creator invokation
// Type creator invokation
template
typename
T
T
T
create
const
QString
key
template
typename
T
T
T
create
const
QString
key
@@ -48,8 +50,9 @@ template <typename T> T *dtkCorePluginFactory<T>::create(const QString& key)
return
this
creators
value
key
return
this
creators
value
key
#pragma mark -
#pragma mark Type creator inspection
// Type creator inspection
template
typename
T
QStringList
T
keys
void
template
typename
T
QStringList
T
keys
void
src/dtkCore/dtkCorePluginManager_t.h
9dfebaa5
@@ -87,8 +87,9 @@ template <typename T> dtkCorePluginManager<T>::~dtkCorePluginManager(void)
d
NULL
d
NULL
#pragma mark -
#pragma Manager Management
// Manager Management
template
typename
T
void
T
initialize
const
QString
path
template
typename
T
void
T
initialize
const
QString
path
@@ -107,8 +108,9 @@ template <typename T> void dtkCorePluginManager<T>::uninitialize(void)
this
unload
path
this
unload
path
#pragma mark -
#pragma Plugin Management
// Plugin Management
template
typename
T
void
T
scan
const
QString
path
template
typename
T
void
T
scan
const
QString
path
@@ -142,6 +144,7 @@ template <typename T> void dtkCorePluginManager<T>::load(const QString& path)
T
plugin
qobject_cast
T
loader
instance
T
plugin
qobject_cast
T
loader
instance
if
plugin
if
plugin
qDebug
loader
errorString
delete
loader
delete
loader
return
return
@@ -158,16 +161,19 @@ template <typename T> void dtkCorePluginManager<T>::unload(const QString& path)
T
plugin
qobject_cast
T
loader
instance
T
plugin
qobject_cast
T
loader
instance
if
plugin
if
plugin
plugin
uninitialize
plugin
uninitialize
if
loader
unload
if
loader
unload
d
loaders
remove
path
d
loaders
remove
path
delete
loader
delete
loader
else
qDebug
loader
errorString
#pragma mark -
#pragma Plugin Queries
// Plugin Queries
template
typename
T
QStringList
T
plugins
void
template
typename
T
QStringList
T
plugins
void
