GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
belenios
belenios
da4a0a30
da4a0a30
Stephane Glondu
Add step[135]_check
a8af9c7c
2
src/lib/signatures.mli
da4a0a30
@@ -245,10 +245,13 @@ module type PEDERSEN = sig
type
elt
val
step1
unit
string
cert
m
val
step1_check
cert
bool
val
step2
certs
unit
val
step3
certs
string
int
polynomial
m
val
step3_check
certs
int
polynomial
bool
val
step4
certs
polynomial
array
vinput
array
val
step5
certs
string
vinput
elt
voutput
m
val
step5_check
certs
int
polynomial
array
elt
voutput
bool
val
step6
certs
polynomial
array
elt
voutput
array
elt
threshold_parameters
val
check
elt
bool
src/lib/trustees.ml
da4a0a30
@@ -283,6 +283,8 @@ module MakePedersen (G : GROUP) (M : RANDOM)
P
make_cert
sk
dk
fun
cert
return
seed
cert
let
step1_check
cert
P
verify_cert
cert
let
step2
certs
Array
iteri
fun
i
cert
if
P
verify_cert
cert
then
@@ -339,6 +341,10 @@ module MakePedersen (G : GROUP) (M : RANDOM)
in
fill_secrets
fun
return
p_polynomial
p_secrets
p_coefexps
let
step3_check
certs
i
polynomial
let
certs
Array
map
fun
x
cert_keys_of_string
G
read
x
s_message
certs
certs
in
P
verify
certs
i
cert_verification
polynomial
p_coefexps
let
step4
certs
polynomials
let
n
Array
length
certs
certs
in
let
step2
certs
in
@@ -412,6 +418,22 @@ module MakePedersen (G : GROUP) (M : RANDOM)
let
step5_check
certs
i
polynomials
voutput
let
n
Array
length
certs
certs
in
let
certs
Array
map
fun
x
cert_keys_of_string
G
read
x
s_message
certs
certs
in
assert
n
Array
length
polynomials
let
coefexps
Array
init
n
fun
i
let
x
polynomials
i
p_coefexps
in
if
not
P
verify
certs
i
cert_verification
x
then
raise
PedersenFailure
Printf
sprintf
"coefexps %d does not validate"
i
raw_coefexps_of_string
G
read
x
s_message
coefexps
in
let
computed_vk
compute_verification_keys
coefexps
i
in
K
check
voutput
vo_public_key
voutput
vo_public_key
trustee_public_key
computed_vk
let
step6
certs
polynomials
voutputs
let
n
Array
length
certs
certs
in
let
step2
certs
in
