GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
CHARGUERAUD Arthur
cfml
ec836ce2
ec836ce2
charguer
xfor
193f7455
6
TODO
ec836ce2
@@ -23,8 +23,12 @@ MAJOR TODAY
- for downto
- inline CFHeader.pred as -1
MAJOR NEXT
- xchanges
- record with
- when clauses
@@ -35,6 +39,8 @@ MAJOR NEXT
- open no scope in CF.
- add support for pure records
MAJOR NEXT NEXT
@@ -51,10 +57,6 @@ MAJOR POSTPONED
- support float
=> need type information for normalization
=> how to shared typed/untyped AST
- implement the work around for type abbreviations:
type typerecb1 = | Typerecb_1 of typerecb2
and typerecb2 = typerecb1 list
examples/BasicDemos/Demo.ml
ec836ce2
@@ -48,7 +48,7 @@ let renaming_demo () =
(* ** Return *)
(* ** Return *)
let
ret_unit
x
examples/BasicDemos/Demo_proof.v
ec836ce2
@@ -6,22 +6,36 @@ Require Import Stdlib.
For
loops
a
b
H
Q
tt
a
b
H
I
a
forall
i
I
b
Q
tt
let
for_to_incr
r
let
n
ref
in
for
i
to
pred
r
do
incr
n
done
n
For
loops
Lemma
for_to_incr_spec
forall
r
int
r
app
for_to_incr
r
r
Proof
using
xcf
xapps
unfolds
CFHeader
pred
dup
7.
xfor
intros
S
LS
HS
cuts
PS
forall
i
i
r
S
i
n
i
n
r
applys
PS
math
intros
i
induction_wf
IH
upto
r
i
intros
Li
applys
rm
HS
xif
xapps
applys
IH
hnf
skip
skip
math
xrets
skip
math
xapps
xsimpl
xfor
as
S
skip
skip
xfor_inv
fun
i
int
n
i
skip
skip
skip
skip
xseq
n
r
xfor_inv
fun
i
int
n
i
skip
skip
skip
skip
skip
xseq
n
r
xfor_inv_void
skip
skip
skip
xfor_inv_void
skip
skip
xseq
n
r
xfor_inv_case
fun
i
int
n
i
intros
C
exists
splits
skip
skip
skip
false
skip
math
xapps
xsimpl
Qed
TODO
let
for_downto
r
let
n
ref
in
@@ -29,6 +43,7 @@ let for_downto r =
incr
n
done
n
@@ -701,12 +716,16 @@ Proof using.
xcf
xif
xrets
Qed
Ltac
xauto_tilde
xauto_tilde_default
ltac
fun
_
auto_tilde
Lemma
lazyop_term_spec
app
lazyop_term
tt
Proof
using
xcf
xfun
fun
f
forall
x
int
app
f
x
isTrue
x
xrets
xrets
xapps
xlet
dup
3.
@@ -725,7 +744,7 @@ Lemma lazyop_mixex_spec :
Proof
using
xcf
xfun
fun
f
forall
x
int
app
f
x
isTrue
x
xrets
xrets
xlet
true
xif
xapps
xlet
true
xif
xapps
xlet
true
@@ -804,7 +823,7 @@ Proof using.
dup
2.
k
induction_wf
IH
downto
k
xcf
xif
xrets
xrets
math
xif
xfail
math
xapps
k
@@ -827,7 +846,7 @@ Proof using.
intros
cuts
G
forall
m
int
forall
x
x
m
x
app
rec_mutual_f
x
x
forall
x
x
m
x
app
rec_mutual_g
x
x
split
intros
x
P
specializes
G
x
destruct
G
as
G1
G2
xapp
split
intros
x
P
specializes
G
x
destruct
G
as
G1
G2
xapp
try
math
m
induction_wf
IH
downto
m
split
intros
x
Lx
Px
xcf
xif
xrets
xapp
x
unfolds
skip
TODO
skip
skip
generator/formula_to_coq.ml
ec836ce2
@@ -177,7 +177,30 @@ let rec coqtops_of_imp_cf cf =
funhq
"tag_seq"
coq_exist
"Q'"
wild_to_hprop
coq_conj
c1
c2
(* (!S: fun H Q => exists Q', F1 H Q /\ F2 (Q' tt) Q *)
Cf_for
i_name
v1
v2
cf
Cf_for
i_name
v1
v2
cf
let
s
Coq_var
"S"
in
let
i
Coq_var
i_name
in
let
typs
Coq_impl
coq_int
formula_type
in
let
locals
Coq_app
Coq_var
"CFML.CFHeaps.is_local_pred"
s
in
let
snext
coq_apps
s
coq_plus
i
Coq_int
in
let
cf_step
Cf_seq
cf
Cf_manual
snext
in
let
cf_ret
Cf_ret
coq_tt
in
let
cond
coq_apps
Coq_var
"TLC.LibReflect.isTrue"
coq_le
i
v2
in
let
cf_if
Cf_caseif
cond
cf_step
cf_ret
in
let
bodys
coq_of_cf
cf_if
in
let
hypr
coq_foralls
i_name
coq_int
"H"
hprop
"Q"
Coq_impl
coq_unit
hprop
Coq_impl
coq_apps
bodys
h
q
coq_apps
s
i
h
q
in
funhq
"tag_for"
Coq_forall
"S"
typs
coq_impls
locals
hypr
coq_apps
s
v1
h
q
(* (!For (fun H Q => forall S:int->~~unit, is_local_pred S ->
(forall i H Q,
(If_ i <= v2
Then Seq (F1 ;; S (i+1)) H Q))
Else Ret tt) H Q
-> S i H Q)
-> S v1 H Q) *)
(*--todo:optimize using rec calls *)
(* DEPRECATED
let s = Coq_var "S" in
let i = Coq_var i_name in
let typs = Coq_impl (coq_int,formula_type) in
@@ -192,20 +215,14 @@ let rec coqtops_of_imp_cf cf =
let bodys = coq_conj ple pgt in
let hypr = coq_foralls [(i_name, coq_int); ("H", hprop); ("Q", Coq_impl (coq_unit, hprop))] (Coq_impl (bodys,(coq_apps s [i;h;q]))) in
funhq "tag_for" (Coq_forall (("S",typs), coq_impls [locals; hypr] (coq_apps s [v1;h;q])))
(forall i H Q,
((i <= v2 -> !Seq (fun H Q => exists Q', Q1 H Q' /\ S (i+1) (Q' tt) Q) H Q))
/\ (i > v2 -> !Ret: (fun H Q => H ==> Q tt) H Q) ))
-> S i H Q)
-> S v1 H Q) *)
Cf_while
cf1
cf2
let
r
Coq_var
"R"
in
let
typr
formula_type
in
let
cf
seq
Cf_seq
cf2
Cf_manual
r
in
let
cfret
Cf_ret
coq_tt
in
let
cfif
Cf_caseif
Coq_var
"_c"
cf
seq
cfret
in
let
cf
_step
Cf_seq
cf2
Cf_manual
r
in
let
cf
_
ret
Cf_ret
coq_tt
in
let
cfif
Cf_caseif
Coq_var
"_c"
cf
_step
cf
_
ret
in
let
bodyr
coq_of_cf
Cf_let
"_c"
coq_bool
cf1
cfif
in
let
hypr
coq_foralls
"H"
hprop
"Q"
Coq_impl
coq_unit
hprop
Coq_impl
coq_apps
bodyr
h
q
coq_apps
r
h
q
in
let
localr
Coq_app
Coq_var
"CFML.CFHeaps.is_local"
r
in
lib/coq/CFPrint.v
ec836ce2
@@ -631,10 +631,11 @@ Notation "'LetIf' F0 'Then' F1 'Else' F2" :=
Let
x
F0
in
If_
x
Then
F1
Else
F2
at
level
69
only
parsing
charac
DEPRECATED
Notation
"'IfProp' P 'Then' F1 'Else' F2"
If
fun
H
Q
P
F1
H
Q
P
F2
H
Q
at
level
69
P
at
level
charac
Case
@@ -786,8 +787,7 @@ Notation "'While' F1 'Do' F2 'Done_'" :=
Notation
"'For' i '=' a 'To' b 'Do' F1 'Done_'"
For
fun
H
Q
forall
S
int
unit
CFHeaps
is_local_pred
S
forall
i
H
Q
i
b
Z
F1
S
i
H
Q
i
b
Z
Ret
tt
H
Q
If_
isTrue
i
b
Z
Then
F1
S
i
Else
Ret
tt
H
Q
S
i
H
Q
S
a
H
Q
at
level
69
i
ident
a
at
level
b
at
level
charac
lib/coq/CFTactics.v
ec836ce2
@@ -2021,9 +2021,9 @@ Tactic Notation "xfail" "*" constr(C) :=
forall
H
Q
If_
F1
Then
Seq_
F2
S
Else
Ret
tt
H
Q
S
H
Q
After
xwhile
the
typical
proof
pattern
is
to
generalize
the
goal
calling
assert
forall
X
S
I
X
Q
for
some
predicate
I
then
performing
a
well
founded
induction
on
X
w
r
t
wf
relation
Or
using
xind_skip
to
skip
the
termination
proof
calling
assert
forall
X
S
Hof
X
Qof
X
for
some
predicate
Hof
Qof
then
performing
a
well
founded
induction
on
X
w
r
t
wf
relation
Or
using
xind_skip
to
skip
the
termination
proof
Alternatively
one
can
call
one
of
the
xwhile_inv
tactics
described
below
to
automatically
set
up
the
induction
The
use
of
an
invariant
@@ -2033,7 +2033,7 @@ Tactic Notation "xfail" "*" constr(C) :=
xwhile
is
the
basic
form
described
above
xwhile
as
S
is
equivalent
to
xwhile
intros
S
L
R
HS
xwhile
as
S
is
equivalent
to
xwhile
intros
S
L
S
HS
xwhile_inv
I
R
where
R
is
a
well
founded
relation
on
type
A
then
invariant
I
has
the
form
@@ -2183,118 +2183,146 @@ Tactic Notation "xwhile_inv_basic_skip" constr(I) :=
xfor
xfor
xfor
applies
to
a
goal
of
the
form
For
i
a
To
b
Do
F
H
Q
It
introduces
an
abstract
local
predicate
S
such
that
S
i
denotes
the
behavior
of
the
loop
starting
from
index
i
The
initial
goal
is
S
a
H
Q
An
assumption
is
provided
to
unfold
the
loop
forall
i
H
Q
If_
i
b
Then
Seq_
F
S
i
Else
Ret
tt
H
Q
S
i
H
Q
After
xfor
the
typical
proof
pattern
is
to
generalize
the
goal
calling
assert
forall
X
i
i
b
S
i
Hof
i
X
Qof
i
X
then
performing
an
induction
on
i
Or
using
xind_skip
to
skip
the
termination
proof
Alternatively
one
can
call
one
of
the
xfor_inv
tactics
described
below
to
automatically
set
up
the
induction
The
use
of
an
invariant
makes
the
proof
simpler
but
Forms:
xfor
is
the
basic
form
described
above
xfor
as
S
is
equivalent
to
xwhile
intros
S
LS
HS
xfor_inv
I
specializes
the
goal
for
the
case
a
b
It
requests
to
prove
H
I
a
I
b
Q
forall
i
a
i
b
F
I
i
I
i
for
iterations
Note
that
the
goal
will
not
be
provable
if
a
b
TODO
document
xfor_inv_void
simplifies
the
goal
in
case
the
loops
runs
no
iteration
that
is
when
a
b
Lemma
for_loop_cf_to_inv
forall
I
H
xfor_inv_case
I
provides
two
sub
goals
one
for
the
case
a
b
one
for
the
case
a
b
Lemma
xfor_inv_case_lemma
forall
I
int
hprop
forall
a
int
b
int
F
int
unit
H
Q
unit
hprop
a
b
Z
H
Q
tt
a
b
Z
a
b
exists
H
H
I
a
H
forall
i
a
i
i
b
Z
F
i
I
i
I
i
I
b
Z
H
Q
tt
forall
i
a
i
b
F
i
I
i
I
i
I
b
H
Q
tt
GC
a
b
H
Q
tt
GC
For
i
a
To
b
Do
F
i
Done_
H
Q
Proof
TODO
introv
M1
M2
apply
local_erase
intros
S
LS
HS
tests
C
a
b
apply
rm
HS
split
intros
C
math
xret_no_gc
forwards
Ma
Mb
Mc
rm
M2
math
cuts
P
forall
i
a
i
b
S
i
I
i
I
b
xapply
P
math
hchanges
Ma
hchanges
Mc
intros
i
induction_wf
IH
int_upto_wf
b
i
intros
Bnd
applys
rm
HS
split
intros
C
xseq
eapply
Mb
math
xapply
IH
auto
maths
hsimpl
xret_no_gc
math_rewrite
i
b
tests:
a
b
forwards
H
Ma
Mb
Mc
rm
M1
math
cuts
P
forall
i
a
i
b
S
i
I
i
I
b
xapply
P
math
hchanges
Ma
hchanges
Mc
intros
i
induction_wf
IH
upto
b
i
intros
Hi
applys
rm
HS
xif
xseq
applys
Mb
math
xapply
IH
auto
maths
xsimpl
xret
math_rewrite
i
b
xsimpl
applys
rm
HS
xif
math
xret
applys
M2
math
Qed
Admitted
Lemma
for_loop_cf_to_inv_gen
forall
I
H
forall
a
int
b
int
F
int
unit
H
a
b
Z
H
I
a
H
forall
i
a
i
i
b
Z
F
i
I
i
I
i
a
b
Z
H
I
b
Z
H
For
i
a
To
b
Do
F
i
Done_
H
I
b
Z
H
Proof
intros
applys
for_loop_cf_to_inv
Qed
Lemma
forall
I
H
forall
a
int
b
int
F
int
unit
H
Q
a
b
Z
H
I
a
H
forall
i
a
i
b
Z
F
i
I
i
I
i
a
b
Z
H
I
b
Z
H
I
b
Z
H
Q
For
i
a
To
b
Do
F
i
Done_
H
Q
Lemma
xfor_inv_lemma
forall
I
int
hprop
forall
a
int
b
int
F
int
unit
H
H
a
b
H
I
a
H
forall
i
a
i
b
F
i
I
i
I
i
For
i
a
To
b
Do
F
i
Done_
H
I
b
H
Proof
intros
applys
for_loop_cf_to_inv
intros
C
hchange
H2
C
hchange
H3
tt
hsimpl
introv
ML
MH
MI
applys
xfor_inv_case_lemma
I
intros
C
exists
H
splits
xsimpl
xchange
MH
math_rewrite
a
b
xsimpl
Qed
Lemma
xfor_inv_void_lemma
forall
a
int
b
int
F
int
unit
H
a
b
For
i
a
To
b
Do
F
i
Done_
H
H
Proof
introv
ML
applys
xfor_inv_case_lemma
fun
i
int
intros
C
false
math
xsimpl
Qed
Lemma
for_loop_cf_to_inv_up
forall
I
H
forall
a
int
b
int
F
int
unit
H
Q
unit
hprop
a
b
Z
H
I
a
H
forall
i
a
i
i
b
Z
F
i
I
i
I
i
I
b
Z
H
Q
For
i
a
To
b
Do
F
i
Done_
H
Q
Proof
intros
applys
for_loop_cf_to_inv
intros
math
Qed
Ltac
xfor_intros
tt
let
S
fresh
"S"
in
let
LS
fresh
"L"
S
in
let
HS
fresh
"H"
S
in
apply
local_erase
intros
S
LS
HS
Ltac
xfor_ensure_evar_post
cont
match
cfml_postcondition_is_evar
tt
true
cont
tt
false
xgc_post
cont
tt
Ltac
xfor_pre
cont
xextract_check_not_needed
tt
let
aux
tt
xuntag
tag_for
cont
tt
in
match
cfml_get_tag
tt
tag_seq
xseq
cont
tt
tag_for
cont
tt
tag_for
aux
tt
tag_seq
xseq
aux
tt
instantiate
try
xextract
Ltac
xfor_pre_ensure_evar_post
cont
xfor_pre
ltac
fun
_
ltac
fun
_
cont
tt
Tactic
Notation
"xfor"
xfor_pre
ltac
fun
_
apply
local_erase
Tactic
Notation
"xfor"
"as"
ident
S
xfor_pre
ltac
fun
_
let
LS
fresh
"L"
S
in
let
HS
fresh
"H"
S
in
apply
local_erase
intros
S
LS
HS
Ltac
xfor_inv_case_check_post_instantiated
tt
lazymatch
tt
true
fail
2
"xfor_inv_case requires a post-condition; use [xpost Q] to set it, or [xseq Q] if the loop is behind a Seq."
false
idtac
Ltac
xfor_inv_case_core
I
match
cfml_get_tag
tt
tag_seq
fail
"xfor_inv_case requires a post-condition; use [xseq Q] to assign it."
tag_for
tt
xfor_pre
ltac
fun
_
apply
xfor_inv_case_lemma
I
Tactic
Notation
"xfor"
xfor_pre
ltac
fun
_
xfor_intros
tt
Tactic
Notation
"xfor"
constr
E
xfor_pre
ltac
fun
_
xfor_intros
tt
xgeneralize
E
TODO
document
Ltac
xfor_inv_gen_base
I
i
C
eapply
I
intros
C
intros
i
C
intros
C
apply
rel_le_refl
Tactic
Notation
"xfor_inv_gen"
constr
I
"as"
ident
i
ident
C
xfor_inv_gen_base
I
i
C
Tactic
Notation
"xfor_inv_gen"
constr
I
"as"
ident
i
let
C
fresh
"C"
i
in
xfor_inv_gen
I
as
i
C
Tactic
Notation
"xfor_inv_gen"
constr
I
let
i
fresh
"i"
in
xfor_inv_gen
I
as
i
Ltac
xfor_inv_base
I
i
C
eapply
I
intros
i
C
apply
rel_le_refl
Tactic
Notation
"xfor_inv"
constr
I
"as"
ident
i
ident
C
xfor_inv_gen_base
I
i
C
Tactic
Notation
"xfor_inv"
constr
I
"as"
ident
i
let
C
fresh
"C"
i
in
xfor_inv
I
as
i
C
Tactic
Notation
"xfor_inv_case"
constr
I
xfor_inv_case_core
I
Ltac
xfor_inv_core
I
ltac
fun
_
apply
xfor_inv_lemma
I
Tactic
Notation
"xfor_inv"
constr
I
let
i
fresh
"i"
in
xfor_inv
I
as
i
xfor_inv_core
I
Ltac
xfor_inv_void_core
tt
ltac
fun
_
apply
xfor_inv_void_lemma
Tactic
Notation
"xfor_inv_void"
xfor_inv_void_core
tt
