GitLab
Explore
Primary navigation
Search or go to…
S
Source_Encoding
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
dnarXiv
Source_Encoding
a8f0f9e1
a8f0f9e1
7 months ago
BOULLE Olivier
Downloads
Patches
updated correct typing
34e64b35
binary_dna_conversion.py
+3
-3
3 additions, 3 deletions
3 additions
3 deletions
3
3
a8f0f9e1
@@ -29,7 +29,7 @@ def bit_to_dna_balance_GC(bit_char: str, reference_base: str):
return
bit_to_dna_AT
bit_char
return
bit_to_dna_AT
bit_char
def
forbidden_rest_abaab
binary_string_size
str
bool
def
binary_string_size
int
bool
return True if the binary is of a length that cannot be converted by the abaab method
@@ -45,7 +45,7 @@ def binary_to_dna_abaab(binary_string: str) -> str:
4th 5th bits are normally converted into dna
6th 7th bits are normally converted into dna
8th bit is converted depending on previous conversion : if previous in {AT}, then (0:G, 1:C), elif in {GC}, then (0:A, 1:T)
this ensure that the total sequence cannot contain homopolymers > 3,
this ensure
s
the GC% is in [40%, 60%] in a window of 5 and the conversion rate is 1.6 bit/base
warning : need the binary string to be a multiple of 2, or rest is inconsistent with decoding
@@ -238,7 +238,7 @@ def size_binary_from_dna_len_abaab(dna_length):
return
base_length
7
return
base_length
7
def
forbidden_rest_baa
binary_string_size
str
bool
def
forbidden_rest_baa
binary_string_size
int
bool
return True if the binary is of a length that cannot be converted by the baa method
This diff is collapsed.
Loading
Save comment
