Commit 9ab558df authored by BOULLE Olivier's avatar BOULLE Olivier
cheaper way to get clique
parent e656fcf3
Branches main
......@@ -7,6 +7,8 @@
#include <stack>
#include <string>
#include <algorithm>
#include <random>
#include <chrono>
#include <vector>
#include <map>
......@@ -23,7 +25,7 @@ public:
void add_edge(int node_a, int node_b);
// get a big clique with an heuristique
vector<int> get_clique();
vector<int> get_clique_from_graph();
Graph::Graph(int g_size) {
......@@ -39,7 +41,7 @@ void Graph::add_edge(int node_a, int node_b) {
//sort the vector by edge number
vector<int> Graph::get_clique() {
vector<int> Graph::get_clique_from_graph() {
// heuristique here (maximum clique is NP-complete)
// sort nodes by number of edges
// start a clique from the node with most edges
......@@ -114,20 +116,21 @@ string rev_comp(string sequence) {
bool test_hybridation(string primer_a, string primer_b) {
int max_hybridisation_value = 4;
// true if the 2 primers do not have any hybridation >=4
int max_hybridisation_value = 6; // maximum autorized number of consecutive common bases
int primer_size = 20;
for (int i = 0; i <= primer_size-max_hybridisation_value; ++i) {
string kmer_a = primer_a.substr(i, max_hybridisation_value);
string rev_primer_a = rev_comp(primer_a);
for (int i = 0; i <= primer_size-max_hybridisation_value-1; ++i) {
string kmer_a = primer_a.substr(i, max_hybridisation_value+1);
if (primer_b.find(kmer_a) != string::npos) {
//cout << primer_b << " " << kmer_a << endl;
return false;
string kmer_rev_a = rev_primer_a.substr(i, max_hybridisation_value);
string kmer_rev_a = rev_primer_a.substr(i, max_hybridisation_value+1);
if (primer_b.find(kmer_rev_a) != string::npos) {
//cout << primer_b << " " << kmer_rev_a << endl;
return false;
......@@ -138,6 +141,8 @@ bool test_hybridation(string primer_a, string primer_b) {
Graph compute_hybridation(vector<string> primers_list) {
// generate a graph of primers intercompatiblity
// too long for >20k primers
int primers_n = primers_list.size();
Graph g(primers_n);
......@@ -158,13 +163,47 @@ Graph compute_hybridation(vector<string> primers_list) {
int main() {
vector<string> get_clique(vector<string> primers_list) {
// since it is too long to generate the graph of intercompatibility between primers
// start from a random primer and add the others to the clique by testing hybridation
vector<string> clique_list;
bool compatible;
for(const string& tested_primer : primers_list) {
compatible = true;
for(const string& clique_primer : clique_list) {
if (test_hybridation(tested_primer, clique_primer) == false) { // tested node is not linked to a node from the clique
compatible = false;
break; // cannot be added to the clique -> test the next node
// the tested node is linked to every node in the clique
if (compatible) {
clique_list.push_back(tested_primer); // add to the clique
return clique_list;
int main(int argc,char* argv[]) {
//args = primers_list.txt clique_size
if(argc != 4) {
printf("usage : get_clique primers_list.txt output_path.txt clique_size\n");
return 1;
printf("get clique of compatible primers...\n");
string primers_path = argv[1]; //txt file of the primers //"primer_generator/temp/checked_primers.txt"
string output_path = argv[2];
int clique_size = stoi(argv[3]); // size of the clique to find
// read list of primers
vector<string> primers_list;
ifstream input_file;
input_file.open("primer_generator/temp/checked_primers.txt");
input_file.open(primers_path);
string myline;
if ( input_file.is_open() ) {
while ( input_file ) {
......@@ -175,21 +214,34 @@ int main() {
} else {
cout << "Couldn't open file\n";
// use indexes of primers in the list
Graph g = compute_hybridation(primers_list);
cout << "get clique : hybridation graph created" << endl;
vector<int> clique_list = g.get_clique();
cout << "get clique : found clique of " << clique_list.size() << " primers" << endl;
for( int i = 1; i <= 10; i++) {
// get a time-based seed
unsigned seed = std::chrono::system_clock::now().time_since_epoch().count();
// random shuffle of the primers list
std::shuffle(std::begin(primers_list), std::end(primers_list), std::default_random_engine(seed));
// generate a clique
clique_list = get_clique(primers_list);
cout << "get clique : " << i << "/10; found clique of " << clique_list.size() << " primers" << endl;
if (clique_list.size() >= clique_size) {
// save the resulting clique
ofstream output_file;
output_file.open (output_path);
for(const string& primer : clique_list) {
output_file << primer << "\n";
output_file.close();
// successfull end
return 0;
output_file.open ("test_primers.txt");
for(const int& node : clique_list) {
output_file << primers_list[node] << "\n";
cout << "get clique : couldn't find a clique of the required size" << endl;
return 0;
// failed end
return 1;
