Commit c8f78cfc authored by BOULLE Olivier's avatar BOULLE Olivier
more comments
parent 520f1b35
......@@ -74,29 +74,34 @@ def select_primers(primers_list: list, number_assembly: int) -> list:
primers needs to not hybridize with each other
selected_primers_list = []
def test_hybridation(primer: str, selected_primers_list: list, max_hybridisation_value=4) -> bool:
test the hybridisation of the primer with a list of other primers
primer_rc = dfr.reverse_complement(primer)
primer_rc = dfr.reverse_complement(primer) # get the reverse complement of the primer
for selected_primer in selected_primers_list:
for i in range(len(primer)-max_hybridisation_value):
# test if any part of the primer is contained in another primer from the list (= hybridisation)
if primer[i:i+max_hybridisation_value+1] in selected_primer:
return False
# test also for the reverse complement
if primer_rc[i:i+max_hybridisation_value+1] in selected_primer:
return False
# return true if no hybridisation at all
return True
def compare_GC(primer_A: str, primer_B: str) -> bool:
primers have a special temperature in PCR depending on %GC, a couple (start;stop) needs to have a close tmp, so the same %GC is better
return true if the %GC is the same for the 2 primers
start_GC = (primer_A.count("C") + primer_A.count("G"))/(primer_A.count("A")+primer_A.count("T"))
stop_GC = (primer_B.count("C") + primer_B.count("G"))/(primer_B.count("A")+primer_B.count("T"))
start_GC = (primer_A.count("C") + primer_A.count("G"))/(primer_A.count("A")+primer_A.count("T")) # get the %GC of the first primer
stop_GC = (primer_B.count("C") + primer_B.count("G"))/(primer_B.count("A")+primer_B.count("T")) # get the %GC of the second primer
return start_GC == stop_GC
......@@ -110,19 +115,20 @@ def select_primers(primers_list: list, number_assembly: int) -> list:
# the primer must not hybridise with any previous selected primers
if test_hybridation(potential_stop_primer, selected_primers_list, 4):
selected_primers_list += [potential_start_primer, potential_stop_primer] # add the couple
selected_primers_list += [potential_start_primer, potential_stop_primer] # add the couple to the list
print(str(len(selected_primers_list)//2)+"/"+str(number_assembly))
# all required primers have been selected
# if all required primers have been selected
if len(selected_primers_list) == number_assembly*2:
#print(selected_primers_list)
return selected_primers_list
return selected_primers_list # end the script with the result
# the corresponding stop primer has been found
break # return to start primers search
# not enough couple of primers found
print("error in fragment design : not enough correct primers couple found, found",str(len(selected_primers_list)),"but wanted",str(number_assembly*2))
print("can be solved by using a longer random sequence in primers_generation")
print("can be solved by using a longer random sequence in primers_generation to have a longer primer list ")
