GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
belenios
belenios
f9949778
f9949778
Stephane Glondu
In Election, rename combine_factors into compute_result
e96d4387
4
src/lib/election.ml
f9949778
@@ -565,7 +565,7 @@ module MakeElection (G : GROUP) (M : RANDOM) = struct
type
combinator
factor
array
elt
array
array
type
combinator
factor
array
elt
array
array
let
com
bine_factors
num_tallied
encrypted_tally
partial_decryptions
combinator
let
com
pute_result
num_tallied
encrypted_tally
partial_decryptions
combinator
let
factors
combinator
partial_decryptions
in
let
factors
combinator
partial_decryptions
in
let
results
Array
mmap2
fun
beta
_
f
let
results
Array
mmap2
fun
beta
_
f
beta
f
beta
f
src/lib/signatures.mli
f9949778
@@ -225,7 +225,7 @@ module type ELECTION = sig
type
combinator
factor
array
elt
array
array
type
combinator
factor
array
elt
array
array
val
com
bine_factors
int
ciphertext
factor
array
combinator
result
val
com
pute_result
int
ciphertext
factor
array
combinator
result
(** Combine the encrypted tally and the factors from all trustees to
produce the election result. The first argument is the number of
tallied ballots. May raise [Invalid_argument]. *)
src/tool/tool_election.ml
f9949778
@@ -205,7 +205,7 @@ module Make (P : PARSED_PARAMS) : S = struct
KG
combine_factors
KG
combine_factors
Some
t
KP
combine_factors
checker
t
Some
t
KP
combine_factors
checker
t
in
in
let
result
E
com
bine_factors
cardinal
tally
factors
combinator
in
let
result
E
com
pute_result
cardinal
tally
factors
combinator
in
assert
E
check_result
combinator
Lazy
force
pks
result
assert
E
check_result
combinator
Lazy
force
pks
result
string_of_result
G
write
result
string_of_result
G
write
result
src/web/web_site.ml
f9949778
@@ -1402,7 +1402,7 @@ let handle_election_tally_release (uuid, ()) () =
Lwt_io
chars_of_file
Lwt_stream
to_string
Lwt_io
chars_of_file
Lwt_stream
to_string
wrap1
encrypted_tally_of_string
W
G
read
wrap1
W
G
read
in
in
let
result
E
com
bine_factors
ntallied
et
pds
KG
combine_factors
in
let
result
E
com
pute_result
ntallied
et
pds
KG
combine_factors
in
let
lwt
let
lwt
let
open
Lwt_io
in
let
open
Lwt_io
in
with_file
with_file
