Commit d5a77e10 authored by Stephane Glondu's avatar Stephane Glondu
Bugfix: release lock when election already exists
parent 3709ce01
...@@ -214,6 +214,7 @@ module Make (C : CONFIG) : SITE = struct ...@@ -214,6 +214,7 @@ module Make (C : CONFIG) : SITE = struct
with Not_found -> return false with Not_found -> return false
in in
if exists then ( if exists then (
Lwt_mutex.unlock registration_mutex;
return None return None
) else ( ) else (
let ( / ) = Filename.concat in let ( / ) = Filename.concat in
Supports Markdown
