GitLab
Explore
Primary navigation
Search or go to…
S
Synthesis_Modules
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
dnarXiv
Synthesis_Modules
bf3c176a
bf3c176a
2 years ago
BOULLE Olivier
Downloads
Patches
mono primers couple for all storage
64218c17
eBlocks_design.py
+4
-2
4 additions, 2 deletions
eBlocks_design.py
4 additions
2 deletions
eBlocks_design.py
4
2
bf3c176a
@@ -269,8 +269,10 @@ def eBlocks_design(payload_fragments_dir_path: str, output_dir_path: str) -> Non
print
len
compatible_primers_list
primers
print
len
primers
# select a primers couples for each assembly
selected_primers_list
pg
select_primers
len
full_assembly_total_sequences
#TODO selected_primers_list = pg.select_primers(compatible_primers_list, len(full_assembly_total_sequences))
pg
select_primers
# only 1 couple for all storage
len
# get a list of n times the same couple for the n molecules
assigned_primers_dict
# to save which primers couple is assigned to which file
if
len
2
len
# not enough primers couple
if
len
2
len
This diff is collapsed.
Loading
Save comment
