Commit ddf2b64d authored by Bruno Guillaume's avatar Bruno Guillaume
version 2.29.0: call dep2pict_qt when ≤ 2 arguments
parent 9318a1d4
...@@ -17,7 +17,3 @@ depends: [ ...@@ -17,7 +17,3 @@ depends: [
"camomile" "camomile"
"libcaml-dep2pict" "libcaml-dep2pict"
depopts: [
"lablgtk"
"lablwebkit"
...@@ -105,7 +105,8 @@ let json_apply json_in json_out = ...@@ -105,7 +105,8 @@ let json_apply json_in json_out =
let main () = let main () =
let () = parse_arg (List.tl (Array.to_list Sys.argv)) in let arg_list = List.tl (Array.to_list Sys.argv) in
let () = parse_arg arg_list in
if !debug then Dep2pict.set_verbose (); if !debug then Dep2pict.set_verbose ();
...@@ -117,7 +118,12 @@ let main () = ...@@ -117,7 +118,12 @@ let main () =
(* check for input_file and load file if any *) (* check for input_file and load file if any *)
match !output_file with match !output_file with
| None -> failwith "TODO call gui" | None ->
begin
match Unix.system ("dep2pict_qt" ^ " " ^ (String.concat " " arg_list)) with
| Unix.WEXITED 127 -> Log.warning "It seems that dep2pict_qt is not installed on your system. See [http://dep2pict.loria.fr/installation] for more information"
| _ -> ()
| Some out_file -> | Some out_file ->
if (Format.get !input_file) = Format.Json if (Format.get !input_file) = Format.Json
then json_apply (Yojson.Basic.from_file !input_file) out_file then json_apply (Yojson.Basic.from_file !input_file) out_file
