GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
belenios
belenios
f1eb6365
f1eb6365
Stephane Glondu
Remove Web_templates.Login functor
08588459
12
src/web/auth_cas.ml
f1eb6365
@@ -33,7 +33,7 @@ module type CONFIG = sig
val
server
string
val
server
string
module
Make
C
CONFIG
N
NAME
T
LOGIN_TEMPLATE
S
AUTH_HANDLERS
struct
module
Make
C
CONFIG
N
NAME
S
AUTH_SERVICES
L
AUTH_LINK
S
AUTH_HANDLERS
struct
let
scope
Eliom_common
default_session_scope
let
scope
Eliom_common
src/web/auth_dummy.ml
f1eb6365
@@ -32,7 +32,7 @@ let parse_config ~attributes =
Some
Some
_
None
_
None
module
Make
N
NAME
T
LOGIN_TEMPLATE
S
AUTH_HANDLERS
struct
module
Make
N
NAME
S
AUTH_SERVICES
L
AUTH_LINK
S
AUTH_HANDLERS
struct
let
scope
Eliom_common
let
scope
Eliom_common
@@ -60,7 +60,7 @@ module Make (N : NAME) (T : LOGIN_TEMPLATES) : AUTH_HANDLERS = struct
cont
user_name
cont
user_name
None
fail_http
400
None
fail_http
400
in
T
dummy
service
in
Web_templates
dummy
service
module
S
AUTH_SERVICES
module
L
AUTH_LINKS
let
login
cont
let
login
cont
src/web/auth_password.ml
f1eb6365
@@ -49,7 +49,7 @@ let load_db name file =
let
Filename
concat
let
Filename
concat
module
Make
C
CONFIG
N
NAME
T
LOGIN_TEMPLATE
S
AUTH_HANDLERS
struct
module
Make
C
CONFIG
N
NAME
S
AUTH_SERVICES
L
AUTH_LINK
S
AUTH_HANDLERS
struct
let
scope
Eliom_common
let
scope
Eliom_common
@@ -97,7 +97,7 @@ module Make (C : CONFIG) (N : NAME) (T : LOGIN_TEMPLATES) : AUTH_HANDLERS = stru
None
fail_http
400
None
fail_http
400
else
forbidden
else
forbidden
in
in
T
password
service
Web_templates
password
service
module
S
AUTH_SERVICES
module
L
AUTH_LINKS
let
bootstrap_service_handler
let
let
post_params
Eliom_parameter
file
"password_db"
in
let
post_params
Eliom_parameter
file
"password_db"
in
@@ -126,7 +126,7 @@ module Make (C : CONFIG) (N : NAME) (T : LOGIN_TEMPLATES) : AUTH_HANDLERS = stru
`Production
_
forbidden
`Production
_
forbidden
in
in
T
upload_password_db
service
upload_service
Web_templates
upload_password_db
service
upload_service
module
S
AUTH_SERVICES
module
L
AUTH_LINKS
let
Eliom_registration
Html5
service
let
Eliom_registration
Html5
service
fun
fun
src/web/server.mllib
f1eb6365
@@ -10,12 +10,12 @@ Election
Web_serializable_j
Web_serializable_j
Web_common
Web_common
Web_services
Web_services
Web_templates
Web_auth
Web_auth
Auth_dummy
Auth_dummy
Auth_password
Auth_password
Auth_cas
Auth_cas
Web_site_auth
Web_site_auth
Web_templates
Web_persist
Web_persist
Web_election
Web_election
Web_site
Web_site
src/web/web_auth.ml
f1eb6365
@@ -54,9 +54,8 @@ module Make (N : NAME) = struct
(* Forward reference, will be set to eponymous template *)
let
login_choose
ref
fun
assert
false
let
login_choose
ref
fun
assert
false
let
templates
xs
let
auth_services
links
xs
let
module
T
val
templates
LOGIN_TEMPLATES
in
login_choose
Web_templates
choose
auth_services
links
login_choose
T
choose
iter
iter
fun
auth_instance
fun
auth_instance
let
let
@@ -87,7 +86,9 @@ module Make (N : NAME) = struct
let
path
N
path
"auth"
instance
let
path
N
path
"auth"
instance
let
kind
N
kind
let
kind
N
kind
in
in
let
module
A
val
auth
AUTH_SERVICE
N
T
in
let
module
S
val
auth_services
AUTH_SERVICES
in
let
module
L
val
links
AUTH_LINKS
in
let
module
A
val
auth
AUTH_SERVICE
N
S
L
in
let
i
module
A
AUTH_HANDLERS
in
let
i
module
A
AUTH_HANDLERS
in
Hashtbl
add
auth_instances
instance
i
Hashtbl
add
auth_instances
instance
i
auth_instance_names
instance
auth_instance_names
auth_instance_names
instance
auth_instance_names
src/web/web_auth.mli
f1eb6365
@@ -27,7 +27,7 @@ open Web_signatures
val
register_auth_system
module
AUTH_SYSTEM
unit
val
module
AUTH_SYSTEM
unit
module
Make
C
NAME
sig
module
Make
C
NAME
sig
val
module
LOGIN_TEMPLATE
S
auth_config
list
unit
val
module
AUTH_SERVICES
module
AUTH_LINK
S
auth_config
list
unit
module
Services
AUTH_SERVICES
module
Services
AUTH_SERVICES
module
Handlers
AUTH_HANDLERS_PUBLIC
module
Handlers
src/web/web_election.ml
f1eb6365
@@ -283,9 +283,7 @@ module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE = struct
let
let
let
module
T
Web_templates
Login
W
S
L
in
Auth
module
W
S
AUTH_SERVICES
module
L
AUTH_LINKS
N
auth_config
let
templates
module
T
LOGIN_TEMPLATES
in
Auth
templates
N
auth_config
let
login
service
let
login
service
lwt
cont
Eliom_reference
get
Web_services
cont
in
lwt
cont
Eliom_reference
get
Web_services
cont
in
@@ -334,7 +332,7 @@ module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE = struct
match
site_user
match
site_user
Some
u
when
W
metadata
e_owner
Some
u
Some
u
when
W
metadata
e_owner
Some
u
lwt
state
Web_persist
get_election_state
uuid
in
lwt
state
Web_persist
get_election_state
uuid
in
T
election_admin
module
W
is_featured
state
Html5
send
T
election_admin
module
W
is_featured
state
module
Web_site_auth
AUTH_SERVICES
Html5
send
_
forbidden
_
forbidden
@@ -370,7 +368,7 @@ module Make (D : ELECTION_DATA) (P : WEB_PARAMS) : REGISTRABLE = struct
match
site_user
match
site_user
Some
u
Some
u
if
W
metadata
e_owner
Some
u
then
if
W
metadata
e_owner
Some
u
then
T
update_credential
module
W
Html5
send
T
update_credential
module
W
module
Web_site_auth
AUTH_SERVICES
Html5
send
else
else
forbidden
forbidden
src/web/web_signatures.mli
f1eb6365
@@ -147,45 +147,6 @@ module type REGISTRABLE_ELECTION = sig
val
unit
module
WEB_ELECTION
Lwt
t
val
unit
module
WEB_ELECTION
Lwt
t
module
type
LOGIN_TEMPLATES
sig
val
dummy
service
unit
a
Eliom_service
post_service_kind
Eliom_service
suff
b
string
Eliom_parameter
setoneradio
Eliom_parameter
param_name
Eliom_service
registrable
Eliom_service
non_ocaml_service
Eliom_service
service
unit
`Html
Eliom_content
Html5
F
elt
Lwt
t
val
password
service
unit
a
Eliom_service
post_service_kind
Eliom_service
suff
b
string
Eliom_parameter
setoneradio
Eliom_parameter
param_name
string
Eliom_parameter
setoneradio
Eliom_parameter
param_name
Eliom_service
registrable
Eliom_service
non_ocaml_service
Eliom_service
service
unit
`Html
Eliom_content
Html5
F
elt
Lwt
t
val
upload_password_db
service
unit
a
Eliom_service
post_service_kind
Eliom_service
suff
b
Eliom_lib
file_info
Eliom_parameter
setoneradio
Eliom_parameter
param_name
Eliom_service
registrable
Eliom_service
non_ocaml_service
Eliom_service
service
unit
`Html
Eliom_content
Html5
F
elt
Lwt
t
val
choose
unit
`Html
Eliom_content
Html5
F
elt
Lwt
t
module
type
NAME
sig
module
type
NAME
sig
val
name
string
val
name
string
val
path
string
list
val
path
string
list
@@ -194,7 +155,8 @@ end
module
type
AUTH_SERVICE
module
type
AUTH_SERVICE
functor
N
NAME
functor
N
NAME
functor
T
LOGIN_TEMPLATES
functor
S
AUTH_SERVICES
functor
L
AUTH_LINKS
AUTH_HANDLERS
AUTH_HANDLERS
module
type
AUTH_SYSTEM
sig
module
type
AUTH_SYSTEM
sig
src/web/web_site.ml
f1eb6365
@@ -230,9 +230,7 @@ module L = struct
let
install_authentication
auth_configs
let
auth_configs
let
module
T
T
Login
Web_site_auth
L
in
Web_site_auth
module
Web_site_auth
AUTH_SERVICES
module
L
AUTH_LINKS
auth_configs
let
templates
module
T
LOGIN_TEMPLATES
in
Web_site_auth
templates
auth_configs
let
Any
service
home
let
Any
service
home
fun
fun
@@ -267,7 +265,7 @@ let () = Html5.register ~service:admin
election_table
rev
return
election_table
rev
return
in
in
T
admin
elections
T
admin
elections
module
Web_site_auth
AUTH_SERVICES
let
File
let
File
@@ -299,7 +297,7 @@ let () = Html5.register ~service:new_election
fun
fun
match_lwt
Web_site_auth
get_user
match_lwt
Web_site_auth
get_user
None
forbidden
None
forbidden
Some
_
T
new_election
Some
_
T
new_election
module
Web_site_auth
AUTH_SERVICES
let
Any
service
new_election_post
let
Any
service
new_election_post
@@ -316,7 +314,7 @@ let () = Any.register ~service:new_election_post
begin
try_lwt
begin
try_lwt
begin
match_lwt
import_election
files
begin
match_lwt
import_election
files
None
None
T
new_election_failure
`Exists
Html5
send
T
`Exists
module
Web_site_auth
AUTH_SERVICES
Html5
send
Some
w
Some
w
let
module
W
val
w
in
let
module
W
val
w
in
lwt
w
W
in
lwt
w
W
in
@@ -325,7 +323,7 @@ let () = Any.register ~service:new_election_post
preapply
election_admin
W
election
e_params
e_uuid
preapply
election_admin
W
election
e_params
e_uuid
e
e
T
`Exception
e
Html5
send
T
`Exception
e
module
Web_site_auth
AUTH_SERVICES
Html5
send
None
forbidden
None
forbidden
@@ -342,7 +340,7 @@ let () = Html5.register ~service:election_setup_index
then
return
uuid_of_string
k
accu
then
return
uuid_of_string
k
accu
else
return
accu
else
return
accu
election_stable
election_stable
in
T
uuids
in
T
uuids
module
Web_site_auth
AUTH_SERVICES
None
forbidden
None
forbidden
@@ -394,7 +392,7 @@ let () = Html5.register ~service:election_setup
let
uuid_s
Uuidm
to_string
uuid
in
let
uuid_s
Uuidm
to_string
uuid
in
lwt
se
Ocsipersist
find
election_stable
uuid_s
in
lwt
se
Ocsipersist
find
election_stable
uuid_s
in
if
se
se_owner
u
if
se
se_owner
u
then
T
election_setup
uuid
se
then
T
election_setup
uuid
se
module
Web_site_auth
AUTH_SERVICES
else
forbidden
else
forbidden
None
forbidden
None
forbidden
@@ -445,7 +443,7 @@ let () =
let
uuid_s
Uuidm
to_string
uuid
in
let
uuid_s
Uuidm
to_string
uuid
in
lwt
se
Ocsipersist
find
election_stable
uuid_s
in
lwt
se
Ocsipersist
find
election_stable
uuid_s
in
if
se
se_owner
u
if
se
se_owner
u
then
T
election_setup_questions
uuid
se
then
T
uuid
se
module
Web_site_auth
AUTH_SERVICES
else
forbidden
else
forbidden
None
forbidden
None
forbidden
@@ -648,7 +646,7 @@ let () =
(* actually create the election *)
begin
match_lwt
import_election
files
begin
match_lwt
import_election
files
None
None
T
`Exists
Html5
send
T
`Exists
module
Web_site_auth
AUTH_SERVICES
Html5
send
Some
w
Some
w
let
module
W
val
w
in
let
module
W
val
w
in
lwt
w
W
in
lwt
w
W
in
@@ -670,7 +668,7 @@ let () =
e
e
T
`Exception
e
Html5
send
T
`Exception
e
module
Web_site_auth
AUTH_SERVICES
Html5
send
src/web/web_site_auth.mli
f1eb6365
open
Web_serializable_t
open
Web_serializable_t
open
Web_signatures
open
Web_signatures
val
module
LOGIN_TEMPLATE
S
auth_config
list
unit
val
module
AUTH_SERVICES
module
AUTH_LINK
S
auth_config
list
unit
include
AUTH_SERVICES
include
AUTH_SERVICES
src/web/web_templates.ml
f1eb6365
@@ -74,9 +74,7 @@ let make_login_box style auth links =
let
site_login_box
auth
let
site_login_box
let
auth
module
Web_site_auth
AUTH_SERVICES
in
let
module
L
struct
let
module
L
struct
let
login
x
Eliom_service
preapply
site_login
x
let
login
x
Eliom_service
preapply
site_login
x
let
logout
Eliom_service
preapply
site_logout
let
logout
Eliom_service
preapply
site_logout
@@ -151,7 +149,7 @@ let home ~featured () =
let
login_box
pcdata
in
let
login_box
pcdata
in
base
title
site_title
login_box
content
base
title
site_title
login_box
content
let
admin
elections
let
admin
elections
auth
let
title
site_title
" — Administration"
in
let
title
site_title
" — Administration"
in
let
elections
let
elections
match
elections
match
elections
@@ -166,20 +164,17 @@ let admin ~elections () =
elections
elections
in
in
lwt
login_box
site_login_box
in
lwt
login_box
site_login_box
auth
in
base
title
login_box
content
base
title
login_box
content
module
Login
S
AUTH_SERVICES
L
AUTH_LINKS
LOGIN_TEMPLATES
struct
let
login_box
auth
links
let
module
S
val
auth
AUTH_SERVICES
in
let
login_box
let
auth
module
S
AUTH_SERVICES
in
let
links
module
L
AUTH_LINKS
in
let
style
let
style
if
S
auth_realm
"site"
then
admin_background
else
if
S
auth_realm
"site"
then
admin_background
else
in
in
fun
make_login_box
style
auth
links
make_login_box
style
auth
links
let
dummy
service
let
dummy
service
auth
links
let
title
field_name
input_type
let
title
field_name
input_type
"Dummy login"
"Username:"
`Text
"Dummy login"
"Username:"
`Text
in
in
@@ -200,10 +195,10 @@ module Login (S : AUTH_SERVICES) (L : AUTH_LINKS) : LOGIN_TEMPLATES = struct
let
content
let
content
form
form
in
in
lwt
login_box
login_box
in
lwt
login_box
login_box
auth
links
in
base
title
login_box
content
base
title
login_box
content
let
password
service
let
password
service
auth
links
let
form
post_form
service
let
form
post_form
service
fun
llogin
lpassword
fun
llogin
lpassword
@@ -225,10 +220,10 @@ module Login (S : AUTH_SERVICES) (L : AUTH_LINKS) : LOGIN_TEMPLATES = struct
let
content
let
content
form
form
in
in
lwt
login_box
login_box
in
lwt
login_box
login_box
auth
links
in
base
title
"Password login"
login_box
content
base
title
"Password login"
login_box
content
let
upload_password_db
service
let
upload_password_db
service
auth
links
let
title
"Upload password database"
in
let
title
in
let
form
post_form
service
let
form
post_form
service
fun
password_db
fun
password_db
@@ -244,10 +239,12 @@ module Login (S : AUTH_SERVICES) (L : AUTH_LINKS) : LOGIN_TEMPLATES = struct
let
content
let
content
div
form
div
form
in
in
lwt
login_box
site_
login_box
in
lwt
login_box
login_box
auth
links
in
base
title
login_box
content
base
title
login_box
content
let
choose
let
choose
auth
links
let
module
S
val
auth
AUTH_SERVICES
in
let
module
L
val
links
AUTH_LINKS
in
let
auth_systems
let
auth_systems
S
get_auth_systems
S
get_auth_systems
map
fun
name
map
fun
name
@@ -259,11 +256,9 @@ module Login (S : AUTH_SERVICES) (L : AUTH_LINKS) : LOGIN_TEMPLATES = struct
pcdata
"Please log in: ["
auth_systems
pcdata
pcdata
"Please log in: ["
auth_systems
pcdata
in
in
lwt
login_box
login_box
in
lwt
login_box
login_box
auth
links
in
base
title
"Log in"
login_box
content
base
title
"Log in"
login_box
content
let
format_date
Platform
format_datetime
"%a, %d %b %Y %T %z"
let
format_date
Platform
format_datetime
let
make_button
service
contents
let
make_button
service
contents
@@ -273,7 +268,7 @@ let make_button ~service contents =
uri
uri
contents
contents
let
new_election
let
new_election
auth
let
title
"Create new election"
in
let
title
in
lwt
body
lwt
body
let
form
post_form
service
new_election_post
let
form
post_form
service
new_election_post
@@ -318,10 +313,10 @@ let new_election () =
let
content
let
content
div
body
div
body
in
in
lwt
login_box
site_login_box
in
lwt
login_box
site_login_box
auth
in
base
title
login_box
content
base
title
login_box
content
let
reason
let
reason
auth
let
title
in
let
title
in
let
reason
let
reason
match
reason
match
reason
@@ -334,10 +329,10 @@ let new_election_failure reason () =
p
reason
p
reason
in
in
lwt
login_box
site_login_box
in
lwt
login_box
site_login_box
auth
in
base
title
login_box
content
base
title
login_box
content
let
uuids
let
uuids
auth
let
service
election_setup
in
let
service
election_setup
in
let
title
"Elections being prepared"
in
let
title
in
let
uuids
let
uuids
@@ -353,7 +348,7 @@ let election_setup_index uuids () =
let
content
let
content
div
list
div
list
in
in
lwt
login_box
site_login_box
in
lwt
login_box
site_login_box
auth
in
