Commit e17fa8d0 authored by Stephane Glondu's avatar Stephane Glondu
Less passing WEB_ELECTION around
 - introduce sub-module D with signature WEB_ELECTION_DATA
 - Web_templates functions now take WEB_ELECTION_DATA
Rationale: sub-modules E and B are seldom used, eventually we want to
create them on demand and get rid of election_table. D can be directly
created from database. Long-term goal: get rid of register_election
and election_table, and have a constant server startup time.
parent 40d4add4
...@@ -32,12 +32,12 @@ open Web_services ...@@ -32,12 +32,12 @@ open Web_services
let ( / ) = Filename.concat let ( / ) = Filename.concat
module Make (D : ELECTION_DATA) (P : WEB_PARAMS) (M : RANDOM with type 'a t = 'a Lwt.t) : WEB_ELECTION = struct module Make (D : WEB_ELECTION_DATA) (M : RANDOM with type 'a t = 'a Lwt.t) : WEB_ELECTION = struct
let uuid = Uuidm.to_string D.election.e_params.e_uuid let uuid = Uuidm.to_string D.election.e_params.e_uuid
module D = D
include D include D
include P
module E = Election.MakeElection(G)(M) module E = Election.MakeElection(G)(M)
module B : WEB_BALLOT_BOX = struct module B : WEB_BALLOT_BOX = struct
...@@ -25,4 +25,4 @@ open Signatures ...@@ -25,4 +25,4 @@ open Signatures
open Web_serializable_t open Web_serializable_t
open Web_signatures open Web_signatures
module Make (D : ELECTION_DATA) (P : WEB_PARAMS) (M : RANDOM with type 'a t = 'a Lwt.t) : WEB_ELECTION module Make (D : WEB_ELECTION_DATA) (M : RANDOM with type 'a t = 'a Lwt.t) : WEB_ELECTION
...@@ -85,10 +85,14 @@ module type WEB_PARAMS = sig ...@@ -85,10 +85,14 @@ module type WEB_PARAMS = sig
val dir : string val dir : string
end end
module type WEB_ELECTION = sig module type WEB_ELECTION_DATA = sig
include ELECTION_DATA include ELECTION_DATA
include WEB_PARAMS include WEB_PARAMS
module E : ELECTION with type elt = G.t and type 'a m = 'a Lwt.t end
module D : WEB_ELECTION_DATA
module E : ELECTION with type elt = D.G.t and type 'a m = 'a Lwt.t
module B : WEB_BALLOT_BOX module B : WEB_BALLOT_BOX
end end
...@@ -88,9 +88,9 @@ let register_election params web_params = ...@@ -88,9 +88,9 @@ let register_election params web_params =
e_pks = None; e_pks = None;
e_fingerprint = P.fingerprint; e_fingerprint = P.fingerprint;
include (val web_params : WEB_PARAMS)
end in end in
let module P = (val web_params : WEB_PARAMS) in let module W = Web_election.Make (D) (LwtRandom) in
let module W = Web_election.Make (D) (P) (LwtRandom) in
let election = (module W : WEB_ELECTION) in let election = (module W : WEB_ELECTION) in
fun () -> fun () ->
(* starting from here, we do side-effects on the running server *) (* starting from here, we do side-effects on the running server *)
...@@ -192,7 +192,7 @@ let import_election f = ...@@ -192,7 +192,7 @@ let import_election f =
let election = do_register () in let election = do_register () in
let module W = (val election : WEB_ELECTION) in let module W = (val election : WEB_ELECTION) in
lwt () = lwt () =
match W.metadata.e_auth_config with match W.D.metadata.e_auth_config with
| None -> return () | None -> return ()
| Some xs -> | Some xs ->
let auth_config = let auth_config =
...@@ -239,6 +239,7 @@ lwt () = ...@@ -239,6 +239,7 @@ lwt () =
let do_register = register_election params web_params in let do_register = register_election params web_params in
let module W = W.D in
assert (uuid = Uuidm.to_string W.election.e_params.e_uuid); assert (uuid = Uuidm.to_string W.election.e_params.e_uuid);
Ocsigen_messages.debug (fun () -> Ocsigen_messages.debug (fun () ->
Printf.sprintf "Initialized election %s from persistent store" uuid Printf.sprintf "Initialized election %s from persistent store" uuid
...@@ -264,6 +265,8 @@ let () = Html5.register ~service:admin ...@@ -264,6 +265,8 @@ let () = Html5.register ~service:admin
lwt elections, tallied = lwt elections, tallied =
SMap.fold (fun _ w accu -> SMap.fold (fun _ w accu ->
let module W = (val w : WEB_ELECTION) in let module W = (val w : WEB_ELECTION) in
let w = (module W : WEB_ELECTION_DATA) in
if W.metadata.e_owner = Some u then ( if W.metadata.e_owner = Some u then (
let uuid_s = Uuidm.to_string W.election.e_params.e_uuid in let uuid_s = Uuidm.to_string W.election.e_params.e_uuid in
lwt state = Web_persist.get_election_state uuid_s in lwt state = Web_persist.get_election_state uuid_s in
...@@ -538,6 +541,7 @@ let () = ...@@ -538,6 +541,7 @@ let () =
let uuid_s = Uuidm.to_string uuid in let uuid_s = Uuidm.to_string uuid in
let w = SMap.find uuid_s !election_table in let w = SMap.find uuid_s !election_table in
lwt site_user = Web_auth_state.get_site_user () in lwt site_user = Web_auth_state.get_site_user () in
match site_user with match site_user with
| Some u when W.metadata.e_owner = Some u -> | Some u when W.metadata.e_owner = Some u ->
...@@ -952,7 +956,7 @@ let () = ...@@ -952,7 +956,7 @@ let () =
match private_key with match private_key with
| Some x -> | Some x ->
let fname = W.dir / "private_key.json" in let fname = W.D.dir / "private_key.json" in
create_file fname string_of_number [x] create_file fname string_of_number [x]
in in
(* clean up temporary files *) (* clean up temporary files *)
...@@ -970,7 +974,7 @@ let () = ...@@ -970,7 +974,7 @@ let () =
Ocsipersist.remove election_stable uuid_s >> Ocsipersist.remove election_stable uuid_s >>
Web_persist.set_election_date uuid_s (now ()) >> Web_persist.set_election_date uuid_s (now ()) >>
Redirection.send Redirection.send
(preapply election_admin (W.election.e_params.e_uuid, ())) (preapply election_admin (W.D.election.e_params.e_uuid, ()))
end end
with e -> with e ->
...@@ -986,6 +990,7 @@ let () = ...@@ -986,6 +990,7 @@ let () =
try try
Eliom_reference.unset Web_services.ballot >> Eliom_reference.unset Web_services.ballot >>
let cont () = let cont () =
...@@ -1013,6 +1018,7 @@ let () = ...@@ -1013,6 +1018,7 @@ let () =
let uuid = Uuidm.to_string W.election.e_params.e_uuid in let uuid = Uuidm.to_string W.election.e_params.e_uuid in
...@@ -1025,6 +1031,7 @@ let election_set_state state (uuid, ()) () = ...@@ -1025,6 +1031,7 @@ let election_set_state state (uuid, ()) () =
lwt () = lwt () =
match_lwt Web_auth_state.get_site_user () with match_lwt Web_auth_state.get_site_user () with
| Some u when W.metadata.e_owner = Some u -> return () | Some u when W.metadata.e_owner = Some u -> return ()
...@@ -1050,6 +1057,7 @@ let () = ...@@ -1050,6 +1057,7 @@ let () =
| Some u -> | Some u ->
...@@ -1067,11 +1075,13 @@ let () = ...@@ -1067,11 +1075,13 @@ let () =
let module B = W.B in
try_lwt try_lwt
W.B.update_cred ~old ~new_ >> B.update_cred ~old ~new_ >>
String.send ("OK", "text/plain") String.send ("OK", "text/plain")
with Error e -> with Error e ->
String.send ("Error: " ^ explain_error e, "text/plain") String.send ("Error: " ^ explain_error e, "text/plain")
...@@ -1103,6 +1113,7 @@ let () = ...@@ -1103,6 +1113,7 @@ let () =
(Eliom_service.preapply (Eliom_service.preapply
...@@ -1110,8 +1121,8 @@ let () = ...@@ -1110,8 +1121,8 @@ let () =
in in
Eliom_reference.set Web_auth_state.cont [cont] >> Eliom_reference.set Web_auth_state.cont [cont] >>
match_lwt Eliom_reference.get Web_services.ballot with match_lwt Eliom_reference.get Web_services.ballot with
| Some b -> T.cast_confirmation w (sha256_b64 b) () >>= Html5.send | Some b -> T.cast_confirmation (module W) (sha256_b64 b) () >>= Html5.send
| None -> T.cast_raw w () >>= Html5.send) | None -> T.cast_raw (module W) () >>= Html5.send)
let () = let () =
Any.register Any.register
...@@ -1120,6 +1131,7 @@ let () = ...@@ -1120,6 +1131,7 @@ let () =
lwt user = Web_auth_state.get_election_user uuid in lwt user = Web_auth_state.get_election_user uuid in
lwt the_ballot = match ballot_raw, ballot_file with lwt the_ballot = match ballot_raw, ballot_file with
| Some ballot, None -> return ballot | Some ballot, None -> return ballot
...@@ -1150,6 +1162,8 @@ let () = ...@@ -1150,6 +1162,8 @@ let () =
| Some the_ballot -> | Some the_ballot ->
begin begin
...@@ -1159,7 +1173,7 @@ let () = ...@@ -1159,7 +1173,7 @@ let () =
let record = string_of_user u, now () in let record = string_of_user u, now () in
lwt result = lwt result =
try_lwt try_lwt
lwt hash = W.B.cast the_ballot record in lwt hash = B.cast the_ballot record in
return (`Valid hash) return (`Valid hash)
with Error e -> return (`Error e) with Error e -> return (`Error e)
in in
...@@ -1178,8 +1192,10 @@ let () = ...@@ -1178,8 +1192,10 @@ let () =
lwt res, _ = lwt res, _ =
W.B.Ballots.fold B.Ballots.fold
(fun h _ (accu, i) -> (fun h _ (accu, i) ->
if i >= start && i < start+1000 then if i >= start && i < start+1000 then
return (h :: accu, i+1) return (h :: accu, i+1)
...@@ -1214,6 +1230,7 @@ let () = ...@@ -1214,6 +1230,7 @@ let () =
lwt () = lwt () =
...@@ -1248,6 +1265,7 @@ let () = ...@@ -1248,6 +1265,7 @@ let () =
lwt () = lwt () =
match_lwt Web_persist.get_election_state uuid_s with match_lwt Web_persist.get_election_state uuid_s with
| `EncryptedTally _ -> return () | `EncryptedTally _ -> return ()
...@@ -1259,7 +1277,7 @@ let () = ...@@ -1259,7 +1277,7 @@ let () =
"Your partial decryption has already been received and checked!" "Your partial decryption has already been received and checked!"
() >>= Html5.send () >>= Html5.send
) else ( ) else (
T.tally_trustees w trustee_id () >>= Html5.send T.tally_trustees (module W) trustee_id () >>= Html5.send
let () = let () =
...@@ -1281,6 +1299,8 @@ let () = ...@@ -1281,6 +1299,8 @@ let () =
in in
let module E = W.E in
let pks = W.dir / string_of_election_file ESKeys in let pks = W.dir / string_of_election_file ESKeys in
let pks = Lwt_io.lines_of_file pks in let pks = Lwt_io.lines_of_file pks in
lwt () = Lwt_stream.njunk (trustee_id-1) pks in lwt () = Lwt_stream.njunk (trustee_id-1) pks in
...@@ -1297,7 +1317,7 @@ let () = ...@@ -1297,7 +1317,7 @@ let () =
let et = W.dir / string_of_election_file ESETally in let et = W.dir / string_of_election_file ESETally in
lwt et = Lwt_io.chars_of_file et |> Lwt_stream.to_string in lwt et = Lwt_io.chars_of_file et |> Lwt_stream.to_string in
let et = encrypted_tally_of_string W.G.read et in let et = encrypted_tally_of_string W.G.read et in
if W.E.check_factor et pk pd then ( if E.check_factor et pk pd then (
let pds = (trustee_id, partial_decryption) :: pds in let pds = (trustee_id, partial_decryption) :: pds in
lwt () = Web_persist.set_partial_decryptions uuid_s pds in lwt () = Web_persist.set_partial_decryptions uuid_s pds in
T.generic_page ~title:"Success" T.generic_page ~title:"Success"
...@@ -1313,6 +1333,8 @@ let handle_election_tally_release (uuid, ()) () = ...@@ -1313,6 +1333,8 @@ let handle_election_tally_release (uuid, ()) () =
let module W = (val w) in let module W = (val w) in
lwt () = lwt () =
...@@ -1336,7 +1358,7 @@ let handle_election_tally_release (uuid, ()) () = ...@@ -1336,7 +1358,7 @@ let handle_election_tally_release (uuid, ()) () =
Lwt_io.chars_of_file |> Lwt_stream.to_string >>= Lwt_io.chars_of_file |> Lwt_stream.to_string >>=
wrap1 (encrypted_tally_of_string W.G.read) wrap1 (encrypted_tally_of_string W.G.read)
in in
let result = W.E.combine_factors ntallied et pds in let result = E.combine_factors ntallied et pds in
lwt () = lwt () =
let open Lwt_io in let open Lwt_io in
with_file with_file
...@@ -1359,6 +1381,7 @@ let content_type_of_file = function ...@@ -1359,6 +1381,7 @@ let content_type_of_file = function
let handle_pseudo_file w u f site_user = let handle_pseudo_file w u f site_user =
let confidential = let confidential =
match f with match f with
| ESRaw | ESKeys | ESBallots | ESETally | ESResult | ESCreds -> false | ESRaw | ESKeys | ESBallots | ESETally | ESResult | ESCreds -> false
...@@ -1391,6 +1414,9 @@ let () = ...@@ -1391,6 +1414,9 @@ let () =
lwt () = lwt () =
...@@ -1401,7 +1427,7 @@ let () = ...@@ -1401,7 +1427,7 @@ let () =
| `Closed -> return () | `Closed -> return ()
| _ -> forbidden () | _ -> forbidden ()
in in
lwt nb, hash, tally = W.B.compute_encrypted_tally () in lwt nb, hash, tally = B.compute_encrypted_tally () in
let npks = ref 0 in let npks = ref 0 in
...@@ -1417,7 +1443,7 @@ let () = ...@@ -1417,7 +1443,7 @@ let () =
| _ -> failwith "several private keys are available" | _ -> failwith "several private keys are available"
in in
let tally = encrypted_tally_of_string W.G.read tally in let tally = encrypted_tally_of_string W.G.read tally in
lwt pd = W.E.compute_factor tally sk in lwt pd = E.compute_factor tally sk in
let pd = string_of_partial_decryption W.G.write pd in let pd = string_of_partial_decryption W.G.write pd in
Web_persist.set_partial_decryptions uuid_s [1, pd] >> Web_persist.set_partial_decryptions uuid_s [1, pd] >>
handle_election_tally_release (uuid, ()) () handle_election_tally_release (uuid, ()) ()
...@@ -135,7 +135,7 @@ let base ~title ~login_box ~content ?(footer = div []) () = ...@@ -135,7 +135,7 @@ let base ~title ~login_box ~content ?(footer = div []) () =
let format_election kind election = let format_election kind election =
let module W = (val election : WEB_ELECTION) in let module W = (val election : WEB_ELECTION_DATA) in
let e = W.election.e_params in let e = W.election.e_params in
let service = let service =
match kind with match kind with
...@@ -725,7 +725,7 @@ let election_setup_trustee token uuid se () = ...@@ -725,7 +725,7 @@ let election_setup_trustee token uuid se () =
let election_login_box w = let election_login_box w =
let module W = (val w : WEB_ELECTION) in let module W = (val w : WEB_ELECTION_DATA) in
let module A = struct let module A = struct
let get_user () = let get_user () =
Web_auth_state.get_election_user W.election.e_params.e_uuid Web_auth_state.get_election_user W.election.e_params.e_uuid
...@@ -746,13 +746,13 @@ let election_login_box w = ...@@ -746,13 +746,13 @@ let election_login_box w =
fun () -> make_login_box ~show_login:false "" auth links fun () -> make_login_box ~show_login:false "" auth links
let file w x = let file w x =
Eliom_service.preapply Eliom_service.preapply
election_dir election_dir
(W.election.e_params.e_uuid, x) (W.election.e_params.e_uuid, x)
let election_home w state () = let election_home w state () =
let params = W.election.e_params in let params = W.election.e_params in
let state_ = let state_ =
match state with match state with
...@@ -870,7 +870,7 @@ let election_home w state () = ...@@ -870,7 +870,7 @@ let election_home w state () =
base ~title:params.e_name ~login_box ~content ~footer () base ~title:params.e_name ~login_box ~content ~footer ()
let election_admin w state () = let election_admin w state () =
let title = W.election.e_params.e_name ^ " — Administration" in let title = W.election.e_params.e_name ^ " — Administration" in
let state_form checked = let state_form checked =
...@@ -1005,7 +1005,7 @@ let election_admin w state () = ...@@ -1005,7 +1005,7 @@ let election_admin w state () =
base ~title ~login_box ~content () base ~title ~login_box ~content ()
let update_credential w () = let update_credential w () =
let form = post_form ~service:election_update_credential_post let form = post_form ~service:election_update_credential_post
(fun (old, new_) -> (fun (old, new_) ->
...@@ -1063,7 +1063,7 @@ let regenpwd uuid () = ...@@ -1063,7 +1063,7 @@ let regenpwd uuid () =
let cast_raw w () = let cast_raw w () =
let form_rawballot = post_form ~service:election_cast_post let form_rawballot = post_form ~service:election_cast_post
(fun (name, _) -> (fun (name, _) ->
...@@ -1096,7 +1096,7 @@ let cast_raw w () = ...@@ -1096,7 +1096,7 @@ let cast_raw w () =
base ~title:params.e_name ~login_box ~content () base ~title:params.e_name ~login_box ~content ()
let cast_confirmation w hash () = let cast_confirmation w hash () =
lwt user = Web_auth_state.get_election_user W.election.e_params.e_uuid in lwt user = Web_auth_state.get_election_user W.election.e_params.e_uuid in
let name = params.e_name in let name = params.e_name in
...@@ -1154,7 +1154,7 @@ let cast_confirmation w hash () = ...@@ -1154,7 +1154,7 @@ let cast_confirmation w hash () =
base ~title:name ~login_box ~content () base ~title:name ~login_box ~content ()
let cast_confirmed w ~result () = let cast_confirmed w ~result () =
let progress = div ~a:[a_style "text-align:center;margin-bottom:20px;"] [ let progress = div ~a:[a_style "text-align:center;margin-bottom:20px;"] [
...@@ -1196,7 +1196,7 @@ let cast_confirmed w ~result () = ...@@ -1196,7 +1196,7 @@ let cast_confirmed w ~result () =
let pretty_ballots w hashes () = let pretty_ballots w hashes () =
let title = params.e_name ^ " — Accepted ballots" in let title = params.e_name ^ " — Accepted ballots" in
let nballots = ref 0 in let nballots = ref 0 in
...@@ -1230,7 +1230,7 @@ let pretty_ballots w hashes () = ...@@ -1230,7 +1230,7 @@ let pretty_ballots w hashes () =
let tally_trustees w trustee_id () = let tally_trustees w trustee_id () =
let title = let title =
params.e_name ^ " — Partial decryption #" ^ string_of_int trustee_id params.e_name ^ " — Partial decryption #" ^ string_of_int trustee_id
