Verified Commit 3d5aab50 authored by SZPYRKA Jean-Luc's avatar SZPYRKA Jean-Luc
renamed cmake tool file - fixed gunzip flag
parent 4a4f4848
Pipeline #130704 failed with stage
in 3 minutes and 11 seconds
...@@ -41,7 +41,7 @@ set(${PROJECT_NAME}_VERSION ...@@ -41,7 +41,7 @@ set(${PROJECT_NAME}_VERSION
#set(DTK_WIDGETS_DIRECTORY ${CMAKE_SOURCE_DIR}/../dtk-widgets) #set(DTK_WIDGETS_DIRECTORY ${CMAKE_SOURCE_DIR}/../dtk-widgets)
set(CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH} "${CMAKE_SOURCE_DIR}/cmake") set(CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH} "${CMAKE_SOURCE_DIR}/cmake")
include(git_clone) include(cloning_tools)
dtk_clone(dtk-core) dtk_clone(dtk-core)
dtk_clone(dtk-log) dtk_clone(dtk-log)
...@@ -71,7 +71,7 @@ function(tag_clone module url) ...@@ -71,7 +71,7 @@ function(tag_clone module url)
if ( ${result} ) if ( ${result} )
message("Decompressing: ${output_filename}") message("Decompressing: ${output_filename}")
execute_process(COMMAND execute_process(COMMAND
gunzip -k -f ${output_filename} gunzip -f ${output_filename}
WORKING_DIRECTORY ${output_directory} WORKING_DIRECTORY ${output_directory}
endif() endif()
