GitLab
Support
Community forum
Keyboard shortcuts
D
dtk-widgets
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Analytics
Analytics
Value Stream
dtk
dtk-widgets
55d73766
55d73766
NICLAUSSE Nicolas
add script to convert old parameters json to new one (move type)
fcadae62
44 additions
+44
tst/resources/convert_parameters.py
+44
0 → 100755
55d73766
#!/usr/bin/env python3
import
json
import
argparse
def
parse_group
json_o
type_map
for
c
in
json_o
"contents"
if
'group'
in
c
parse_group
c
'group'
type_map
else
uid
c
'parameter'
'uid'
newtype
c
'parameter'
'type'
del
c
'parameter'
'type'
type_map
uid
newtype
parser
argparse
ArgumentParser
description
'Process Convert dtk parameters file to new format (type in def).'
parser
add_argument
'def_file'
help
'definition file'
parser
add_argument
'menu_file'
help
'menu file'
args
parser
parse_args
def_data
open
args
def_file
menu_data
open
args
menu_file
def_json
json
load
def_data
menu_json
json
load
menu_data
type_map
for
c
in
menu_json
"contents"
parse_group
c
'group'
type_map
for
uid
in
def_json
"contents"
keys
if
uid
in
type_map
def_json
"contents"
uid
'type'
type_map
uid
else
print
uid
"not used !"
open
'new_menu.json'
'w'
as
outfile
print
"write new_menu.json"
json
dump
menu_json
outfile
indent
4
open
'new_definition.json'
'w'
as
outfile
print
"write new_definition.json"
json
dump
def_json
outfile
indent
4
