Commit 0eb80e14 authored by Jacques-Henri Jourdan's avatar Jacques-Henri Jourdan
Work on ROFrame.
parent d76039be
...@@ -1476,55 +1476,113 @@ Lemma rule_frame_read_only_with_frame : forall t H1 H2 H3 Q1, ...@@ -1476,55 +1476,113 @@ Lemma rule_frame_read_only_with_frame : forall t H1 H2 H3 Q1,
triple t (H1 \* RO H2) Q1 -> triple t (H1 \* RO H2) Q1 ->
triple t (H1 \* normally H2 \* normally H3) ((Q1 \*+ normally H2) \*+ normally H3). triple t (H1 \* normally H2 \* normally H3) ((Q1 \*+ normally H2) \*+ normally H3).
Proof using. Proof using.
introv M. rewrite <- hstar_assoc. applys rule_frame. introv M. rewrite <- hstar_assoc. applys rule_frame.
{ applys~ rule_frame_read_only'. } { applys~ rule_frame_read_only'. }
{ applys normal_normally. } { applys normal_normally. }
Qed. Qed.
(* ** Definition ofe the ROFrame connective *)
Definition ROFrame (H1 H2 : hprop) :=
Hexists H3, normally H3 \* (RO(H3) \--* H1) \* normally(H3 \--* H2).
Lemma ROFrame_himpl : forall H1 H2 H1' H2',
H1 ==> H1' -> H2 ==> H2' -> ROFrame H1 H2 ==> ROFrame H1' H2'.
Proof.
unfold ROFrame. intros H1 H2 H1' H2' MONO1 MONO2.
apply himpl_hexists_l=>H3. apply himpl_hexists_r with H3. hsimpl.
eapply himpl_trans; [apply himpl_frame_r|apply himpl_frame_l].
{ auto using hwand_himpl_r. } { auto using normally_himpl, hwand_himpl_r. }
Qed.
Lemma ROFrame_intro : forall H1 H2,
H1 \* normally H2 ==> ROFrame H1 H2.
Proof.
intros. unfold ROFrame. apply himpl_hexists_r with \[].
rewrite normally_hempty, RO_empty, hstar_hempty_l.
- apply normally_himpl. apply hwand_move_l. hsimpl.
- apply hwand_move_l. hsimpl.
Qed.
Lemma ROFrame_frame_l : forall H1 H2 H3,
H1 \* ROFrame H2 H3 ==> ROFrame (H1 \* H2) H3.
Proof.
intros. unfold ROFrame. hpull=>HF. apply himpl_hexists_r with HF. hsimpl.
apply hwand_move_l. hsimpl. apply hwand_cancel.
Qed.
Lemma ROFrame_frame_lr : forall H1 H2 H3,
normal H1 ->
H1 \* ROFrame H2 H3 ==> ROFrame (RO(H1) \* H2) (H1 \* H3).
Proof.
intros H1 H2 H3 NORM.
unfold ROFrame. hpull=>HF. apply himpl_hexists_r with (H1 \* HF).
hchange (normally_intro NORM). rewrite normally_hstar. hsimpl.
- apply hwand_move_l. hchange (RO_star H1 HF). hsimpl.
rewrite hstar_comm. apply hwand_cancel.
- apply normally_himpl, hwand_move_l. hsimpl. apply hwand_cancel.
Qed.
Lemma ROFrame_frame_lr' : forall H1 H2 H3,
normal H1 ->
H1 \* ROFrame H2 (H1 \--* H3) ==> ROFrame (RO(H1) \* H2) H3.
Proof.
intros H1 H2 H3 NORM. hchange (@ROFrame_frame_lr H1 H2 (H1 \--* H3) NORM).
hsimpl. apply ROFrame_himpl; [hsimpl|]. apply hwand_cancel.
Qed.
Lemma ROFrame_frame_r : forall H1 H2 H3,
normal H1 ->
H1 \* ROFrame H2 H3 ==> ROFrame H2 (H1 \* H3).
Proof.
hchange (normally_intro NORM). rewrite hstar_hempty_r, <-normally_hstar.
apply normally_himpl. apply hwand_move_l. hsimpl. apply hwand_cancel.
Qed.
(* ** Ramified read-only frame rule *) (* ** Ramified read-only frame rule *)
Lemma rule_ramified_frame_read_only_core : forall H2 t H Q H' Q', Lemma rule_ramified_frame_read_only_core : forall H2 t H Q H' Q',
triple t H' Q' -> triple t H' Q' ->
H = normally H2 \* (RO H2 \--* H') \* normally ((Q' \*+ normally H2) \---* Q) -> H = normally H2 \* (RO H2 \--* H') \* normally (H2 \--* (Q' \---* Q)) ->
triple t H Q. triple t H Q.
introv M W. subst H. introv M W. subst H.
forwards K: rule_frame_read_only_with_frame t (RO H2 \--* H') H2 ((Q' \*+ normally H2) \---* Q) Q'. forwards K: rule_frame_read_only_with_frame t (RO H2 \--* H') H2 (H2 \--* (Q' \---* Q)) Q'.
{ applys~ rule_consequence M. hchanges (hwand_cancel (RO H2)). } { applys~ rule_consequence M. hchanges (hwand_cancel (RO H2)). }
{ clear M. applys rule_consequence (rm K). { clear M. applys rule_consequence (rm K).
{ hsimpl. } { hsimpl. }
{ intros x. hchange (>> normally_erase (Q' \*+ normally H2 \---* Q)). { intros x. hchange (>> normally_erase (H2 \--* (Q' \---* Q))).
hchange (>> qwand_cancel_part (normally H2)). hchange (>> normally_erase H2). hchange (>> hwand_cancel H2 (Q' \---* Q)).
hchange (qwand_himpl_hwand x). hchanges (hwand_cancel (Q' x)). } } hsimpl. apply qwand_cancel. } }
Qed. Qed.
Lemma rule_ramified_frame_read_only : forall t H Q H' Q', Lemma rule_ramified_frame_read_only : forall t H Q H' Q',
H ==> Hexists H2, normally H2 H ==> ROFrame H' (Q' \---* Q) ->
\* (RO H2 \--* (H' \* RO \Top))
introv M W. applys~ rule_consequence Q (rm W). introv M W. applys~ rule_consequence Q (rm W).
applys rule_extract_hexists. intros H2. applys rule_extract_hexists. intros H2.
asserts M': (triple t (H' \* RO \Top) Q'). asserts M': (triple t H' Q').
{ applys* rule_consequence (H' \* \Top). hsimpl. { applys* rule_consequence H'. }
applys~ rule_htop_pre. }
clear M. applys* rule_ramified_frame_read_only_core. clear M. applys* rule_ramified_frame_read_only_core.
Qed. Qed.
Lemma rule_ramified_frame_read_only_direct : forall H2 t H Q H' Q', Lemma rule_ramified_frame_read_only_direct : forall H2 t H Q H' Q',
H ==> normally H2 \* (RO H2 \--* (H' \* RO \Top)) \* normally ((Q' \*+ normally H2) \---* Q) -> H ==> normally H2 \* (RO H2 \--* H') \*
introv M W. applys rule_ramified_frame_read_only M. hchanges W. introv M W. applys rule_ramified_frame_read_only M. unfold ROFrame. hchanges W.
Qed. Qed.
...@@ -2234,11 +2234,17 @@ Hint Extern 2 (envs_entails _ (_ \* _)) => progress iFrame : iFrame. ...@@ -2234,11 +2234,17 @@ Hint Extern 2 (envs_entails _ (_ \* _)) => progress iFrame : iFrame.
Hint Extern 3 (envs_entails _ ?P) => is_evar P; iAccu. Hint Extern 3 (envs_entails _ ?P) => is_evar P; iAccu.
Hint Extern 3 (envs_entails _ (?P _)) => is_evar P; iAccu. Hint Extern 3 (envs_entails _ (?P _)) => is_evar P; iAccu.
Hint Extern 0 (envs_entails _ (\[_] \* _)) => iSplitR. Hint Extern 0 (envs_entails _ (\[_] \* _)) => iSplitR.
Hint Extern 0 (envs_entails _ (\[_] _)) => iSplitR. Hint Extern 0 (envs_entails _ (\[_] _)) => iSplitR.
Hint Extern 0 (envs_entails _ (_ \* \[_])) => iSplitL. Hint Extern 0 (envs_entails _ (_ \* \[_])) => iSplitL.
Hint Extern 0 (envs_entails _ (_ \[_])) => iSplitL. Hint Extern 0 (envs_entails _ (_ \[_])) => iSplitL.
Hint Extern 0 (envs_entails _ (\[] \* _)) => iSplitR.
Hint Extern 0 (envs_entails _ (\[] _)) => iSplitR.
Hint Extern 0 (envs_entails _ (_ \* \[])) => iSplitL.
Hint Extern 0 (envs_entails _ (_ \[])) => iSplitL.
(** * Specific Proofmode instances about hpure and htop. *) (** * Specific Proofmode instances about hpure and htop. *)
Global Instance htop_absorbing : Absorbing \Top. Global Instance htop_absorbing : Absorbing \Top.
