Verified Commit 4504da9e authored by SZPYRKA Jean-Luc's avatar SZPYRKA Jean-Luc
changed ignoreprefix
parent d674cadd
Pipeline #129292 passed with stage
in 3 minutes and 1 second
...@@ -1122,7 +1122,7 @@ COLS_IN_ALPHA_INDEX = 5 ...@@ -1122,7 +1122,7 @@ COLS_IN_ALPHA_INDEX = 5
# while generating the index headers. # while generating the index headers.
# This tag requires that the tag ALPHABETICAL_INDEX is set to YES. # This tag requires that the tag ALPHABETICAL_INDEX is set to YES.
IGNORE_PREFIX = @PROJECT_NAME@ IGNORE_PREFIX = dtk
# Configuration options related to the HTML output # Configuration options related to the HTML output
