GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
CHARGUERAUD Arthur
cfml
9ded32ff
9ded32ff
POTTIER Francois
Redefine [parens] using [block]. Extract global parameters.
916af86d
generator/print_coq.ml
9ded32ff
@@ -3,6 +3,16 @@ open Coq
(* Global parameters. *)
let
indentation
2
let
width
80
(* Various fixed elements. *)
let
arrow
@@ -30,7 +40,7 @@ let quote =
let
app
d1
d2
(* The following definition would reject a large argument on a line of
its own, indented: *)
(* group (d1 ^^ nest
2
(break 1 ^^ d2)) *)
indentation
(break 1 ^^ d2)) *)
(* However, that would be redundant with the fact that large arguments
are usually parenthesized, and we already break lines and indent
within the parentheses. So, the following suffices: *)
@@ -50,6 +60,9 @@ let apps ds =
let
block
n
opening
contents
closing
group
opening
nest
n
contents
closing
let
block
block
indentation
(* Parentheses with indentation. *)
@@ -58,10 +71,10 @@ let block n opening contents closing =
opening and closing parentheses alone on a line and indenting the content. *)
let
parens
d
group
nest
2
lparen
break
d
break
rparen
block
lparen
break
d
break
rparen
@@ -136,21 +149,21 @@ and expr2 = function
expr3
function
Coq_lettuple
es
e1
e2
block
2
block
string
"let '"
tuple
expr
es
colonequals
break
expr
e1
break
within
expr3
e2
Coq_forall
x
e1
e2
block
2
block
string
"forall "
string
x
colon
break
expr
e1
comma
empty
expr3
e2
Coq_fun
x
e1
e2
block
2
block
string
"fun"
space
string
x
colon
break
expr
e1
break
doublearrow
@@ -166,7 +179,6 @@ and expr e =
let
expr
e
string
let
b
Buffer
create
1024
in
PPrintEngine
ToBuffer
pretty
80
b
expr
e
PPrintEngine
ToBuffer
pretty
width
b
expr
e
Buffer
contents
b
(* TEMPORARY allow choosing the width *)
