Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit 4a905b99 authored by Berenger Bramas's avatar Berenger Bramas
Update examples -- Add altivec in exp test
parent a0d25748
......@@ -272,6 +272,85 @@ inline void InaVecAVX512KNL_exp(const double inVal[], double outVal[]) {
#endif
#ifdef INASTEMP_USE_ALTIVEC
#include "ALTIVEC/InaVecALTIVECDouble.hpp"
#include "ALTIVEC/InaVecALTIVECFloat.hpp"
inline void InaVecALTIVEC_exp(const float inVal[], float outVal[]) {
__vector float vec = vec_xl(0, inVal);
const __vector float COEFF_LOG2E = vec_splats(float(InaFastExp::CoeffLog2E()));
const __vector float COEFF_A = vec_splats(float(InaFastExp::CoeffA32()));
const __vector float COEFF_B = vec_splats(float(InaFastExp::CoeffB32()));
const __vector float COEFF_P5_A = vec_splats(float(InaFastExp::GetCoefficient6_5()));
const __vector float COEFF_P5_B = vec_splats(float(InaFastExp::GetCoefficient6_4()));
const __vector float COEFF_P5_C = vec_splats(float(InaFastExp::GetCoefficient6_3()));
const __vector float COEFF_P5_D = vec_splats(float(InaFastExp::GetCoefficient6_2()));
const __vector float COEFF_P5_E = vec_splats(float(InaFastExp::GetCoefficient6_1()));
const __vector float COEFF_P5_F = vec_splats(float(InaFastExp::GetCoefficient6_0()));
__vector float x = vec * COEFF_LOG2E;
const __vector float fractional_part = x - vec_floor(x);
__vector float factor = (((((COEFF_P5_A * fractional_part + COEFF_P5_B)
* fractional_part + COEFF_P5_C)
* fractional_part + COEFF_P5_D)
* fractional_part + COEFF_P5_E)
* fractional_part + COEFF_P5_F);
x -= factor;
__vector int castedInteger = vec_cts(COEFF_A * x + COEFF_B, 0);
vec = reinterpret_cast<__vector float>(castedInteger);
alignas(16) float tmpptr[4];
vec_st(vec, 0, tmpptr);
outVal[0] = tmpptr[0];
outVal[1] = tmpptr[1];
outVal[2] = tmpptr[2];
outVal[3] = tmpptr[3];
inline void InaVecALTIVEC_exp(const double inVal[], double outVal[]) {
__vector double vec = vec_xl(0, &inVal[0]);
const __vector double COEFF_LOG2E = vec_splats(double(InaFastExp::CoeffLog2E()));
const __vector double COEFF_A = vec_splats(double(InaFastExp::CoeffA64()));
const __vector double COEFF_B = vec_splats(double(InaFastExp::CoeffB64()));
const __vector double COEFF_P5_C = vec_splats(double(InaFastExp::GetCoefficient4_3()));
const __vector double COEFF_P5_D = vec_splats(double(InaFastExp::GetCoefficient4_2()));
const __vector double COEFF_P5_E = vec_splats(double(InaFastExp::GetCoefficient4_1()));
const __vector double COEFF_P5_F = vec_splats(double(InaFastExp::GetCoefficient4_0()));
__vector double x = vec * COEFF_LOG2E;
const __vector double fractional_part = x - vec_floor(x);
__vector double factor = (((COEFF_P5_C * fractional_part + COEFF_P5_D)
x -= factor;
x = COEFF_A * x + COEFF_B;
// TODO find conversion function
//__vector long castedInteger = vec_cts(x, 0);
//return reinterpret_cast<__vector double>(castedInteger);
alignas(16) double tmpptr[2];
vec_st( reinterpret_cast<__vector unsigned int>(x), 0, reinterpret_cast<unsigned int*>(tmpptr));
alignas(16) long ltmpptr[2];
ltmpptr[0] = long(tmpptr[0]);
ltmpptr[1] = long(tmpptr[1]);
vec = reinterpret_cast<__vector double>(vec_xl(0, ltmpptr));
vec_st(reinterpret_cast<__vector unsigned int>(vec), 0, reinterpret_cast<unsigned int*>(outVal));
#endif
template <class VecType>
void GenericExpInavec(const size_t NbOverLoop, const size_t NbExp){
using RealType = typename VecType::RealType;
......@@ -406,6 +485,34 @@ void compareExpTime(const size_t NbOverLoop, const size_t NbExp){
std::cout << "\n";
#endif
GenericExpInavec<InaVecALTIVEC<RealType>>(NbOverLoop, NbExp);
// Raw SIMD
const int VecLength = InaVecALTIVEC<RealType>::VecLength;
// Note : we increase the length of the vector to avoid checking the loop size
std::unique_ptr< RealType[] > resSimd(new RealType[NbExp + VecLength]);
InaTimer timer;
for (size_t idxLoop = 0; idxLoop < NbOverLoop; ++idxLoop) {
for (size_t idx = 0; idx < NbExp; idx += VecLength) {
alignas(64) RealType bufferX[VecLength];
// Copy value into a buffer since we do it on the fly
for (size_t idxX = 0; idxX < VecLength; ++idxX) {
bufferX[idxX] = static_cast<RealType>((idx + idxX) % 200);
InaVecALTIVEC_exp(bufferX, &resSimd[idx]);
timer.stop();
std::cout << "Vector " << "ALTIVEC" << " for " << NbExp * NbOverLoop
<< " exp took " << timer.getElapsed() << "s (" << timer.getElapsed()/double(NbExp * NbOverLoop) << "s per exp)\n";
std::cout << "\n";
#endif
int main(int /*argc*/, char* /*argv*/ []) {
