Commit b4494884 authored by Swergas's avatar Swergas
edit DOM of edition of question answers page, to better target the remove button
parent 3923c0f9
...@@ -85,6 +85,7 @@ let extractTemplate () = ...@@ -85,6 +85,7 @@ let extractTemplate () =
let rec createAnswer a = let rec createAnswer a =
let container = Dom_html.createDiv document in let container = Dom_html.createDiv document in
container##.className := Js.string "question_answer_item";
let t = document##createTextNode (Js.string "Answer: ") in let t = document##createTextNode (Js.string "Answer: ") in
let u = Dom_html.createInput document in let u = Dom_html.createInput document in
u##.className := Js.string "question_answer"; u##.className := Js.string "question_answer";
...@@ -100,6 +101,7 @@ let rec createAnswer a = ...@@ -100,6 +101,7 @@ let rec createAnswer a =
return () return ()
in in
btn##.onclick := handler f; btn##.onclick := handler f;
btn##.className := Js.string "btn_remove";
Dom.appendChild btn btn_text; Dom.appendChild btn btn_text;
Dom.appendChild container btn; Dom.appendChild container btn;
let insert_text = document##createTextNode (Js.string "Insert") in let insert_text = document##createTextNode (Js.string "Insert") in
...@@ -111,6 +113,7 @@ let rec createAnswer a = ...@@ -111,6 +113,7 @@ let rec createAnswer a =
return () return ()
in in
insert_btn##.onclick := handler f; insert_btn##.onclick := handler f;
insert_btn##.className := Js.string "btn_insert";
Dom.appendChild insert_btn insert_text; Dom.appendChild insert_btn insert_text;
Dom.appendChild container insert_btn; Dom.appendChild container insert_btn;
container container
...@@ -475,7 +475,7 @@ def administrator_edits_election_questions(browser): ...@@ -475,7 +475,7 @@ def administrator_edits_election_questions(browser):
# She removes answer 3 # She removes answer 3
question_to_remove = 3 question_to_remove = 3
remove_button_css_selector = ".question_answers > div:nth-child(" + str(question_to_remove) + ") button:nth-child(2)" remove_button_css_selector = ".question_answer_item:nth-child(" + str(question_to_remove) + ") .btn_remove"
remove_button_element = browser.find_element_by_css_selector(remove_button_css_selector) remove_button_element = browser.find_element_by_css_selector(remove_button_css_selector)
remove_button_element.click() remove_button_element.click()
