GitLab
Support
Community forum
Keyboard shortcuts
lib3dmol
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Analytics
Analytics
Value Stream
Capsid.crates
lib3dmol
09450558
NOEL Philippe
Add doc in atom
98da9fc3
6
6 changed files
43 additions
20 deletions
+43
-20
src/main.rs
src/main.rs
+2
-2
src/pdb/atom.rs
src/pdb/atom.rs
+8
-5
src/pdb/protein.rs
src/pdb/protein.rs
+1
-1
src/pdb/read_pdb.rs
src/pdb/read_pdb.rs
+9
-8
src/pdb/residue.rs
src/pdb/residue.rs
+7
tests/test.rs
tests/test.rs
+16
-4
src/main.rs
09450558
@@ -8,7 +8,7 @@ fn main() {
println!
"Prot : {}
\n
n chain: {}
\n
n res: {}
\n
n atom: {}"
my_prot
.name
my_prot
.get_number_chain
my_prot
.get_number_residue
my_prot
.get_number_atom
println!
"Reduce protein"
let
chain
A
my_prot
.select_atoms
"chain a"
.unwrap
println!
"Prot : {}
\n
n chain: {}
\n
n res: {}
\n
n atom: {}"
chain
A
.name
chainA
.get_number_chain
chainA
.get_number_residue
chainA
.get_number_atom
let
chain
_a
my_prot
.select_atoms
"chain a"
.unwrap
println!
"Prot : {}
\n
n chain: {}
\n
n res: {}
\n
n atom: {}"
chain
_a
.name
chain_a
.get_number_chain
chainA
.get_number_residue
chainA
.get_number_atom
src/pdb/atom.rs
09450558
@@ -17,6 +17,7 @@ pub struct Atom {
impl
Atom
/// Create a new structure Atom. An atom have a name, a number and x, y, z coordinates
/// If the atom name is "C", "CA", "N", "O", "OT1" or "OT2", it will be consider as backbone
/// # Examples
@@ -28,11 +29,7 @@ impl Atom {
pub
fn
new
name
String
number
u64
coord
f32
3
Atom
let
n
name
.deref
let
back
if
n
"C"
n
"CA"
n
"N"
n
"O"
n
"OT1"
n
"OT2"
true
else
false
let
back
n
"C"
n
"CA"
n
"N"
n
"O"
n
"OT1"
n
"OT2"
Atom
name
number
@@ -41,6 +38,12 @@ impl Atom {
/// Get the name of the atom
pub
fn
name
self
String
self
.name
.clone
/// Compute the distance between 2 Atoms
/// # Examples
src/pdb/protein.rs
09450558
@@ -286,7 +286,7 @@ impl<'a> Protein {
// ex: don't parse the chain if it's not selected
pub
fn
select_atoms
self
pattern
str
Option
Protein
let
mut
n_prot
Protein
new
String
from
self
.name
.clone
let
mut
n_prot
Protein
new
self
.name
.clone
let
select
match
selection_atom
parse_select
pattern
Some
x
x
src/pdb/read_pdb.rs
09450558
@@ -12,7 +12,7 @@ use super::protein::Protein;
/// # Errors
/// Will return 0.0 if the String cannot be convert and print the error
fn
parse_float
s
String
f32
fn
parse_float
s
str
f32
match
s
.trim
.parse
f32
Ok
n
n
Err
e
@@ -30,15 +30,15 @@ fn parse_float(s: &String) -> f32 {
/// # Errors
/// Will return 0 if the String cannot be convert and print the error
fn
parse_int
s
String
i64
fn
parse_int
s
str
i64
match
s
.trim
.parse
i64
Ok
n
n
Err
e
match
i64
from_str_radix
s
.trim
16
Ok
n
return
n
Ok
n
n
Err
_
println!
e
return
@@ -79,7 +79,7 @@ pub fn parse_pdb(pdb: &str, name: &str) -> Protein {
let
l
line
.unwrap
if
l
.starts_with
"HETAM"
l
.starts_with
"ATOM"
let
atom_name
l
12
17
.trim
.to_string
let
residue_name
l
17
20
.trim
.to_string
let
residue_name
l
17
20
.trim
let
chain
l
21
22
.chars
.next
.unwrap
let
atom_number
parse_int
l
6
11
.to_string
let
residue_number
parse_int
l
22
26
.to_string
@@ -87,14 +87,15 @@ pub fn parse_pdb(pdb: &str, name: &str) -> Protein {
let
y
parse_float
l
38
46
.to_string
let
z
parse_float
l
46
54
.to_string
if
is_protein_res
residue_name
lst_res
protein
.update_protein
chain
residue_name
clone
residue_number
as
u64
atom_name
.clone
atom_number
as
u64
x
y
z
protein
.update_protein
chain
residue_name
to_string
residue_number
as
u64
atom_name
.clone
atom_number
as
u64
x
y
z
protein
fn
is_protein_res
r
str
lst
Vec
str
bool
/// Test if the selected line is a residue
fn
is_protein_res
r
str
lst
str
bool
let
r
r
.to_uppercase
src/pdb/residue.rs
09450558
@@ -34,7 +34,14 @@ impl Residue {
/// Get the name of the residue
pub
fn
name
self
String
self
.name
.clone
/// Get the number of the residue
pub
fn
get_res_num
self
u64
self
.res_num
tests/test.rs
09450558
@@ -2,8 +2,8 @@ extern crate pdbparser;
#[test]
fn
parse_f2
use
pdbparser
let
my_prot
pdbparser
parse_pdb
"tests/tests_file/f2.pdb"
"f2"
assert_eq!
"f2"
my_prot
.name
assert_eq!
my_prot
.get_number_chain
assert_eq!
66
my_prot
.get_number_residue
assert_eq!
1085
my_prot
.get_number_atom
@@ -11,7 +11,6 @@ fn parse_f2() {
#[test]
fn
parse_f2_adn
use
pdbparser
let
my_prot
pdbparser
parse_pdb
"tests/tests_file/f2_adn.pdb"
"f2"
assert_eq!
my_prot
.get_number_chain
assert_eq!
66
my_prot
.get_number_residue
@@ -20,7 +19,6 @@ fn parse_f2_adn() {
#[test]
fn
parse_trp
use
pdbparser
let
my_prot
pdbparser
parse_pdb
"tests/tests_file/trp_MD.pdb"
"trp"
assert_eq!
my_prot
.get_number_chain
assert_eq!
704
my_prot
.get_number_residue
@@ -29,9 +27,23 @@ fn parse_trp() {
#[test]
fn
parse_5jpq
use
pdbparser
let
my_prot
pdbparser
parse_pdb
"tests/tests_file/5jpq.pdb"
"5jpq"
assert_eq!
35
my_prot
.get_number_chain
assert_eq!
8173
my_prot
.get_number_residue
assert_eq!
44801
my_prot
.get_number_atom
#[test]
fn
f2_res
let
mut
my_prot
pdbparser
parse_pdb
"f2"
let
chain_a
my_prot
.get_chain_ref
'A'
.unwrap
let
res
chain_A
.get_residue_ref
.unwrap
assert_eq!
"THR"
res
.name
let
res
chain_A
.get_residue_ref
2
.unwrap
assert_eq!
"SER"
res
.name
let
res
chain_A
.get_residue_ref
chain_A
.get_number_residue
.unwrap
assert_eq!
"HSD"
res
.name
\ No newline at end of file
