GitLab
Explore
Primary navigation
Search or go to…
S
Synthesis_Modules
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
dnarXiv
Synthesis_Modules
4ba034e1
4ba034e1
2 years ago
BOULLE Olivier
Downloads
Patches
fix buf removing some assemblies
382e55bc
eBlock_assembly_simulation.py
+8
-2
8 additions, 2 deletions
8 additions
2 deletions
8
2
4ba034e1
@@ -80,6 +80,10 @@ def assemble_blocks_simulation(eBlocks_list: list, nbr_mol: int) -> dict:
for
block
in
eBlocks_list
last_overhang
current_assembly
overhang_size
if
block
overhang_size
last_overhang
print
error assembly simulation, overhangs not compatibles
last_overhang
block
overhang_size
exit
overhang_link_proba
float
overhang_assembly_stats_dict
last_overhang
if
random
random
overhang_link_proba
# chance to succeed overhang linking
@@ -91,6 +95,7 @@ def assemble_blocks_simulation(eBlocks_list: list, nbr_mol: int) -> dict:
# add the assembly to the dict
assembly_dict
molecule_
str
mol_index
current_assembly
mol_index
return
assembly_dict
@@ -146,7 +151,8 @@ def eBlocks_assembly(input_path: str, output_path: str, nbr_mol: int) -> None:
# simulate bsaI digestion
blocks_list
digest_bsaI
blocks_list
# simulation assembly by overhangs, fatal error if overhangs are not compatibles for successive blocks
assembly_dict
assemble_blocks
blocks_list
#assembly_dict = assemble_blocks(blocks_list)
assembly_dict
blocks_list
nbr_mol
# save the assemblies into file
dfr
save_dict_to_fasta
assembly_dict
output_path
@@ -156,7 +162,7 @@ def container_assembly(input_dir_path, output_dir_path, nbr_mol):
for
filename
in
os
listdir
input_dir_path
file_path
os
path
join
input_dir_path
filename
if
os
path
isdir
file_path
input_file
file_path
/5_blocks_buffer.fasta
output_file
os
path
join
output_dir_path
filename
.fasta
This diff is collapsed.
Loading
Save comment
