Commit d9a8fb78 authored by charguer's avatar charguer
demo1
parent 9cadd115
...@@ -8,28 +8,52 @@ Require Import Stdlib. ...@@ -8,28 +8,52 @@ Require Import Stdlib.
Ltac xapply_core H cont1 cont2 ::=
forwards_nounfold_then H ltac:(fun K =>
match cfml_postcondition_is_evar tt with
| true => eapply local_frame; [ xlocal | sapply K | cont1 tt | try xok ]
| false => eapply local_frame_gc; [ xlocal | sapply K | cont1 tt | cont2 tt ]
end).
Lemma max_spec' : forall (n m:int),
app max [n m]
PRE \[]
POST \[= Coq.ZArith.BinInt.Zmax n m ].
Abort.
Lemma max_spec'' : forall (n m:int), (** [xassert] applies to a goal of the form [(Assert F) H Q],
app max [n m] (or, more generally, of the form [(Seq_ (Assert F) ;; F') H Q],
PRE \[] in which case [xseq] is called first.).
RET x ST \[x = Coq.ZArith.BinInt.Zmax n m ].
Abort.
It produces two subgoals: [F H (fun (b:bool) => \[b = true] \* H)]
and [H ==> Q tt]. The second one is discharged automatically
if [Q] is not instantiated---this is the case whenever. *)
Ltac xassert_core tt :=
xuntag tag_assert;
apply local_erase;
split; [ | try xok ].
Ltac xassert_pre cont :=
xextract_check_not_needed tt;
match cfml_get_tag tt with
| tag_assert => cont tt
| tag_seq => xseq; [ cont tt | instantiate ]
end.
Tactic Notation "xassert" :=
xassert_pre ltac:(fun _ => xassert_core tt).
(* ** Type annotations *)
let annot_let () =
let x : int = 3 in x
let annot_tuple_arg () =
(3, ([] : int list))
let annot_pattern_var x =
match (x : int list) with [] -> 1 | _ -> 0
let annot_pattern_constr () =
match ([] : int list) with [] -> 1 | _ -> 0
...@@ -118,8 +142,8 @@ Proof using. ...@@ -118,8 +142,8 @@ Proof using.
{ xapp3. } { xapp3. }
dup 4. dup 4.
{ xseq. xapp. xapp. xsimpl~. } { xseq. xapp. xapp. xsimpl~. }
{ xapp. intro_subst. xapp. xsimpl~. } { xapp. intro_subst. xapp. }
{ xapps. xapps. xsimpl~. } { xapps. xapps. }
{ xapps. xapps~. } { xapps. xapps~. }
Qed. Qed.
...@@ -150,9 +174,9 @@ Lemma let_val_poly_spec : ...@@ -150,9 +174,9 @@ Lemma let_val_poly_spec :
app let_val_poly [tt] \[] \[= 3]. app let_val_poly [tt] \[] \[= 3].
Proof using. Proof using.
xcf. dup 3. xcf. dup 3.
xval. x ret. xsimpl. auto. { xval. xret. xsimpl. auto. }
xval as r. xrets~. { xval as r. xrets~. }
xvals. xrets~. { xvals. xrets~. }
Qed. Qed.
...@@ -194,12 +218,11 @@ Proof using. ...@@ -194,12 +218,11 @@ Proof using.
{ xapp1. { xapp1.
xapp2. xapp2.
dup 5. dup 5.
{ apply Spec. xret. } { apply Spec. xrets. auto. }
{ xapp3_no_apply. Focus 2. apply S. xret. } { xapp3_no_apply. Focus 2. apply S. xrets. auto. }
{ xapp3_no_simpl. xret. } { xapp3_no_simpl. xrets~. }
{ xapp3. xret. } { xapp3. xrets~. }
{ xapp. xret. xsimpl~. } { xapp. xret. xsimpl~. } }
xsimpl~.
Qed. Qed.
Lemma let_fun_poly_pair_homogeneous_spec : Lemma let_fun_poly_pair_homogeneous_spec :
...@@ -224,10 +247,16 @@ Proof using. ...@@ -224,10 +247,16 @@ Proof using.
xsimpl~. xsimpl~.
Qed. Qed.
let let_fun_in_let () = Lemma let_fun_in_let_spec :
let f = (assert (true); fun x -> x) in app let_fun_in_let [tt] \[]
f (fun g => \[ forall A (x:A), app g [x] \[] \[= x] ]).
Proof using.
xcf. xlet (fun g => \[ forall A (x:A), app g [x] \[] \[= x] ]).
(* TODO: could we get away by typing just [xlet] above? *)
{ xassert. { xret. }
xfun. xrets. =>>. xapp. xrets~. }
{ =>> M. xrets~. }
Qed.
...@@ -237,7 +266,7 @@ Lemma let_term_nested_id_calls_spec : ...@@ -237,7 +266,7 @@ Lemma let_term_nested_id_calls_spec :
app let_term_nested_id_calls [tt] \[] \[= 2]. app let_term_nested_id_calls [tt] \[] \[= 2].
xcf. xcf.
xfun (fun f => forall (x:int), app f [x] \[] \[= x]). { xret~. } xfun (fun f => forall (x:int), app f [x] \[] \[= x]). { xrets~. }
xapps. xapps.
xapps. xapps.
xapps. xapps.
...@@ -248,7 +277,7 @@ Lemma let_term_nested_pairs_calls_spec : ...@@ -248,7 +277,7 @@ Lemma let_term_nested_pairs_calls_spec :
app let_term_nested_pairs_calls [tt] \[] \[= ((1,2),(3,(4,5))) ]. app let_term_nested_pairs_calls [tt] \[] \[= ((1,2),(3,(4,5))) ].
xcf. xcf.
xfun (fun f => forall A B (x:A) (y:B), app f [x y] \[] \[= (x,y)]). { xret~. } xfun (fun f => forall A B (x:A) (y:B), app f [x y] \[] \[= (x,y)]). { xrets~. }
xapps. xapps.
xapps. xapps.
xapps. xapps.
...@@ -268,7 +297,7 @@ Proof using. ...@@ -268,7 +297,7 @@ Proof using.
{ xmatch_no_alias. xalias. xalias as L. skip. } { xmatch_no_alias. xalias. xalias as L. skip. }
{ xmatch_no_cases. dup 6. { xmatch_no_cases. dup 6.
{ xmatch_case. { xmatch_case.
{ xrets~. } { xrets*. }
{ xmatch_case. } } { xmatch_case. } }
{ xcase_no_simpl. { xcase_no_simpl.
{ dup 3. { dup 3.
...@@ -294,11 +323,11 @@ Lemma match_nested_spec : ...@@ -294,11 +323,11 @@ Lemma match_nested_spec :
xcf. xval. dup 3. xcf. xval. dup 3.
{ xmatch_no_simpl. { xmatch_no_simpl.
{ false. (* note: [xrets] would produce a ununified [hprop]. { false. (* note: [xrets] would produce a ununified [hprop].
caused by [tryfalse] in [hextract_cleanup]. TODO: avoid this. *) } } caused by [tryfalse] in [hextract_cleanup]. TODO: avoid this. *) } }
{ xmatch. { xmatch.
xrets~. xrets*.
(* second case is killed by [xcase_post] *) } (* second case is killed by [xcase_post] *) }
{ xmatch_no_intros. skip. skip. } { xmatch_no_intros. skip. skip. }
Qed. Qed.
...@@ -847,19 +876,5 @@ let (top_val_pair_fun_1,top_val_pair_fun_2) = (fun x -> x), (fun x -> x) ...@@ -847,19 +876,5 @@ let (top_val_pair_fun_1,top_val_pair_fun_2) = (fun x -> x), (fun x -> x)
let annot_let () =
\ No newline at end of file
...@@ -1463,7 +1463,7 @@ and cfg_module id m = ...@@ -1463,7 +1463,7 @@ and cfg_module id m =
let cfg_file str = let cfg_file str =
[ Cftop_coqs ([ [ Cftop_coqs ([
Coqtop_set_implicit_args; Coqtop_set_implicit_args;
Coqtop_require [ "Coq.ZArith.BinInt"; "LibLogic"; "LibRelation"; "LibInt"; "Shared"; "CFHeaps"; "CFApp" ]; Coqtop_require [ "Coq.ZArith.BinInt"; "TLC.LibLogic"; "TLC.LibRelation"; "TLC.LibInt"; "TLC.LibListZ"; "CFML.Shared"; "CFML.CFHeaps"; "CFML.CFApp" ];
Coqtop_require_import ["CFHeader"]; Coqtop_require_import ["CFHeader"];
Coqtop_require ["CFPrint"]; Coqtop_require ["CFPrint"];
Coqtop_custom "Open Scope list_scope."; Coqtop_custom "Open Scope list_scope.";
...@@ -1574,14 +1574,26 @@ Tactic Notation "xfun_ind" constr(R) constr(S) := ...@@ -1574,14 +1574,26 @@ Tactic Notation "xfun_ind" constr(R) constr(S) :=
(* ** [xret] and [xret_no_gc] and [xrets] *) (* ** [xret] and [xret_no_gc] and [xrets] *)
(** [xret] applies to a goal of the form [(Ret v) H Q]. (** [xret] applies to a goal of the form [(Ret v) H Q],
(or, more generally, on goals of the from
[(Let x := (Ret V) in F) H Q] in which case
[xlet] is called first).
It changes the goal to [H ==> Q v \* \GC], It changes the goal to [H ==> Q v \* \GC],
where [\GC] can be instantiated with garbage. where [\GC] can be instantiated with garbage.
Use [xret_no_gc] to only produce the goal [H ==> Q v]. Use [xret_no_gc] to only produce the goal [H ==> Q v].
[xret] automatically calls [xclean]. Note that [xret] automatically calls [xclean].
[xret_no_clean] may be used to disable [xclean]. *)
Variants:
- [xret_no_clean] may be used to disable [xclean].
- [xret_no_gc] can be used to not introduce an existentially-
quantified heap for garbage collection.
- [xrets] is short for [xret; xsimpl].
(* Lemma used by [xret] *) (* Lemma used by [xret] *)
...@@ -1613,11 +1625,11 @@ Proof using. ...@@ -1613,11 +1625,11 @@ Proof using.
Qed. Qed.
Ltac xret_core := Ltac xret_core tt :=
first [ apply xret_lemma_unify first [ apply xret_lemma_unify
| eapply xret_lemma ]. | eapply xret_lemma ].
Ltac xret_no_gc_core := Ltac xret_no_gc_core tt :=
| eapply xret_no_gc_lemma ]. | eapply xret_no_gc_lemma ].
...@@ -1636,28 +1648,22 @@ Ltac xret_pre cont := ...@@ -1636,28 +1648,22 @@ Ltac xret_pre cont :=
end. *) end. *)
Tactic Notation "xret_no_clean" := Tactic Notation "xret_no_clean" :=
xret_pre ltac:(fun _ => xret_core). xret_pre ltac:(fun _ => xret_core tt).
Tactic Notation "xret" := Tactic Notation "xret" :=
xret_pre ltac:(fun _ => xret_core; xclean). xret_pre ltac:(fun _ => xret_core tt; xclean).
Tactic Notation "xret" "~" := Tactic Notation "xret" "~" :=
xret; xauto~. xret; xauto~.
Tactic Notation "xret" "*" := Tactic Notation "xret" "*" :=
xret; xauto*. xret; xauto*.
(** [xret_no_gc] can be used to not introduce an existentially-
quantified heap for garbage collection. *)
Tactic Notation "xret_no_gc" := Tactic Notation "xret_no_gc" :=
xret_no_gc_core. xret_no_gc_core tt.
Tactic Notation "xret_no_gc" "~" := Tactic Notation "xret_no_gc" "~" :=
xret_no_gc; xauto~. xret_no_gc; xauto~.
Tactic Notation "xret_no_gc" "*" := Tactic Notation "xret_no_gc" "*" :=
xret_no_gc; xauto*. xret_no_gc; xauto*.
(** [xrets] is short for [xret; xsimpl].*)
Ltac xrets_base := Ltac xrets_base :=
xret; xsimpl. xret; xsimpl.
...@@ -102,6 +102,8 @@ Pervasives.cmj: Pervasives.ml $(CFML_MLV) ...@@ -102,6 +102,8 @@ Pervasives.cmj: Pervasives.ml $(CFML_MLV)
Array_ml.vo List_ml.vo: Pervasives_ml.vo Array_ml.vo List_ml.vo: Pervasives_ml.vo
Array_ml.vio List_ml.vio: Pervasives_ml.vio Array_ml.vio List_ml.vio: Pervasives_ml.vio
Stdlib.vo: Array_ml.vo List_ml.vo Pervasives_ml.vo
Stdlib.vio: Array_ml.vio List_ml.vio Pervasives_ml.vio
%_ml.vo: %.cmj %_ml.vo: %.cmj
# Needed only when developing CFML. Ideally, should be removed. # Needed only when developing CFML. Ideally, should be removed.
