Verified Commit 0ef68732 authored by SZPYRKA Jean-Luc's avatar SZPYRKA Jean-Luc
changed exclude pattern
parent 4504da9e
Pipeline #129300 failed with stage
in 15 seconds
...@@ -928,7 +928,7 @@ EXCLUDE_PATTERNS = */tst/* */doc/* ...@@ -928,7 +928,7 @@ EXCLUDE_PATTERNS = */tst/* */doc/*
# Note that the wildcards are matched against the file with absolute path, so to # Note that the wildcards are matched against the file with absolute path, so to
# exclude all test directories use the pattern */test/* # exclude all test directories use the pattern */test/*
EXCLUDE_SYMBOLS = EXCLUDE_SYMBOLS = dtk::detail::is_*
# The EXAMPLE_PATH tag can be used to specify one or more files or directories # The EXAMPLE_PATH tag can be used to specify one or more files or directories
# that contain example code fragments that are included (see the \include # that contain example code fragments that are included (see the \include
