Commit a570c135 authored by Emmanuel Thomé's avatar Emmanuel Thomé
typo
parent 13df288d
...@@ -551,7 +551,7 @@ big: 158G and 2.3TB, respectively. ...@@ -551,7 +551,7 @@ big: 158G and 2.3TB, respectively.
Once this precomputation is done, the two big files can be used as Once this precomputation is done, the two big files can be used as
drop-in replacements to the corresponding files in the drop-in replacements to the corresponding files in the
`reconstructlog-dl` command lines, and the program completes in about two `reconstructlog-dl` command line, and the program completes in about two
days. days.
## Reproducing the individual logarithm result ## Reproducing the individual logarithm result
Supports Markdown
