Commit 6b4a743c authored by charguer's avatar charguer
compile 8.5rc1 but not examples
parent 5773f39d
(* open Aux (* required for cfml to do the require in Coq, in the current implementation *) *) open Aux (* required for cfml to do the require in Coq, in the current implementation *)
open NullPointers open NullPointers
EXAMPLE_DIRS=\ EXAMPLE_DIRS=\
DemoMake \ DemoMake \
Compose \ Compose \
Memoization \ Memoization \
CPSappend \ CPSappend \
...@@ -11,6 +11,7 @@ EXAMPLE_DIRS=\ ...@@ -11,6 +11,7 @@ EXAMPLE_DIRS=\
SelfBalancedHeap \ SelfBalancedHeap \
BinaryTrees BinaryTrees
# Dijkstra # Dijkstra
# FingerTree \ # FingerTree \
# Sieve \ # Sieve \
...@@ -29,7 +29,10 @@ Proof. apply (Build_Rep eq). congruence. Defined. ...@@ -29,7 +29,10 @@ Proof. apply (Build_Rep eq). congruence. Defined.
Instance list_rep : forall `{Rep a A}, Rep (list a) (list A). Instance list_rep : forall `{Rep a A}, Rep (list a) (list A).
Proof. Proof.
intros. apply (Build_Rep (fun l L => Forall2 rep l L)). intros. apply (Build_Rep (fun l L => Forall2 rep l L)).
induction x; introv H1 H2; inverts H1; inverts H2; prove_rep. admit.
(* TODO: coqbug in 8.5rc1
Defined. Defined.
Lemma list_rep_cons : forall `{Rep a A} l L x X, Lemma list_rep_cons : forall `{Rep a A} l L x X,
...@@ -53,7 +56,10 @@ Proof. ...@@ -53,7 +56,10 @@ Proof.
| None, None => True | None, None => True
| Some x, Some X => rep x X | Some x, Some X => rep x X
| _,_ => False end)). | _,_ => False end)).
admit.
intros [x|] [X|] [Y|] H1 H2; prove_rep. intros [x|] [X|] [Y|] H1 H2; prove_rep.
Defined. Defined.
Hint Extern 1 (@rep (list _) _ _ _ _) => simpl. Hint Extern 1 (@rep (list _) _ _ _ _) => simpl.
...@@ -201,9 +201,9 @@ Proof. auto. Qed. ...@@ -201,9 +201,9 @@ Proof. auto. Qed.
(* ** tools for post-conditions *) (* ** tools for post-conditions *)
Ltac is_evar_as_bool E := Ltac is_evar_as_bool E :=
constr:($(first constr:(ltac:(first
[ is_evar E; exact true [ is_evar E; exact true
| exact false ])$). | exact false ])).
Ltac get_post tt := Ltac get_post tt :=
match goal with |- ?E => match goal with |- ?E =>
