Commit 2c18733d authored by LE BRETON Come's avatar LE BRETON Come
Nicer user api. But two dynamic casts.
parent 5e08573a
...@@ -17,6 +17,7 @@ ...@@ -17,6 +17,7 @@
#include <dtkCore/dtkCoreParameter> #include <dtkCore/dtkCoreParameter>
#include <dtkWidgets/dtkWidgetsParameter> #include <dtkWidgets/dtkWidgetsParameter>
#include <dtkWidgets/dtkWidgetsParameterFactory>
...@@ -38,8 +39,7 @@ int main(int argc, char **argv) ...@@ -38,8 +39,7 @@ int main(int argc, char **argv)
qDebug() << value; qDebug() << value;
dtkWidgetsParameterDouble *real_parameter_widget = dtk::widgets::parameterDouble::pluginFactory().create("dtkWidgetsParameterDoubleSpinBoxPlugin"); dtkWidgetsParameter *real_parameter_widget = dtk::widgets::pluginFactory().create(&real_parameter, "dtkWidgetsParameterDoubleSpinBoxPlugin");
real_parameter_widget->connect(&real_parameter);
window->setCentralWidget(real_parameter_widget); window->setCentralWidget(real_parameter_widget);
...@@ -41,19 +41,26 @@ dtkWidgetsParameterDoubleSpinBox::~dtkWidgetsParameterDoubleSpinBox(void) ...@@ -41,19 +41,26 @@ dtkWidgetsParameterDoubleSpinBox::~dtkWidgetsParameterDoubleSpinBox(void)
delete d; delete d;
void dtkWidgetsParameterDoubleSpinBox::connect(dtk::d_real *parameter) void dtkWidgetsParameterDoubleSpinBox::connect(dtkCoreAbstractParameter *parameter)
d->spin_box->setMinimum(parameter->min()); dtk::d_real *double_parameter = dynamic_cast<dtk::d_real *>(parameter);
d->spin_box->setMaximum(parameter->max());
d->spin_box->setToolTip(parameter->documentation());
QObject::connect(parameter, &dtk::d_real::valueChanged, [=] (QVariant v) { if(!double_parameter) {
qWarning() << "Could not connect the parameter to the widget, the parameter is not of type dtk::d_real";
return;
d->spin_box->setMinimum(double_parameter->min());
d->spin_box->setMaximum(double_parameter->max());
d->spin_box->setToolTip(double_parameter->documentation());
QObject::connect(double_parameter, &dtk::d_real::valueChanged, [=] (QVariant v) {
double value = v.value<dtk::d_real>().value(); double value = v.value<dtk::d_real>().value();
d->spin_box->setValue(value); d->spin_box->setValue(value);
QObject::connect(d->spin_box, QOverload<double>::of(&QDoubleSpinBox::valueChanged), [=] (double v) { QObject::connect(d->spin_box, QOverload<double>::of(&QDoubleSpinBox::valueChanged), [=] (double v) {
parameter->setValue(v); double_parameter->setValue(v);
...@@ -26,7 +26,7 @@ public: ...@@ -26,7 +26,7 @@ public:
virtual ~dtkWidgetsParameterDoubleSpinBox(void); virtual ~dtkWidgetsParameterDoubleSpinBox(void);
public: public:
virtual void connect(dtk::d_real *); virtual void connect(dtkCoreAbstractParameter *);
private: private:
class dtkWidgetsParameterDoubleSpinBoxPrivate *d; class dtkWidgetsParameterDoubleSpinBoxPrivate *d;
...@@ -34,9 +34,8 @@ private: ...@@ -34,9 +34,8 @@ private:
inline dtkWidgetsParameterDouble *dtkWidgetsParameterDoubleSpinBoxCreator(void) inline dtkWidgetsParameter *dtkWidgetsParameterDoubleSpinBoxCreator(void)
qDebug() << Q_FUNC_INFO;
return new dtkWidgetsParameterDoubleSpinBox(); return new dtkWidgetsParameterDoubleSpinBox();
...@@ -15,7 +15,7 @@ ...@@ -15,7 +15,7 @@
#include "dtkWidgetsParameterDoubleSpinBoxPlugin.h" #include "dtkWidgetsParameterDoubleSpinBoxPlugin.h"
#include "dtkWidgetsParameterDoubleSpinBox.h" #include "dtkWidgetsParameterDoubleSpinBox.h"
#include <dtkCoreWidgets/dtkCoreWidgets> #include <dtkWidgets/dtkWidgetsParameterFactory>
// dtkWidgetsParameterDoubleSpinBoxPlugin // dtkWidgetsParameterDoubleSpinBoxPlugin
...@@ -24,7 +24,7 @@ ...@@ -24,7 +24,7 @@
void dtkWidgetsParameterDoubleSpinBoxPlugin::initialize(void) void dtkWidgetsParameterDoubleSpinBoxPlugin::initialize(void)
qDebug() << Q_FUNC_INFO; qDebug() << Q_FUNC_INFO;
dtk::widgets::parameterDouble::pluginFactory().record("dtkWidgetsParameterDoubleSpinBoxPlugin", dtkWidgetsParameterDoubleSpinBoxCreator); dtk::widgets::pluginFactory().record("dtkWidgetsParameterDoubleSpinBoxPlugin", dtkWidgetsParameterDoubleSpinBoxCreator);
void dtkWidgetsParameterDoubleSpinBoxPlugin::uninitialize(void) void dtkWidgetsParameterDoubleSpinBoxPlugin::uninitialize(void)
...@@ -18,10 +18,10 @@ ...@@ -18,10 +18,10 @@
class dtkWidgetsParameterDoubleSpinBoxPlugin : public dtkWidgetsParameterDoublePlugin class dtkWidgetsParameterDoubleSpinBoxPlugin : public dtkWidgetsParameterPlugin
Q_OBJECT Q_OBJECT
Q_INTERFACES(dtkWidgetsParameterDoublePlugin); Q_INTERFACES(dtkWidgetsParameterPlugin);
Q_PLUGIN_METADATA(IID "fr.inria.dtkWidgetsParameterDoubleSpinBoxPlugin" FILE "dtkWidgetsParameterDoubleSpinBoxPlugin.json") Q_PLUGIN_METADATA(IID "fr.inria.dtkWidgetsParameterDoubleSpinBoxPlugin" FILE "dtkWidgetsParameterDoubleSpinBoxPlugin.json")
public: public:
"name" : "dtkWidgetsParameterDoubleSpinBoxPlugin", "name" : "dtkWidgetsParameterDoubleSpinBoxPlugin",
"concept" : "dtkWidgetsParameterDouble", "concept" : "dtkWidgetsParameter",
"version" : "0.0.1", "version" : "0.0.1",
"dependencies" : [] "dependencies" : []
...@@ -60,6 +60,8 @@ set(${PROJECT_NAME}_HEADERS ...@@ -60,6 +60,8 @@ set(${PROJECT_NAME}_HEADERS
dtkWidgetsOverlayRope.h dtkWidgetsOverlayRope.h
dtkWidgetsParameter dtkWidgetsParameter
dtkWidgetsParameter.h dtkWidgetsParameter.h
dtkWidgetsParameterFactory.h
dtkWidgetsSettings dtkWidgetsSettings
dtkWidgetsSettings.h dtkWidgetsSettings.h
dtkWidgetsStylesheetParser dtkWidgetsStylesheetParser
...@@ -88,6 +90,7 @@ set(${PROJECT_NAME}_SOURCES ...@@ -88,6 +90,7 @@ set(${PROJECT_NAME}_SOURCES
dtkWidgetsOverlayPaneSlider.cpp dtkWidgetsOverlayPaneSlider.cpp
dtkWidgetsOverlayRope.cpp dtkWidgetsOverlayRope.cpp
dtkWidgetsParameter.cpp dtkWidgetsParameter.cpp
dtkWidgetsParameterFactory.cpp
dtkWidgetsSettings.cpp dtkWidgetsSettings.cpp
dtkWidgetsStylesheetParser.cpp dtkWidgetsStylesheetParser.cpp
dtkWidgetsWidget.cpp) dtkWidgetsWidget.cpp)
#include "dtkWidgetsParameter.h" #include "dtkWidgetsParameter.h"
#include "dtkWidgets.h" #include "dtkWidgets.h"
namespace dtk {
namespace widgets {
DTK_DEFINE_CONCEPT(dtkWidgetsParameterDouble, parameterDouble, dtk::widgets);
...@@ -22,28 +22,31 @@ ...@@ -22,28 +22,31 @@
class DTKWIDGETS_EXPORT dtkWidgetsParameterInt : public QWidget class DTKWIDGETS_EXPORT dtkWidgetsParameter : public QWidget {
public: public:
virtual void connect(dtk::d_int *) = 0; dtkWidgetsParameter(QWidget *parent) : QWidget(parent) {};
virtual ~dtkWidgetsParameter() = default;
public:
virtual void connect(dtkCoreAbstractParameter *) = 0;
class DTKWIDGETS_EXPORT dtkWidgetsParameterDouble : public QWidget class DTKWIDGETS_EXPORT dtkWidgetsParameterInt : public dtkWidgetsParameter
public:
dtkWidgetsParameterDouble(QWidget *parent) : QWidget(parent) {};
class DTKWIDGETS_EXPORT dtkWidgetsParameterDouble : public dtkWidgetsParameter
public: public:
virtual void connect(dtk::d_real *) = 0; dtkWidgetsParameterDouble(QWidget *parent) : dtkWidgetsParameter(parent) {};
DTK_DECLARE_OBJECT(dtkWidgetsParameterDouble*); DTK_DECLARE_OBJECT(dtkWidgetsParameter*);
DTK_DECLARE_PLUGIN(dtkWidgetsParameter, DTKWIDGETS_EXPORT);
DTK_DECLARE_PLUGIN(dtkWidgetsParameterDouble, DTKWIDGETS_EXPORT); DTK_DECLARE_PLUGIN_FACTORY(dtkWidgetsParameter, DTKWIDGETS_EXPORT);
DTK_DECLARE_PLUGIN_FACTORY(dtkWidgetsParameterDouble, DTKWIDGETS_EXPORT); DTK_DECLARE_PLUGIN_MANAGER(dtkWidgetsParameter, DTKWIDGETS_EXPORT);
DTK_DECLARE_PLUGIN_MANAGER(dtkWidgetsParameterDouble, DTKWIDGETS_EXPORT);
// Register to dtkDiscretegeometry layer // Register to dtkDiscretegeometry layer
...@@ -51,7 +54,7 @@ DTK_DECLARE_PLUGIN_MANAGER(dtkWidgetsParameterDouble, DTKWIDGETS_EXPORT); ...@@ -51,7 +54,7 @@ DTK_DECLARE_PLUGIN_MANAGER(dtkWidgetsParameterDouble, DTKWIDGETS_EXPORT);
namespace dtk { namespace dtk {
namespace widgets { namespace widgets {
DTK_DECLARE_CONCEPT(dtkWidgetsParameterDouble, DTKWIDGETS_EXPORT, parameterDouble); DTK_DECLARE_CONCEPT(dtkWidgetsParameter, DTKWIDGETS_EXPORT, parameter);
#include "dtkWidgetsParameterFactory.h"
\ No newline at end of file
namespace dtk
namespace widgets
namespace _private
dtkWidgetsParameterFactory factory;
dtkWidgetsParameterPluginManager manager;
dtkWidgetsParameterFactory& pluginFactory()
return _private::factory;
dtkWidgetsParameterPluginManager& pluginManager()
return _private::manager;
namespace _private
dtkCorePluginManagerRecorder mrecorder(&dtk::widgets::manager(), &pluginManager(), "dtkWidgetsParameter");
dtkCorePluginFactoryRecorder frecorder(&dtk::widgets::manager(), &pluginFactory(), "dtkWidgetsParameter");
#pragma once
#include<dtkWidgetsExport.h>
class DTKWIDGETS_EXPORT dtkWidgetsParameterFactory : public dtkWidgetsParameterPluginFactory {
public:
dtkWidgetsParameter *create(dtkCoreAbstractParameter *parameter, const QString& key) {
dtkWidgetsParameter *widget = dtkWidgetsParameterPluginFactory::create(key);
qDebug() << "widget" << widget;
dtkWidgetsParameterDouble *double_widget = dynamic_cast<dtkWidgetsParameterDouble *>(widget);
if(double_widget) {
double_widget->connect(parameter);
return double_widget;
return nullptr;
namespace dtk
namespace widgets
DTKWIDGETS_EXPORT dtkWidgetsParameterFactory& pluginFactory();
DTKWIDGETS_EXPORT dtkWidgetsParameterPluginManager& pluginManager();
...@@ -21,6 +21,7 @@ ...@@ -21,6 +21,7 @@
#include <dtkWidgets/dtkWidgets> #include <dtkWidgets/dtkWidgets>
...@@ -63,7 +64,7 @@ void dtkWidgetsParameterTestCase::testBasic(void) ...@@ -63,7 +64,7 @@ void dtkWidgetsParameterTestCase::testBasic(void)
dtk::d_real real_parameter; dtk::d_real real_parameter;
dtkWidgetsParameterDouble *spin_box = dtk::widgets::parameterDouble::pluginFactory().create("dtkWidgetsSpinBoxPlugin"); dtkWidgetsParameter *spin_box = dtk::widgets::pluginFactory().create(&real_parameter, "dtkWidgetsParameterDoubleSpinBoxPlugin");
qDebug() << "spin_box" << spin_box; qDebug() << "spin_box" << spin_box;
