Commit 0a94e6be authored by Armaël Guéneau's avatar Armaël Guéneau
Merge branch 'coq-fixes' into 'master'
Make CFML work with coq 8.6.1 and newer
See merge request !4
parents e7e1c856 fd3a3137
......@@ -19,18 +19,15 @@ CFML consists of two parts:
Installation
The current version of CFML requires Coq 8.6 (*not* 8.6.1).
The current version of CFML requires Coq 8.6 or newer.
The simplest way of installing the *latest released version* of CFML is via `opam`.
It is recommended to create a new switch, whose name you can choose;
in the following, we use `cfml86`.
```sh
opam switch cfml86 -A 4.05.0
eval `opam config env`
opam install -j4 coq.8.6
opam install -j4 coq-cfml
# This only needs to be done once, to add the opam repository with coq packages
opam repo add coq-released https://coq.inria.fr/opam/released
opam install coq-cfml
If instead you wish to use *the development version* of CFML,
......@@ -1923,16 +1923,16 @@ Ltac hsimpl_try_same tt :=
Ltac hsimpl_find_same H HL :=
match HL with
| H \* _ => apply hsimpl_cancel_1
| _ \* H \* _ => apply hsimpl_cancel_2
| _ \* _ \* H \* _ => apply hsimpl_cancel_3
| _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_4
| _ \* _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_5
| _ \* _ \* _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_6
| _ \* _ \* _ \* _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_7
| _ \* _ \* _ \* _ \* _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_8
| _ \* _ \* _ \* _ \* _ \* _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_9
| _ \* _ \* _ \* _ \* _ \* _ \* _ \* _ \* _ \* H \* _ => apply hsimpl_cancel_10
| ?H' \* _ => unify H H'; apply hsimpl_cancel_1
| _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_2
| _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_3
| _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_4
| _ \* _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_5
| _ \* _ \* _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_6
| _ \* _ \* _ \* _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_7
| _ \* _ \* _ \* _ \* _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_8
| _ \* _ \* _ \* _ \* _ \* _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_9
| _ \* _ \* _ \* _ \* _ \* _ \* _ \* _ \* _ \* ?H' \* _ => unify H H'; apply hsimpl_cancel_10
end.
Ltac hsimpl_find_data l HL cont :=
......@@ -2421,7 +2421,7 @@ Lemma Group_add : forall a (x:a) A `{Inhab A} (M:map a A) (G:htype A a) X,
Heapdata G ->
Group G M \* (x ~> G X) ==> Group G (M[x:=X]).
Proof using.
intros. hchange~ Group_add_fresh. hsimpl. hsimpl.
Qed.
(* LATER: prove reciprocal to Group_add
......@@ -2575,7 +2575,7 @@ Proof using.
rewrite star_assoc. exists~ h1 h2.
auto.
intros x. hchange (Qle' x). hchange~ (Qle x).
set (H' := \GC) at 1 2. hsimpl; subst H'; affine.
hchange (@hsimpl_gc (\GC \* \GC)). affine. hsimpl.
apply~ local_erase.
Qed.
......@@ -109,7 +109,7 @@ Proof using.
=>> M. xapp~ (fun k => Hexists r, \[l = k ++ r] \* I r).
{ =>> E. xpull ;=> r' E'. subst l.
lets: app_cancel_l E'. subst r'.
xapp. xsimpl~. xsimpl~. }
xapp. xsimpl~. }
{ xpull ;=>> E. rewrites (>> self_eq_app_l_inv E). xsimpl~. }
Qed. (* TODO: beautify this proof *)
......@@ -14,6 +14,6 @@ remove: [make "uninstall"]
depends: [
"ocamlbuild" {build}
"pprint"
"coq" {= "8.6"}
"coq" {>= "8.6"}
"coq-tlc" {>= "20161010"}
