Commit cc1c727a authored by camille garcin's avatar camille garcin
adding csv mapping and updating README
parent dd515664
...@@ -12,6 +12,10 @@ conda env create -f plantnet_env.yml ...@@ -12,6 +12,10 @@ conda env create -f plantnet_env.yml
conda activate plantnet_env conda activate plantnet_env
## Species names
The correspondence between the species id and the species names can be found in the csv file class_names.csv
## Downloading the dataset ## Downloading the dataset
To donwload the dataset, run : To donwload the dataset, run :
...@@ -19,4 +23,11 @@ To donwload the dataset, run : ...@@ -19,4 +23,11 @@ To donwload the dataset, run :
python dl_plantnet.py --root=your_path --num_workers=4 python dl_plantnet.py --root=your_path --num_workers=4
where your_path is the path where you want to save the dataset and num_workers represents the number of threads to use to donwload the dataset where your_path is the path where you want to save the dataset and num_workers represents the number of threads to use to donwload the dataset.
If for some reason your download is interrupted, you can run :
```bash
python resume_dl.py
This diff is collapsed.
