Commit 6e11695f authored by Jacques-Henri Jourdan's avatar Jacques-Henri Jourdan
Improve tactics a bit.
parent 4a91ae92
...@@ -151,7 +151,7 @@ Lemma rule_box_get : forall p n, ...@@ -151,7 +151,7 @@ Lemma rule_box_get : forall p n,
Proof using. Proof using.
intros. xdef. xchanges (RO_Box_unfold p) ;=> q. intros. xdef. xchanges (RO_Box_unfold p) ;=> q.
xletapp rule_get_ro => ? ->. xletapp rule_get_ro => ? ->.
ram_apply rule_get_ro. iIntros "_ $". auto. (* TODO : improve. *) ram_apply rule_get_ro. auto with iFrame.
Qed. Qed.
(* detailed proof (to keep somewhere for debugging): (* detailed proof (to keep somewhere for debugging):
...@@ -294,11 +294,13 @@ Proof using. ...@@ -294,11 +294,13 @@ Proof using.
xletfun => F HF. xletfun => F HF.
ram_apply_let (rule_box_twice (fun (x:int) => (x + n)%Z) n). ram_apply_let (rule_box_twice (fun (x:int) => (x + n)%Z) n).
{ intros. xdef'. xletapp rule_box_get => m ->. { intros. xdef'. xletapp rule_box_get => m ->.
ram_apply rule_add. { iModIntro. auto. } } (* TODO : improve. *) ram_apply rule_add. { iIntros "?".
iSplitR. iModIntro. auto. auto with iFrame. } } (* TODO : improve. *)
{ iIntros "Hq Hp". iDestruct (Box_fold with "[$Hq $Hp]") as "$". { iIntros "Hq Hp". iDestruct (Box_fold with "[$Hq $Hp]") as "$".
auto with iFrame. } auto with iFrame. }
unlock. xpull=> u /= _. apply rule_htop_post. ram_apply rule_box_get. unlock. xpull=> u /= _. apply rule_htop_post. ram_apply rule_box_get.
math_rewrite (2 * (n + n) = 4 * n)%Z. math_rewrite (2 * (n + n) = 4 * n)%Z.
iIntros "$ !>". auto 10. (* TODO: improve. *) iIntros "$". auto 10 with iFrame. (* TODO: improve. *)
Qed. Qed.
...@@ -1887,7 +1887,8 @@ Hint Extern 1 (Frame _ (RO _) (ROFrame _ ?Q) _) => ...@@ -1887,7 +1887,8 @@ Hint Extern 1 (Frame _ (RO _) (ROFrame _ ?Q) _) =>
lazymatch Q with lazymatch Q with
| normally _ => fail | normally _ => fail
| _ => simple eapply @frame_roframe_ro_lr | _ => simple eapply @frame_roframe_ro_lr
end. end
: typeclass_instances.
(* 2nd step: we try to frame on the LHS. *) (* 2nd step: we try to frame on the LHS. *)
Instance frame_roframe_l p (R P P' Q S : hprop) : Instance frame_roframe_l p (R P P' Q S : hprop) :
...@@ -1913,28 +1914,29 @@ Qed. ...@@ -1913,28 +1914,29 @@ Qed.
(** Setup iModIntro to work with normally. *) (** Setup iModIntro to work with normally. *)
Lemma modality_normally_mixin : Lemma modality_normally_mixin :
modality_mixin normally MIEnvId (MIEnvForall Normal). modality_mixin normally MIEnvId
(MIEnvTransform (λ P Q : hprop, TCAnd (TCEq P Q) (Normal P))).
Proof. Proof.
split; simpl; intros. split; simpl.
- by intros h [-> ?]. - by intros P h [-> ?].
- by apply normally_intro. - by intros P Q [-> ?]; apply normally_intro.
- by rewrite normally_hempty. - by rewrite normally_hempty.
- by f_equiv. - by intros P Q ?; f_equiv.
- by rewrite normally_hstar. - by intros P Q; rewrite normally_hstar.
Qed. Qed.
Definition modality_normally := Definition modality_normally :=
Modality _ modality_normally_mixin. Modality _ modality_normally_mixin.
Instance from_modal_normally P : Instance from_modal_normally P :
FromModal modality_normally (normally P) (normally P) P. FromModal modality_normally (normally P) (normally P) P.
Proof. by rewrite /FromModal. Qed. Proof. by rewrite /FromModal. Qed.
(* Low priority to force annotation. *)
Instance from_modal_abs_normally P : Instance from_modal_abs_normally P :
FromModal modality_normally (<absorb> normally P) (<absorb> normally P) P. FromModal modality_normally (normally P) (<absorb> normally P) P | 100.
Proof. by rewrite /FromModal -bi.absorbingly_intro. Qed. Proof. by rewrite /FromModal -bi.absorbingly_intro. Qed.
(** A bit of automation for ROFrame and normally. *) (** A bit of automation for ROFrame and normally. *)
Hint Extern 2 (envs_entails _ (ROFrame _ _)) => progress iFrame : iFrame. Hint Extern 2 (envs_entails _ (ROFrame _ _)) => progress iFrame : iFrame.
Hint Extern 2 (envs_entails _ (<absorb> ROFrame _ _)) => progress iFrame : iFrame.
Hint Extern 0 (envs_entails _ (ROFrame \[_] _)) => iSplitR. Hint Extern 0 (envs_entails _ (ROFrame \[_] _)) => iSplitR.
Hint Extern 0 (envs_entails _ (ROFrame _ \[_])) => iSplitL. Hint Extern 0 (envs_entails _ (ROFrame _ \[_])) => iSplitL.
...@@ -1942,11 +1944,9 @@ Hint Extern 0 (envs_entails _ (ROFrame \[] _)) => iSplitR. ...@@ -1942,11 +1944,9 @@ Hint Extern 0 (envs_entails _ (ROFrame \[] _)) => iSplitR.
Hint Extern 0 (envs_entails _ (ROFrame _ \[])) => iSplitL. Hint Extern 0 (envs_entails _ (ROFrame _ \[])) => iSplitL.
Hint Extern 0 (envs_entails _ (ROFrame emp%I _)) => iSplitR. Hint Extern 0 (envs_entails _ (ROFrame emp%I _)) => iSplitR.
Hint Extern 0 (envs_entails _ (ROFrame _ emp%I)) => iSplitL. Hint Extern 0 (envs_entails _ (ROFrame _ emp%I)) => iSplitL.
Hint Extern 0 (envs_entails _ (<absorb> ROFrame _ _)) => iSplit.
Hint Extern 0 (envs_entails _ (normally _)) => iModIntro (normally _). Hint Extern 0 (envs_entails _ (normally _)) => iModIntro (normally _).
Hint Extern 0 (envs_entails _ (<absorb> normally _)) => Hint Extern 0 (envs_entails _ (<absorb> normally _)) => iModIntro (normally _)%I.
iModIntro (<absorb> normally _)%I.
(** [PrepareHProp] stuff. *) (** [PrepareHProp] stuff. *)
