GitLab
Explore
Primary navigation
Search or go to…
S
Synthesis_Modules
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
dnarXiv
Synthesis_Modules
c8f78cfc
c8f78cfc
1 year ago
BOULLE Olivier
Downloads
Patches
more comments
520f1b35
primers_generation.py
+15
-9
15 additions, 9 deletions
15 additions
9 deletions
15
9
c8f78cfc
@@ -74,29 +74,34 @@ def select_primers(primers_list: list, number_assembly: int) -> list:
primers needs to not hybridize with each other
selected_primers_list
def
test_hybridation
primer
str
list
max_hybridisation_value
4
bool
def
test_hybridation
primer
str
list
4
bool
test the hybridisation of the primer with a list of other primers
primer_rc
dfr
reverse_complement
primer
primer_rc
dfr
reverse_complement
primer
# get the reverse complement of the primer
for
selected_primer
in
for
selected_primer
in
for
i
in
range
len
primer
for
i
in
range
len
primer
# test if any part of the primer is contained in another primer from the list (= hybridisation)
if
primer
i
i
in
selected_primer
if
primer
i
i
in
selected_primer
return
False
return
False
# test also for the reverse complement
if
primer_rc
i
i
in
selected_primer
if
primer_rc
i
i
in
selected_primer
return
False
return
False
# return true if no hybridisation at all
return
True
return
True
def
compare_GC
primer_A
str
primer_B
str
bool
def
compare_GC
primer_A
str
primer_B
str
bool
primers have a special temperature in PCR depending on %GC, a couple (start;stop) needs to have a close tmp, so the same %GC is better
return true if the %GC is the same for the 2 primers
start_GC
primer_A
count
C
primer_A
count
G
primer_A
count
A
primer_A
count
T
start_GC
primer_A
count
C
primer_A
count
G
primer_A
count
A
primer_A
count
T
# get the %GC of the first primer
stop_GC
primer_B
count
C
primer_B
count
G
primer_B
count
A
primer_B
count
T
stop_GC
primer_B
count
C
primer_B
count
G
primer_B
count
A
primer_B
count
T
# get the %GC of the second primer
return
start_GC
stop_GC
return
start_GC
stop_GC
@@ -110,19 +115,20 @@ def select_primers(primers_list: list, number_assembly: int) -> list:
# the primer must not hybridise with any previous selected primers
if
test_hybridation
potential_stop_primer
4
if
test_hybridation
4
potential_start_primer
# add the couple
# add the couple
to the list
print
str
len
2
str
number_assembly
print
str
len
2
str
number_assembly
# all required primers have been selected
if
if
len
number_assembly
2
if
len
number_assembly
2
#print(selected_primers_list)
return
return
# end the script with the result
# the corresponding stop primer has been found
break
# return to start primers search
break
# not enough couple of primers found
print
error in fragment design : not enough correct primers couple found, found
str
len
but wanted
str
number_assembly
2
print
str
len
but wanted
str
number_assembly
2
print
can be solved by using a longer random sequence in primers_generation
print
to have a longer primer list
return
return
This diff is collapsed.
Loading
Save comment
