GitLab
Support
Community forum
Keyboard shortcuts
D
dtk
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
dtk
dtk
8beec1e8
8beec1e8
KLOCZKO Thibaud
Merge branch 'hotfix/1.6.2'
parents
c81b80b3
2fecb550
4
4 changed files
42 additions
47 deletions
+42
-47
CHANGES.md
CHANGES.md
+2
CMakeLists.txt
CMakeLists.txt
+1
-1
src/dtkScript/dtkScriptInterpreterPython.cpp
+35
-43
src/dtkScript/dtkScriptInterpreterPython.h
+4
-3
CHANGES.md
8beec1e8
# ChangeLog
## version 1.6.2 - 2018-11-08
dtkScriptInterpreterPython enables release method (for real).
## version 1.6.1 - 2018-11-08
dtkScriptInterpreterPython enables release method.
## version 1.6.0 - 2018-11-07
CMakeLists.txt
8beec1e8
@@ -24,7 +24,7 @@ project(dtk)
set
dtk_VERSION_MAJOR 1
set
dtk_VERSION_MINOR 6
set
dtk_VERSION_PATCH
set
dtk_VERSION_PATCH
2
set
dtk_VERSION
dtk_VERSION_MAJOR
dtk_VERSION_MINOR
dtk_VERSION_PATCH
8beec1e8
@@ -57,9 +57,9 @@ public:
instance
void
if
s_instance
if
s_instance
s_instance
new
return
s_instance
@@ -68,85 +68,82 @@ dtkScriptInterpreterPython *dtkScriptInterpreterPython::s_instance = nullptr;
void
d
new
dtkScriptInterpreterPythonPrivate
Py_Initialize
// PyRun_SimpleString(dtkScriptInterpreterPythonRedirector_declare.toUtf8().constData());
QString
paths
QSettings
settings
QSettings
IniFormat
QSettings
UserScope
"inria"
"dtk-script"
settings
beginGroup
"modules"
paths
settings
value
"path"
toString
settings
endGroup
PyRun_SimpleString
"import sys"
foreach
QString
path
paths
split
QString
SkipEmptyParts
PyRun_SimpleString
QString
"sys.path.append('%1')"
arg
path
toUtf8
constData
void
Py_Finalize
delete
d
d
NULL
d
nullptr
void
init
void
Py_Initialize
QSettings
settings
QSettings
IniFormat
QSettings
UserScope
"inria"
"dtk-script"
settings
beginGroup
"modules"
QString
paths
settings
value
"path"
toString
settings
endGroup
PyRun_SimpleString
"import sys"
auto
path_list
paths
split
QString
SkipEmptyParts
for
QString
path
path_list
PyRun_SimpleString
qPrintable
QString
arg
path
settings
beginGroup
"init"
QString
init
settings
value
"script"
toString
settings
endGroup
if
init
isEmpty
PyRun_SimpleString
QString
"execfile('%1')"
arg
init
toUtf8
constData
PyRun_SimpleString
qPrintable
QString
"execfile('%1')"
arg
init
else
dtkWarn
"no init function "
dtkWarn
Q_FUNC_INFO
"No init function"
void
release
void
Py_Finalize
QString
interpret
const
QString
command
int
stat
QString
statement
command
if
command
endsWith
if
d
buffer
isEmpty
if
d
buffer
isEmpty
d
buffer
append
\n
d
buffer
append
command
return
return
QString
if
command
isEmpty
command
startsWith
if
d
buffer
isEmpty
if
d
buffer
isEmpty
d
buffer
append
\n
d
buffer
append
command
return
return
QString
if
command
isEmpty
d
buffer
isEmpty
if
d
buffer
isEmpty
if
d
buffer
isEmpty
d
buffer
append
\n
statement
d
buffer
d
buffer
clear
if
statement
isEmpty
return
if
statement
isEmpty
return
QString
PyObject
module
PyImport_AddModule
"__main__"
// PyRun_SimpleString(dtkScriptInterpreterPythonRedirector_define.toUtf8().constData());
switch
PyRun_SimpleString
statement
toUtf8
constData
switch
PyRun_SimpleString
qPrintable
statement
case
stat
Status_Ok
break
case
stat
Status_Error
break
default:
break
@@ -154,11 +151,6 @@ QString dtkScriptInterpreterPython::interpret(const QString& command, int *stat)
PyErr_Print
// PyObject *redtor = PyObject_GetAttrString(module, "redirector");
// PyObject *result = PyObject_GetAttrString(redtor, "data");
// return QString(PyString_AsString(result)).simplified();
return
QString
8beec1e8
@@ -14,9 +14,9 @@
#pragma once
#include
"dtkScriptInterpreter.h"
#include
<dtkScriptExport>
class
#include "dtkScriptInterpreter.h"
class
DTKSCRIPT_EXPORT
public
@@ -31,13 +31,14 @@ protected:
public
slots
QString
interpret
const
QString
command
int
stat
void
init
void
void
release
void
private:
void
void
private:
d
class
d
