Commit ae57cff0 authored by Berenger Bramas's avatar Berenger Bramas
Add test coverage -- plus add it to the gitlab ci
parent c705a208
...@@ -118,3 +118,36 @@ inastempsdehsw: ...@@ -118,3 +118,36 @@ inastempsdehsw:
- make test - make test
tags: tags:
- sde - sde
inastempgccsdecov:
stage: test
script:
- mkdir build
- cd build
- VERBOSE=1 cmake -DINASTEMP_WITH_PROF=ON ..
- VERBOSE=1 make
- VERBOSE=1 make lcov_clean
- VERBOSE=1 make test
- VERBOSE=1 make lcov_capture
- VERBOSE=1 make lcov_html
tags:
- gcc
- lcov
artifacts:
paths:
- coverage/
pages:
stage: deploy
dependencies:
- inastempgccsdecov
script:
- mv coverage/ public/
artifacts:
paths:
- public
expire_in: 30 days
only:
- code-coverage
- master
...@@ -187,6 +187,30 @@ list(GET ALL_USED_TYPES -1 INASTEMP_BESTTYPE ) ...@@ -187,6 +187,30 @@ list(GET ALL_USED_TYPES -1 INASTEMP_BESTTYPE )
SET( INASTEMP_EXTRA_CXX_FLAGS "-funroll-loops" CACHE STRING "These flags are used for all configurations" ) SET( INASTEMP_EXTRA_CXX_FLAGS "-funroll-loops" CACHE STRING "These flags are used for all configurations" )
set(INASTEMP_CXX_FLAGS "${INASTEMP_CXX_FLAGS} ${INASTEMP_EXTRA_CXX_FLAGS}") set(INASTEMP_CXX_FLAGS "${INASTEMP_CXX_FLAGS} ${INASTEMP_EXTRA_CXX_FLAGS}")
if(${CMAKE_CXX_COMPILER_ID} MATCHES GNU OR CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX )
# For test coverage
option(INASTEMP_WITH_PROF "Enable profiling and coverage report analysis" OFF)
if(INASTEMP_WITH_PROF)
set(INASTEMP_CXX_FLAGS "${INASTEMP_CXX_FLAGS} --coverage -fprofile-arcs -ftest-coverage")
list(APPEND INASTEMP_LIBRARIES "-fprofile-arcs")
add_custom_target(lcov_clean
COMMAND lcov --directory "${CMAKE_BINARY_DIR}" --zerocounters
WORKING_DIRECTORY "${CMAKE_BINARY_DIR}")
add_custom_target(lcov_capture
COMMAND lcov --directory "${CMAKE_BINARY_DIR}" --capture --output-file "${CMAKE_BINARY_DIR}/app.info"
add_custom_target(lcov_html
COMMAND genhtml --output-directory "${CMAKE_BINARY_DIR}/coverage" --demangle-cpp --sort --title "Complexes" --function-coverage --branch-coverage --legend "${CMAKE_BINARY_DIR}/app.info"
message(STATUS "INASTEMP_WITH_PROF has been turned to ${INASTEMP_WITH_PROF}")
endif()
endif()
# Options # Options
if(NOT INASTEMP_AS_SUBPROJECT) if(NOT INASTEMP_AS_SUBPROJECT)
SET( INASTEMP_EXTRA_CXX_FLAGS_RELEASE "-O3" CACHE STRING "These flags are added to the usual ones for RELEASE" ) SET( INASTEMP_EXTRA_CXX_FLAGS_RELEASE "-O3" CACHE STRING "These flags are added to the usual ones for RELEASE" )
