Commit 8f523096 authored by Jacques-Henri Jourdan's avatar Jacques-Henri Jourdan
Make ProofMode tactics work in RO mode.
Generalization of xpull in the case of RO triples, which are not local.
ram_apply locks the intermediate assertion if the post-condition is an evar.
use rule_seq instead of rule_seq' in ExampleListProofMode.
parent 0e67038d
...@@ -67,8 +67,8 @@ Lemma MCell_hstar_MCell_inv : forall p1 p2 x1 x2 y1 y2, ...@@ -67,8 +67,8 @@ Lemma MCell_hstar_MCell_inv : forall p1 p2 x1 x2 y1 y2,
MCell x1 y1 p1 \* MCell x2 y2 p2 ==+> \[p1 <> p2]. MCell x1 y1 p1 \* MCell x2 y2 p2 ==+> \[p1 <> p2].
Proof using. Proof using.
intros. do 2 rewrite MCell_eq. tests C: (p1 = p2). intros. do 2 rewrite MCell_eq. tests C: (p1 = p2).
{ iClean. iIntros. iDestruct (hstar_hfield_same_loc_disjoint with "[$]") as %[]. } { iPrepare. iIntros. iDestruct (hstar_hfield_same_loc_disjoint with "[$]") as %[]. }
{ iClean. auto with iFrame. } { iPrepare. auto with iFrame. }
Qed. Qed.
...@@ -112,7 +112,7 @@ Lemma rule_set_hd : forall p v' v vq, ...@@ -112,7 +112,7 @@ Lemma rule_set_hd : forall p v' v vq,
(MCell v' vq p) (MCell v' vq p)
(fun r => \[r = val_unit] \* MCell v vq p). (fun r => \[r = val_unit] \* MCell v vq p).
intros. unfold MCell. ram_apply rule_set_field. auto with iFrame. intros. unfold MCell. ram_apply rule_set_field. auto with iFrame.
Qed. Qed.
Hint Extern 1 (Register_spec val_set_hd) => Provide rule_set_hd. Hint Extern 1 (Register_spec val_set_hd) => Provide rule_set_hd.
...@@ -174,9 +174,10 @@ Lemma rule_new_cell' : forall v q, ...@@ -174,9 +174,10 @@ Lemma rule_new_cell' : forall v q,
intros. eapply rule_app_fun2 =>//=; []. intros. eapply rule_app_fun2 =>//=; [].
eapply rule_let; [apply rule_alloc_cell|]=>p /=. xpull=> p' v' q' ->. eapply rule_let; [apply rule_alloc_cell|]=>p /=. xpull=> p' v' q' ->.
eapply rule_seq'. { rewrite MCell_eq. ram_apply rule_set_hd. auto with iFrame. } eapply rule_seq; last admit.
eapply rule_seq'. { ram_apply rule_set_tl. auto with iFrame. } { rewrite MCell_eq. ram_apply rule_set_hd. auto with iFrame. }
eapply rule_val. auto with iFrame. unlock. eapply rule_seq; last admit. { ram_apply rule_set_tl. auto with iFrame. }
unlock. eapply rule_val. iPrepare. auto with iFrame.
Qed. Qed.
Hint Extern 1 (Register_spec val_new_cell) => Provide rule_new_cell. Hint Extern 1 (Register_spec val_new_cell) => Provide rule_new_cell.
...@@ -304,18 +305,18 @@ Proof using. ...@@ -304,18 +305,18 @@ Proof using.
intros L. induction_wf: list_sub_wf L. intros p. intros L. induction_wf: list_sub_wf L. intros p.
applys rule_app_fix=>//=. applys rule_if'. applys rule_app_fix=>//=. applys rule_if'.
- ram_apply rule_neq. auto with iFrame. - ram_apply rule_neq. auto with iFrame.
- xpull=>[= Hp]. rewrite true_eq_isTrue_eq in Hp. - unlock. xpull=>[= Hp]. rewrite true_eq_isTrue_eq in Hp.
xchange (MList_not_null_inv_cons p); [by auto|]. xpull=>p' x L' ?. subst. xchange (MList_not_null_inv_cons p); [by auto|]. xpull=>p' x L' ?. subst.
applys rule_let. { ram_apply rule_get_tl. iIntros "?$%??". iAccu. } applys rule_let. { ram_apply rule_get_tl. auto with iFrame. }
move=> q /=. xpull=>->. unlock. move=> q /=. xpull=>->.
applys rule_let. { ram_apply (IH L'); [done|]. iIntros "?$%??". iAccu. } applys rule_let. { ram_apply (IH L'); [done|]. auto with iFrame. }
move=> n /=. xpull=>->. ram_apply rule_add. unlock. move=> n /=. xpull=>->. ram_apply rule_add.
iIntros "??%->". iSplitR. iIntros "??" (?) "->". iSplitR.
{ iPureIntro. f_equal. math. } { iApply MList_cons. iFrame. } { iPureIntro. f_equal. math. } { iApply MList_cons. iFrame. }
- eapply rule_val. iClean. iIntros "HL" ([= Hp]). revert Hp. - unlock. eapply rule_val. iPrepare. iIntros "HL" ([= Hp]). revert Hp.
rewrite false_eq_isTrue_eq=>/not_not_inv. intros [= ->]. rewrite false_eq_isTrue_eq=>/not_not_inv. intros [= ->].
iDestruct (MList_null_inv with "HL") as "[$ ->]". auto. iDestruct (MList_null_inv with "HL") as "[$ ->]". auto.
- iIntros ([] Hb) "[? %]"=>//. destruct Hb. eexists _. auto. - unlock. iIntros ([] Hb) "[? %]"=>//. destruct Hb. eexists _. auto.
Qed. Qed.
...@@ -344,33 +345,34 @@ Lemma rule_mlist_length_loop : forall L p, ...@@ -344,33 +345,34 @@ Lemma rule_mlist_length_loop : forall L p,
intros L p. eapply rule_app_fun=>//=. intros L p. eapply rule_app_fun=>//=.
applys rule_let. { ram_apply rule_ref. auto with iFrame. } applys rule_let. { ram_apply rule_ref. auto with iFrame. }
move=> ? /=. xpull=>r ->. unlock. move=> ? /=. xpull=>r ->.
move=> ? /=. xpull=>n ->. applys rule_seq'. unlock. move=> ? /=. xpull=>n ->. applys rule_seq; last admit.
- applys rule_while=>t R. - applys rule_while=>t R.
cuts K: (forall (nacc:int), cuts K: (forall (nacc:int),
triple t (n ~~~> nacc \* MList L p \* r ~~~> p) triple t (n ~~~> nacc \* MList L p \* r ~~~> p)
(λ r0 : val, \[r0 = '()] \* n ~~~> (nacc + length L)%Z \* MList L p)). (λ r0 : val, \[r0 = '()] \* n ~~~> (nacc + length L)%Z \* MList L p)).
{ ram_apply K. auto with iFrame. } { ram_apply K. auto with iFrame. }
gen p. induction_wf: list_sub_wf L=>p nacc. apply R. applys rule_if'. gen p. induction_wf: list_sub_wf L=>p nacc. apply R. applys rule_if'.
+ eapply rule_let. ram_apply rule_get. { iIntros "??$ % ??". iAccu. } + eapply rule_let. ram_apply rule_get. { auto with iFrame. }
move=>pp /=. xpull=>->. ram_apply rule_neq. eauto with iFrame. unlock. move=>pp /=. xpull=>->. ram_apply rule_neq. eauto with iFrame.
+ xpull. intros [=Hp]. rewrite true_eq_isTrue_eq in Hp. + unlock. xpull. intros [=Hp]. rewrite true_eq_isTrue_eq in Hp.
xchange (MList_not_null_inv_cons p); [by auto|iClean; auto with iFrame|]. xchange (MList_not_null_inv_cons p); [by auto|iPrepare; auto with iFrame|].
xpull=>p' x L' ?. subst. applys rule_seq'. xpull=>p' x L' ?. subst. applys rule_seq; last admit.
* applys rule_seq'. { ram_apply rule_incr. auto with iFrame. } * applys rule_seq; last admit. { ram_apply rule_incr. auto with iFrame. }
eapply rule_let. { ram_apply rule_get. iIntros "$???%??". iAccu. } unlock. eapply rule_let. { ram_apply rule_get. auto with iFrame. }
xpull=>? -> /=. eapply rule_let. unlock. xpull=>? -> /=. eapply rule_let.
{ ram_apply rule_get_tl. iIntros "??$?%??". iAccu. } { ram_apply rule_get_tl. auto with iFrame. }
move=>? /=. xpull=>->. ram_apply rule_set. auto with iFrame. unlock. move=>? /=. xpull=>->. ram_apply rule_set. auto with iFrame.
* ram_apply (IH L'); [done|]. iIntros. iFrame. iIntros (?) "$ Hn ?". iSplitL "Hn". * unlock. ram_apply (IH L'); [done|]. iIntros. iFrame.
-- by math_rewrite ((nacc + 1) + length L' = nacc + S (length (L')))%Z. -- by math_rewrite ((nacc + 1) + length L' = nacc + S (length (L')))%Z.
-- iApply MList_cons. iFrame. -- iApply MList_cons. iFrame.
+ iApply rule_val_htop. iClean. iIntros "? HL ?" ([= Hp]). + unlock. iApply rule_val_htop. iPrepare. iIntros "? HL ?" ([= Hp]).
revert Hp. rewrite false_eq_isTrue_eq. intros [= ->]%not_not_inv. revert Hp. rewrite false_eq_isTrue_eq. intros [= ->]%not_not_inv.
iDestruct (MList_null_inv with "HL") as "[$ ->]". rewrite plus_zero_r. by iFrame. iDestruct (MList_null_inv with "HL") as "[$ ->]". rewrite plus_zero_r. by iFrame.
+ iIntros ([] Hb) "(? & ? & ? & %)"=>//. destruct Hb. eexists _. auto. + unlock. iIntros ([] Hb) "(? & ? & ? & %)"=>//. destruct Hb. eexists _. auto.
- apply rule_htop_post. ram_apply rule_get. auto with iFrame. - unlock. apply rule_htop_post. ram_apply rule_get. auto with iFrame.
Qed. Qed.
...@@ -47,7 +47,7 @@ Lemma RO_himpl_RO_hstar_RO : forall H, ...@@ -47,7 +47,7 @@ Lemma RO_himpl_RO_hstar_RO : forall H,
RO H ==> (RO H \* RO H). RO H ==> (RO H \* RO H).
Proof using. intros. applys RO_duplicatable. Qed. Proof using. intros. applys RO_duplicatable. Qed.
Lemma rule_xchange : forall (H1 H1':hprop), H1 ==> H1' -> Lemma rule_xchange : forall (H1 H1':hprop), H1 ==> H1' ->
forall t H H2 Q, forall t H H2 Q,
H ==> H1 \* H2 -> H ==> H1 \* H2 ->
triple t (H1' \* H2) Q -> triple t (H1' \* H2) Q ->
...@@ -59,7 +59,7 @@ Qed. ...@@ -59,7 +59,7 @@ Qed.
Lemma rule_frame_read_only_conseq : forall t H1 Q1 H2 H Q, Lemma rule_frame_read_only_conseq : forall t H1 Q1 H2 H Q,
H ==> (H1 \* H2) -> H ==> (H1 \* H2) ->
normal H1 -> Normal H1 ->
triple t (RO H1 \* H2) Q1 -> triple t (RO H1 \* H2) Q1 ->
(Q1 \*+ H1) ===> Q -> (Q1 \*+ H1) ===> Q ->
triple t H Q. triple t H Q.
...@@ -71,12 +71,12 @@ Qed. ...@@ -71,12 +71,12 @@ Qed.
Lemma rule_get : forall v l, Lemma rule_get : forall v l,
triple (val_get (val_loc l)) triple (val_get (val_loc l))
(l ~~~> v) (l ~~~> v)
(fun x => \[x = v] \* l ~~~> v). (fun x => \[x = v] \* l ~~~> v).
intros. applys rule_frame_read_only_conseq (l ~~~> v). intros. applys rule_frame_read_only_conseq (l ~~~> v).
{ hsimpl. } { applys normal_hsingle. (* todo: normal_hsingle? *) } { hsimpl. } { apply _. }
{ rew_heap. applys rule_get_ro. } { rew_heap. applys rule_get_ro. }
{ auto. } { auto. }
Qed. Qed.
...@@ -90,7 +90,7 @@ Proof using. introv WP M1 M2. applys* rule_consequence WP. applys* rule_let. Qed ...@@ -90,7 +90,7 @@ Proof using. introv WP M1 M2. applys* rule_consequence WP. applys* rule_let. Qed
Lemma rule_frame : forall t H1 Q1 H2, Lemma rule_frame : forall t H1 Q1 H2,
triple t H1 Q1 -> triple t H1 Q1 ->
normal H2 -> Normal H2 ->
triple t (H1 \* H2) (Q1 \*+ H2). triple t (H1 \* H2) (Q1 \*+ H2).
introv M N. applys~ rule_frame_read_only. introv M N. applys~ rule_frame_read_only.
...@@ -100,13 +100,13 @@ Qed. ...@@ -100,13 +100,13 @@ Qed.
Lemma rule_frame_conseq : forall t H1 Q1 H2 H Q, Lemma rule_frame_conseq : forall t H1 Q1 H2 H Q,
H ==> H2 \* H1 -> H ==> H2 \* H1 ->
triple t H2 Q1 -> triple t H2 Q1 ->
Q1 \*+ H1 ===> Q -> Q1 \*+ H1 ===> Q ->
Proof using. intros. applys* rule_consequence. applys* rule_frame. Qed. Proof using. intros. applys* rule_consequence. applys* rule_frame. Qed.
Hint Resolve normal_hsingle. Hint Resolve Normal_hsingle.
...@@ -175,7 +175,7 @@ Definition val_ref_update := ...@@ -175,7 +175,7 @@ Definition val_ref_update :=
val_set 'p 'y. val_set 'p 'y.
Lemma rule_ref_update : forall (f:val) (p:loc) (v:val) (H:hprop) (Q:val->hprop), Lemma rule_ref_update : forall (f:val) (p:loc) (v:val) (H:hprop) (Q:val->hprop),
normal_post Q -> (* todo: this might not be needed if using "normally" *) Normal_post Q -> (* todo: this might not be needed if using "normally" *)
(triple (f v) (triple (f v)
PRE (RO(p ~~~> v) \* H) PRE (RO(p ~~~> v) \* H)
POST Q) POST Q)
...@@ -185,13 +185,13 @@ Lemma rule_ref_update : forall (f:val) (p:loc) (v:val) (H:hprop) (Q:val->hprop), ...@@ -185,13 +185,13 @@ Lemma rule_ref_update : forall (f:val) (p:loc) (v:val) (H:hprop) (Q:val->hprop),
POST (fun r => \[r = val_unit] \* Hexists w, (p ~~~> w) \* (Q w))). POST (fun r => \[r = val_unit] \* Hexists w, (p ~~~> w) \* (Q w))).
introv N M. introv N M.
rew_nary; rew_vals_to_trms; applys rule_apps_funs; rew_nary; rew_vals_to_trms; applys rule_apps_funs;
[unfold val_ref_update; rew_nary; reflexivity| auto | simpl]. [unfold val_ref_update; rew_nary; reflexivity| auto | simpl].
applys rule_let. applys rule_let.
{ applys rule_get. } { applys rule_get. }
{ intros x; simpl; rew_heap. applys rule_extract_hprop ;=> E; subst x. { intros x; simpl; rew_heap. applys rule_extract_hprop ;=> E; subst x.
applys rule_let' \[]. { hsimpl. } applys rule_let' \[]. { hsimpl. }
applys~ rule_frame_read_only_conseq (p ~~~> v). applys~ rule_frame_read_only_conseq (p ~~~> v).
{ hsimpl. } { rew_heap. applys M. } { hsimpl. } { hsimpl. } { rew_heap. applys M. } { hsimpl. }
{ intros y; simpl; rew_heap. clear M. { intros y; simpl; rew_heap. clear M.
applys~ rule_frame_conseq (Q y). hsimpl. applys~ rule_frame_conseq (Q y). hsimpl.
This file formalizes example in Separation Logic with read-only predicates
Author: Arthur Charguéraud.
License: MIT.
Set Implicit Arguments.
From Sep Require Import LambdaSepRO.
Import ProofMode.
Generalizable Variables A B.
Open Scope trm_scope.
Ltac auto_star ::= jauto.
Implicit Types p q : loc.
Implicit Types n : int.
Implicit Types v : val.
(* To move and factorize *)
Notation "F 'PRE' H 'POST' Q" :=
(F H Q)
(at level 69, only parsing) : heap_scope.
(* todo move *)
Lemma rule_apps_funs : forall xs F (Vs:vals) t1 H Q,
F = (val_funs xs t1) ->
var_funs (LibList.length Vs) xs ->
triple (substs xs Vs t1) H Q ->
triple (trm_apps F Vs) H Q.
Proof using.
introv E N M. intros h1 h2 D H1.
forwards~ (h1'&v&N1&N2&N3&N4): (rm M) h2 H1.
exists h1' v. splits~. { subst. applys~ red_app_funs_val. }
Qed.
Lemma var_funs_exec_elim : forall (n:nat) xs,
var_funs_exec n xs -> (var_funs n xs).
Proof using. introv M. rewrite var_funs_exec_eq in M. rew_istrue~ in M. Qed.
Hint Resolve var_funs_exec_elim.
(* * Formalisation of higher-order iterator on a reference *)
(** Apply a function to the contents of a reference *)
Definition val_ref_apply :=
ValFun 'f 'p :=
Let 'x := val_get 'p in
'f 'x.
Lemma rule_ref_apply : forall (f:val) (p:loc) (v:val) (H:hprop) (Q:val->hprop),
(triple (f v)
POST Q)
(triple (val_ref_apply f p)
POST Q).
Proof using.
introv M.
[unfold val_ref_apply; rew_nary; reflexivity| auto | simpl].
ram_apply_let rule_get_ro. { auto with iFrame. }
move=>X /=. unlock. xpull=>->. done.
Qed.
(** In-place update of a reference by applying a function *)
ValFun 'f 'p :=
Let 'y := 'f 'x in
val_set 'p 'y.
(triple (f v)
POST Q)
(triple (val_ref_update f p)
PRE (p ~~~> v \* H)
Proof using.
introv N M.
unlock. move=>x /=. xpull=>->. ram_apply_let M. { auto with iFrame. }
unlock. move=>y /=. ram_apply rule_set. { auto 10 with iFrame. }
Qed.
This diff is collapsed.
...@@ -14,7 +14,7 @@ COQFLAGS:=-w -notation-overridden,-implicits-in-term ...@@ -14,7 +14,7 @@ COQFLAGS:=-w -notation-overridden,-implicits-in-term
# Compilation. # Compilation.
# Note: double space below is important for export.sh # Note: double space below is important for export.sh
SRC := TLCbuffer Fmap SepFunctor SepTactics LambdaSemantics LambdaSep LambdaSepCredits LambdaSepRO LambdaCFTactics LambdaCF LambdaStruct LambdaSepLifted LambdaCFLifted LambdaStructLifted Example ExampleBasicNonlifted ExampleListNonlifted ExampleQueueNonlifted ExampleBasic ExampleTrees ExampleUnionFind ExampleHigherOrder ExampleList LambdaCFCredits ExampleRO ExampleListProofMode SRC := TLCbuffer Fmap SepFunctor SepTactics LambdaSemantics LambdaSep LambdaSepCredits LambdaSepRO LambdaCFTactics LambdaCF LambdaStruct LambdaSepLifted LambdaCFLifted LambdaStructLifted Example ExampleBasicNonlifted ExampleListNonlifted ExampleQueueNonlifted ExampleBasic ExampleTrees ExampleUnionFind ExampleHigherOrder ExampleList LambdaCFCredits ExampleRO ExampleROProofMode ExampleListProofMode
# LambdaCFRO # LambdaCFRO
...@@ -1739,7 +1739,7 @@ Ltac xpull_check tt := ...@@ -1739,7 +1739,7 @@ Ltac xpull_check tt :=
(** Lemmas *) (** Lemmas *)
Lemma xpull_start : forall B (F:~~B) H Q, Lemma xpull_start : forall B (F:~~B) H Q,
is_local F -> F (\[] \* H) Q -> F H Q. F (\[] \* H) Q -> F H Q.
Proof using. intros. rew_heap in *. auto. Qed. Proof using. intros. rew_heap in *. auto. Qed.
Lemma xpull_keep : forall B (F:~~B) H1 H2 H3 Q, Lemma xpull_keep : forall B (F:~~B) H1 H2 H3 Q,
...@@ -1755,7 +1755,7 @@ Lemma xpull_starify : forall B (F:~~B) H1 H2 Q, ...@@ -1755,7 +1755,7 @@ Lemma xpull_starify : forall B (F:~~B) H1 H2 Q,
Lemma xpull_empty : forall B (F:~~B) H1 H2 Q, Lemma xpull_empty : forall B (F:~~B) H1 H2 Q,
is_local F -> (F (H1 \* H2) Q) -> F (H1 \* (\[] \* H2)) Q. (F (H1 \* H2) Q) -> F (H1 \* (\[] \* H2)) Q.
Proof using. intros. rew_heap. auto. Qed. Proof using. intros. rew_heap. auto. Qed.
Lemma xpull_hprop : forall B (F:~~B) H1 H2 P Q, Lemma xpull_hprop : forall B (F:~~B) H1 H2 P Q,
...@@ -1783,7 +1783,7 @@ Ltac xpull_setup tt := ...@@ -1783,7 +1783,7 @@ Ltac xpull_setup tt :=
try match goal with |- ?H ==> ?H' => try match goal with |- ?H ==> ?H' =>
fail 100 "you should call hpull, not xpull" end; fail 100 "you should call hpull, not xpull" end;
ProofModeInstantiate.unfold_proofmode; ProofModeInstantiate.unfold_proofmode;
apply xpull_start; [ try xlocal | ]. apply xpull_start.
Ltac xpull_post_processing_for_hyp H := Ltac xpull_post_processing_for_hyp H :=
idtac. idtac.
...@@ -1792,16 +1792,23 @@ Ltac xpull_cleanup tt := ...@@ -1792,16 +1792,23 @@ Ltac xpull_cleanup tt :=
remove_empty_heaps_formula tt; remove_empty_heaps_formula tt;
gen_until_mark_with_processing ltac:(xpull_post_processing_for_hyp). gen_until_mark_with_processing ltac:(xpull_post_processing_for_hyp).
Ltac xpull_hprop tt :=
apply xpull_hprop; [ try xlocal | intro ].
Ltac xpull_hexists tt :=
apply xpull_hexists; [ try xlocal | intro ].
Ltac xpull_id tt :=
apply xpull_id; [ try xlocal | intro ].
Ltac xpull_step tt := Ltac xpull_step tt :=
let go HP := let go HP :=
match HP with _ \* ?HN => match HP with _ \* ?HN =>
match HN with match HN with
| ?H \* _ => | ?H \* _ =>
match H with match H with
| \[] => apply xpull_empty; try xlocal | \[] => apply xpull_empty
| \[_] => apply xpull_hprop; [ try xlocal | intro ] | \[_] => xpull_hprop tt
| hexists _ => apply xpull_hexists; [ try xlocal | intro ] | hexists _ => xpull_hexists tt
| _ ~> Id _ => apply xpull_id; [ try xlocal | intro ] | _ ~> Id _ => xpull_id tt
| _ \* _ => apply xpull_assoc | _ \* _ => apply xpull_assoc
| _ => apply xpull_keep | _ => apply xpull_keep
end end
...@@ -2293,7 +2300,7 @@ Proof. ...@@ -2293,7 +2300,7 @@ Proof.
rewrite /FromPure /Frame=><- /=. destruct p=>/=; iIntros "[% _] !%"; auto. rewrite /FromPure /Frame=><- /=. destruct p=>/=; iIntros "[% _] !%"; auto.
Qed. Qed.
(** [PrepareHProp] / [iClean] tactic. *) (** [PrepareHProp] / [iPrepare] tactic. *)
Class PrepareHProp (P Q : hprop) := prepare_hprop_eq : P = Q. Class PrepareHProp (P Q : hprop) := prepare_hprop_eq : P = Q.
Hint Mode PrepareHProp ! - : typeclass_instances. Hint Mode PrepareHProp ! - : typeclass_instances.
...@@ -2364,18 +2371,38 @@ Hint Extern 1 (PrepareHProp (_ \* emp%I)%I _) => ...@@ -2364,18 +2371,38 @@ Hint Extern 1 (PrepareHProp (_ \* emp%I)%I _) =>
Hint Extern 1 (PrepareHProp (_ emp) _) => Hint Extern 1 (PrepareHProp (_ emp) _) =>
simple apply prepare_hprop_hstar_hemp : typeclass_instances. simple apply prepare_hprop_hstar_hemp : typeclass_instances.
Lemma tac_clean Δ (P Q : hprop) : Lemma tac_prepare Δ (P Q : hprop) :
PrepareHProp P Q PrepareHProp P Q
envs_entails Δ Q envs_entails Δ Q
envs_entails Δ P. envs_entails Δ P.
Proof. by rewrite /PrepareHProp=>->. Qed. Proof. by rewrite /PrepareHProp=>->. Qed.
Ltac iClean := Ltac iPrepare :=
iStartProof; iStartProof;
eapply tac_clean; [apply _|cbv beta]. eapply tac_prepare; [apply _|cbv beta].
(* ProofMode's [iIntros] tend to move pure facts in Coq's context.
While, in general, this is desirable, this is not what we want
after having applied [local_ramified_frame] because we would loose
pure facts that will not be unified in [Q] when [Q] is an evar. As
a result, we use a specific version of this lemma where Q1 is
locked, and hence pure facts cannot escape.
This specific version is only used when the post-condition is
indeed an evar. *)
Lemma local_ramified_frame_locked {B} : forall (Q1 : B hprop) H1 F H Q,
is_local F ->
F H1 Q1 ->
H ==> H1 \* (locked Q1 \---* Q) ->
F H Q.
Proof using. unlock. apply local_ramified_frame. Qed.
Ltac ram_apply lem := Ltac ram_apply lem :=
eapply local_ramified_frame; [xlocal|eapply lem|iClean]. lazymatch goal with
| |- ?F _ ?Q =>
(is_evar Q; eapply local_ramified_frame_locked) ||
end; [xlocal|eapply lem|iPrepare].
End ProofMode. End ProofMode.
