Commit fefc7315 authored by Stephane Glondu's avatar Stephane Glondu
Move election service handlers to Web_site
parent f2cadfe4
...@@ -32,22 +32,6 @@ open Web_services ...@@ -32,22 +32,6 @@ open Web_services
let ( / ) = Filename.concat let ( / ) = Filename.concat
let can_read m user =
match m.e_readers with
| None -> false
| Some acl ->
match user with
| None -> acl = `Any (* readers can be anonymous *)
| Some u -> check_acl (Some acl) u
let can_vote m user =
match m.e_voters with
| None -> false
| Some acl ->
match user with
| None -> false (* voters must log in *)
module type REGISTRATION = sig module type REGISTRATION = sig
module W : WEB_ELECTION_ module W : WEB_ELECTION_
module Register (X : EMPTY) : ELECTION_HANDLERS module Register (X : EMPTY) : ELECTION_HANDLERS
...@@ -289,246 +273,3 @@ module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE = struct ...@@ -289,246 +273,3 @@ module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE = struct
end end
end end
open Eliom_registration
let login w service () =
let module W = (val w : WEB_ELECTION) in
lwt cont = Eliom_reference.get Web_services.cont in
W.Auth.Handlers.login service cont ()
let logout w () () =
W.Auth.Handlers.logout cont ()
module T = Web_templates
let if_eligible w acl f () x =
lwt user = W.Auth.Services.get_user () in
if acl W.metadata user then
f user x
else
forbidden ()
let home w =
let uuid = Uuidm.to_string W.election.e_params.e_uuid in
(if_eligible w can_read
(fun user () ->
Eliom_reference.unset W.Z.ballot >>
let cont () () =
Redirection.send
(Eliom_service.preapply
election_home (W.election.e_params.e_uuid, ()))
in
Eliom_reference.set Web_services.cont cont >>
match_lwt Eliom_reference.get W.Z.cast_confirmed with
| Some result ->
Eliom_reference.unset W.Z.cast_confirmed >>
T.cast_confirmed (module W) ~result () >>= Html5.send
| None ->
lwt state = Web_persist.get_election_state uuid in
T.election_home (module W) state () >>= Html5.send
let admin w site_user is_featured =
(fun () () ->
match site_user with
| Some u when W.metadata.e_owner = Some u ->
T.election_admin (module W) ~is_featured state (module Web_site_auth : AUTH_SERVICES) () >>= Html5.send
| _ -> forbidden ()
let content_type_of_file = function
| ESRaw | ESKeys | ESBallots -> "application/json"
| ESCreds | ESRecords -> "text/plain"
let handle_pseudo_file w u f site_user =
lwt () =
if f = ESRecords then (
| Some u when W.metadata.e_owner = Some u -> return ()
| _ -> forbidden ()
) else return ()
in
let content_type = content_type_of_file f in
File.send ~content_type (W.dir / string_of_election_file f)
let election_dir w site_user =
(fun f () ->
let cont () () =
Redirection.send
election_dir
(W.election.e_params.e_uuid, f))
in
handle_pseudo_file w () f site_user
let election_update_credential w site_user =
(fun () () ->
| Some u ->
if W.metadata.e_owner = Some u then (
T.update_credential (module W) (module Web_site_auth : AUTH_SERVICES) () >>= Html5.send
) else (
forbidden ()
| _ -> forbidden ()
let election_update_credential_post w site_user =
(fun () (old, new_) ->
| Some u ->
try_lwt
W.B.update_cred ~old ~new_ >>
String.send ("OK", "text/plain")
with Error e ->
String.send ("Error: " ^ explain_error e, "text/plain")
) >>= (fun x -> return @@ cast_unknown_content_kind x)
else (
forbidden ()
| _ -> forbidden ()
let election_vote w =
(fun user () ->
let cont () () =
Redirection.send
election_vote (W.election.e_params.e_uuid, ()))
in
let uuid_s = Uuidm.to_string W.election.e_params.e_uuid in
Redirection.send
(Eliom_service.static_dir_with_params
~get_params:(Eliom_parameter.string "election_url") ())
(["static"; "vote.html"],
"../elections/" ^ uuid_s ^ "/"))
let election_cast_confirm w () () =
match_lwt Eliom_reference.get W.Z.ballot with
| Some the_ballot ->
begin
match_lwt W.Auth.Services.get_user () with
| Some u ->
let b = check_acl W.metadata.e_voters u in
if b then (
let record = string_of_user u, now () in
lwt result =
try_lwt
lwt hash = W.B.cast the_ballot record in
return (`Valid hash)
with Error e -> return (`Error e)
in
Eliom_reference.set W.Z.cast_confirmed (Some result) >>
Redirection.send
) else forbidden ()
| None -> forbidden ()
| None -> fail_http 404
let ballot_received w user hash =
let can_vote = can_vote W.metadata user in
T.cast_confirmation (module W) ~can_vote hash ()
let election_cast w =
(fun user () ->
let cont () () =
Redirection.send
election_cast (W.election.e_params.e_uuid, ()))
in
| Some b -> ballot_received w user (sha256_b64 b) >>= Html5.send
| None -> T.cast_raw (module W) () >>= Html5.send
let election_cast_post w =
(fun user (ballot_raw, ballot_file) ->
lwt the_ballot = match ballot_raw, ballot_file with
| Some ballot, None -> return ballot
| None, Some fi ->
let fname = fi.Ocsigen_extensions.tmp_filename in
Lwt_stream.to_string (Lwt_io.chars_of_file fname)
| _, _ -> fail_http 400
in
let cont () () =
Redirection.send
Web_services.election_cast (W.election.e_params.e_uuid, ()))
in
Eliom_reference.set W.Z.ballot (Some the_ballot) >>
match user with
| None ->
Redirection.send
Web_services.election_login
((W.election.e_params.e_uuid, ()), None))
| Some u -> cont () ()
let election_pretty_ballots w start () =
if can_read W.metadata user then (
lwt res, _ =
W.B.Ballots.fold
(fun h _ (accu, i) ->
if i >= start && i < start+50 then
return (h :: accu, i+1)
else return (accu, i+1)
) ([], 1)
in T.pretty_ballots (module W) res () >>= Html5.send
) else forbidden ()
let election_pretty_ballot w hash () =
lwt ballot =
W.B.Ballots.fold
(fun h b accu ->
if h = hash then return (Some b) else return accu
) None
in
match ballot with
| Some b ->
String.send (b, "application/json") >>=
) else forbidden ()
...@@ -40,17 +40,3 @@ module type REGISTRABLE = sig ...@@ -40,17 +40,3 @@ module type REGISTRABLE = sig
end end
module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE
val login : (module WEB_ELECTION) -> string option -> unit -> content
val logout : (module WEB_ELECTION) -> unit -> unit -> content
val home : (module WEB_ELECTION) -> unit -> unit -> content
val admin : (module WEB_ELECTION) -> user option -> bool -> unit -> unit -> content
val election_dir : (module WEB_ELECTION) -> user option -> Web_common.election_file -> unit -> content
val election_update_credential : (module WEB_ELECTION) -> user option -> unit -> unit -> content
val election_update_credential_post : (module WEB_ELECTION) -> user option -> unit -> string * string -> content
val election_vote : (module WEB_ELECTION) -> unit -> unit -> content
val election_cast : (module WEB_ELECTION) -> unit -> unit -> content
val election_cast_post : (module WEB_ELECTION) -> unit -> string option * Eliom_lib.file_info option -> content
val election_cast_confirm : (module WEB_ELECTION) -> unit -> unit -> content
val election_pretty_ballots : (module WEB_ELECTION) -> int -> unit -> content
val election_pretty_ballot : (module WEB_ELECTION) -> string -> unit -> content
...@@ -664,13 +664,56 @@ let () = ...@@ -664,13 +664,56 @@ let () =
end end
| None -> false
| Some acl ->
match user with
| None -> false
| Some acl ->
match user with
f user x
else
forbidden ()
let () = let () =
Any.register Any.register
~service:election_home ~service:election_home
(fun (uuid, ()) () -> (fun (uuid, ()) () ->
let uuid_s = Uuidm.to_string uuid in let uuid_s = Uuidm.to_string uuid in
let w = SMap.find uuid_s !election_table in let w = SMap.find uuid_s !election_table in
Web_election.home w () ()) let module W = (val w : WEB_ELECTION) in
(fun user () ->
let cont () () =
Redirection.send
in
| Some result ->
| None ->
let () = let () =
...@@ -690,9 +733,16 @@ let () = ...@@ -690,9 +733,16 @@ let () =
lwt user = Web_site_auth.get_user () in lwt site_user = Web_site_auth.get_user () in
lwt is_featured = Web_persist.is_featured_election uuid_s in lwt is_featured = Web_persist.is_featured_election uuid_s in
Web_election.admin w user is_featured () ()) let module W = (val w : WEB_ELECTION) in
| _ -> forbidden ()
let () = let () =
...@@ -714,7 +764,9 @@ let () = ...@@ -714,7 +764,9 @@ let () =
(fun ((uuid, ()), service) () -> (fun ((uuid, ()), service) () ->
Web_election.login w service ()) let module W = (val w : WEB_ELECTION) in
W.Auth.Handlers.login service cont ())
let () = let () =
...@@ -722,7 +774,9 @@ let () = ...@@ -722,7 +774,9 @@ let () =
Web_election.logout w () ()) let module W = (val w : WEB_ELECTION) in
W.Auth.Handlers.logout cont ())
let () = let () =
...@@ -730,33 +784,90 @@ let () = ...@@ -730,33 +784,90 @@ let () =
Web_election.election_update_credential w user () ()) let module W = (val w : WEB_ELECTION) in
| Some u ->
) else (
forbidden ()
| _ -> forbidden ())
let () = let () =
~service:election_update_credential_post ~service:election_update_credential_post
(fun (uuid, ()) x -> (fun (uuid, ()) (old, new_) ->
Web_election.election_update_credential_post w user () x) let module W = (val w : WEB_ELECTION) in
| Some u ->
try_lwt
with Error e ->
else (
forbidden ()
| _ -> forbidden ())
let () = let () =
~service:election_vote ~service:election_vote
(fun (uuid, ()) x -> (fun (uuid, ()) () ->
Web_election.election_vote w () x) let module W = (val w : WEB_ELECTION) in
(fun user () ->
let cont () () =
Redirection.send
in
Redirection.send
let () = let () =
~service:election_cast ~service:election_cast
Web_election.election_cast w () x) let module W = (val w : WEB_ELECTION) in
(fun user () ->
let cont () () =
Redirection.send
in
let () = let () =
...@@ -764,15 +875,64 @@ let () = ...@@ -764,15 +875,64 @@ let () =
(fun (uuid, ()) x -> (fun (uuid, ()) x ->
Web_election.election_cast_post w () x) let module W = (val w : WEB_ELECTION) in
| None, Some fi ->
in
let cont () () =
Redirection.send
in
match user with
| None ->
Redirection.send
) () x)
let () = let () =
~service:election_cast_confirm ~service:election_cast_confirm
Web_election.election_cast_confirm w () x) let module W = (val w : WEB_ELECTION) in
| Some the_ballot ->
begin
| Some u ->
if b then (
lwt result =
try_lwt
in
Redirection.send
) else forbidden ()
