Commit a9e8f543 authored by Stephane Glondu's avatar Stephane Glondu
Remove election_table and register_election
parent e17fa8d0
......@@ -73,14 +73,11 @@ let election_pktokens = Ocsipersist.open_table "site_pktokens"
(* Table with tokens given to credential authorities. *)
let election_credtokens = Ocsipersist.open_table "site_credtokens"
(* In-memory table, indexed by UUID, contains closures. *)
let election_table = ref SMap.empty
module T = Web_templates
let register_election params web_params =
let web_election_data (raw_election, web_params) =
let params = Group.election_params_of_string raw_election in
let module P = (val params : ELECTION_PARAMS) in
let uuid = Uuidm.to_string P.params.e_uuid in
let module D = struct
module G = P.G
let election = {
......@@ -90,12 +87,11 @@ let register_election params web_params =
include (val web_params : WEB_PARAMS)
end in
let module W = Web_election.Make (D) (LwtRandom) in
let election = (module W : WEB_ELECTION) in
fun () ->
(* starting from here, we do side-effects on the running server *)
election_table := SMap.add uuid election !election_table;
election
(module D : WEB_ELECTION_DATA)
let find_election uuid =
lwt x = Ocsipersist.find election_ptable uuid in
return (web_election_data x)
(* Mutex to avoid simultaneous registrations of the same election *)
let registration_mutex = Lwt_mutex.create ()
......@@ -136,7 +132,6 @@ let import_election f =
let dir = dir
end in
let web_params = (module X : WEB_PARAMS) in
let do_register = register_election params web_params in
let module G = P.G in
let module KG = Election.MakeSimpleDistKeyGen (G) (LwtRandom) in
let public_keys = Lwt_io.lines_of_file f.f_public_keys in
......@@ -189,8 +184,8 @@ let import_election f =
Lwt_io.(with_file Output (dir/"voters.txt") (fun oc ->
write_lines oc voters
let election = do_register () in
let module W = (val election : WEB_ELECTION) in
let election = web_election_data (raw_election, web_params) in
let module W = Web_election.Make ((val election)) (LwtRandom) in
lwt () =
match W.D.metadata.e_auth_config with
| None -> return ()
......@@ -212,7 +207,7 @@ let import_election f =
W.B.update_files () >>
Ocsipersist.add election_ptable uuid (raw_election, web_params) >>
let () = Lwt_mutex.unlock registration_mutex in
return election
return (module W : WEB_ELECTION)
with e ->
lwt () =
try_lwt delete_shallow_directory dir
......@@ -233,20 +228,6 @@ let import_election f =
Lwt_mutex.unlock registration_mutex;
Lwt.fail e
lwt () =
Ocsipersist.iter_step (fun uuid (raw_election, web_params) ->
let module W = W.D in
assert (uuid = Uuidm.to_string W.election.e_params.e_uuid);
Ocsigen_messages.debug (fun () ->
Printf.sprintf "Initialized election %s from persistent store" uuid
return ()
) election_ptable
let () = Any.register ~service:home
(fun () () ->
Eliom_reference.unset Web_auth_state.cont >>
......@@ -263,22 +244,20 @@ let () = Html5.register ~service:admin
| None -> return None
| Some u ->
lwt elections, tallied =
SMap.fold (fun _ w accu ->
let module W = (val w : WEB_ELECTION) in
let w = (module W : WEB_ELECTION_DATA) in
Ocsipersist.fold_step (fun uuid_s (_, web_params) accu ->
let module W = (val web_params : WEB_PARAMS) in
if W.metadata.e_owner = Some u then (
let uuid_s = Uuidm.to_string W.election.e_params.e_uuid in
lwt w = find_election uuid_s in
lwt state = Web_persist.get_election_state uuid_s in
lwt date = Web_persist.get_election_date uuid_s in
lwt elections, tallied = accu in
let elections, tallied = accu in
match state with
| `Tallied _ -> return (elections, (date, w) :: tallied)
| _ -> return ((date, w) :: elections, tallied)
) else (
accu
return accu
) !election_table (return ([], []))
) election_ptable ([], [])
and setup_elections =
Ocsipersist.fold_step (fun k v accu ->
if v.se_owner = u
......@@ -539,9 +518,8 @@ let () =
~service:election_regenpwd_post
(fun (uuid, ()) user ->
let uuid_s = Uuidm.to_string uuid in
let w = SMap.find uuid_s !election_table in
let module W = (val w) in
lwt site_user = Web_auth_state.get_site_user () in
match site_user with
| Some u when W.metadata.e_owner = Some u ->
......@@ -987,10 +965,9 @@ let () =
~service:election_home
(fun (uuid, ()) () ->
try
try_lwt
Eliom_reference.unset Web_services.ballot >>
let cont () =
Redirection.send
......@@ -1015,10 +992,9 @@ let () =
~service:election_admin
let uuid = Uuidm.to_string W.election.e_params.e_uuid in
......@@ -1029,9 +1005,8 @@ let () =
let election_set_state state (uuid, ()) () =
lwt () =
match_lwt Web_auth_state.get_site_user () with
| Some u when W.metadata.e_owner = Some u -> return ()
......@@ -1054,10 +1029,9 @@ let () =
~service:election_update_credential
| Some u ->
......@@ -1072,9 +1046,9 @@ let () =
~service:election_update_credential_post
(fun (uuid, ()) (old, new_) ->
let module W = Web_election.Make ((val w)) (LwtRandom) in
let module B = W.B in
......@@ -1096,8 +1070,8 @@ let () =
~service:election_vote
Redirection.send
(Eliom_service.preapply
......@@ -1111,9 +1085,8 @@ let () =
~service:election_cast
let cont () =
Redirection.send
......@@ -1129,9 +1102,8 @@ let () =
~service:election_cast_post
(fun (uuid, ()) (ballot_raw, ballot_file) ->
lwt user = Web_auth_state.get_election_user uuid in
lwt the_ballot = match ballot_raw, ballot_file with
| Some ballot, None -> return ballot
......@@ -1160,8 +1132,8 @@ let () =
~service:election_cast_confirm
match_lwt Eliom_reference.get Web_services.ballot with
......@@ -1190,8 +1162,8 @@ let () =
~service:election_pretty_ballots
(fun ((uuid, ()), start) () ->
lwt res, _ =
......@@ -1208,8 +1180,8 @@ let () =
(fun ((uuid, ()), hash) () ->
lwt ballot =
W.B.Ballots.fold
(fun h b accu ->
......@@ -1228,9 +1200,8 @@ let () =
~service:election_missing_voters
lwt () =
......@@ -1263,9 +1234,8 @@ let () =
~service:election_tally_trustees
(fun (uuid, ((), trustee_id)) () ->
lwt () =
match_lwt Web_persist.get_election_state uuid_s with
| `EncryptedTally _ -> return ()
......@@ -1297,8 +1267,8 @@ let () =
lwt () =
if trustee_id > 0 then return () else fail_http 404
in
let module E = W.E in
let pks = W.dir / string_of_election_file ESKeys in
......@@ -1331,8 +1301,8 @@ let () =
let handle_election_tally_release (uuid, ()) () =
lwt () =
......@@ -1380,8 +1350,7 @@ let content_type_of_file = function
| ESCreds | ESRecords | ESVoters -> "text/plain"
let handle_pseudo_file w u f site_user =
let module W = (val w : WEB_ELECTION_DATA) in
let confidential =
match f with
| ESRaw | ESKeys | ESBallots | ESETally | ESResult | ESCreds -> false
......@@ -1402,9 +1371,9 @@ let () =
~service:election_dir
(fun (uuid, f) () ->
handle_pseudo_file w () f site_user)
let () =
......@@ -1412,8 +1381,8 @@ let () =
~service:election_compute_encrypted_tally
