Commit c0900856 authored by Stephane Glondu's avatar Stephane Glondu
Set compile-command to "make all" instead of "make check"
parent 18a00e38
((nil . ((eval . (setq compile-command (format "cd %s && make check" (locate-dominating-file buffer-file-name ".dir-locals.el"))))))) ((nil . ((eval . (setq compile-command (format "cd %s && make all" (locate-dominating-file buffer-file-name ".dir-locals.el")))))))
