Commit 97b1b629 authored by Stephane Glondu's avatar Stephane Glondu
Use getter/setter for setup_election
parent 147c0088
...@@ -69,6 +69,12 @@ let find_election = ...@@ -69,6 +69,12 @@ let find_election =
let cache = new WCache.cache raw_find_election 100 in let cache = new WCache.cache raw_find_election 100 in
fun x -> cache#find x fun x -> cache#find x
let get_setup_election uuid_s =
Ocsipersist.find election_stable uuid_s
let set_setup_election uuid_s se =
Ocsipersist.add election_stable uuid_s se
let dump_passwords dir table = let dump_passwords dir table =
Lwt_io.(with_file Output (dir / "passwords.csv") (fun oc -> Lwt_io.(with_file Output (dir / "passwords.csv") (fun oc ->
Ocsipersist.iter_step (fun voter (salt, hashed) -> Ocsipersist.iter_step (fun voter (salt, hashed) ->
...@@ -343,7 +349,7 @@ let create_new_election owner cred auth = ...@@ -343,7 +349,7 @@ let create_new_election owner cred auth =
se_public_creds = token; se_public_creds = token;
se_public_creds_received = false; se_public_creds_received = false;
} in } in
lwt () = Ocsipersist.add election_stable uuid_s se in lwt () = set_setup_election uuid_s se in
lwt () = Ocsipersist.add election_credtokens token uuid_s in lwt () = Ocsipersist.add election_credtokens token uuid_s in
return (preapply election_setup uuid) return (preapply election_setup uuid)
...@@ -372,7 +378,7 @@ let generic_setup_page f uuid () = ...@@ -372,7 +378,7 @@ let generic_setup_page f uuid () =
match_lwt Web_state.get_site_user () with match_lwt Web_state.get_site_user () with
| Some u -> | Some u ->
let uuid_s = Uuidm.to_string uuid in let uuid_s = Uuidm.to_string uuid in
lwt se = Ocsipersist.find election_stable uuid_s in lwt se = get_setup_election uuid_s in
if se.se_owner = u if se.se_owner = u
then f uuid se () then f uuid se ()
else forbidden () else forbidden ()
...@@ -394,11 +400,11 @@ let handle_setup f uuid x = ...@@ -394,11 +400,11 @@ let handle_setup f uuid x =
Lwt_mutex.with_lock election_setup_mutex (fun () -> Lwt_mutex.with_lock election_setup_mutex (fun () ->
if se.se_owner = u then ( if se.se_owner = u then (
try_lwt try_lwt
lwt cont = f se x u uuid in lwt cont = f se x u uuid in
Ocsipersist.add election_stable uuid_s se >> set_setup_election uuid_s se >>
cont () cont ()
with e -> with e ->
let service = preapply election_setup uuid in let service = preapply election_setup uuid in
...@@ -507,7 +513,7 @@ let () = ...@@ -507,7 +513,7 @@ let () =
then T.election_setup_questions uuid se () then T.election_setup_questions uuid se ()
...@@ -529,7 +535,7 @@ let () = ...@@ -529,7 +535,7 @@ let () =
then T.election_setup_voters uuid se () then T.election_setup_voters uuid se ()
...@@ -610,13 +616,13 @@ let () = ...@@ -610,13 +616,13 @@ let () =
then ( then (
lwt st_token = generate_token () in lwt st_token = generate_token () in
let trustee = {st_id; st_token; st_public_key = ""} in let trustee = {st_id; st_token; st_public_key = ""} in
se.se_public_keys <- se.se_public_keys @ [trustee]; se.se_public_keys <- se.se_public_keys @ [trustee];
Ocsipersist.add election_pktokens st_token uuid_s Ocsipersist.add election_pktokens st_token uuid_s
) else forbidden () ) else forbidden ()
...@@ -636,7 +642,7 @@ let () = ...@@ -636,7 +642,7 @@ let () =
then ( then (
let trustees, old = let trustees, old =
...@@ -646,7 +652,7 @@ let () = ...@@ -646,7 +652,7 @@ let () =
(fun (x, y) -> List.map snd x, List.map snd y) (fun (x, y) -> List.map snd x, List.map snd y)
in in
se.se_public_keys <- trustees; se.se_public_keys <- trustees;
Lwt_list.iter_s (fun {st_token; _} -> Lwt_list.iter_s (fun {st_token; _} ->
Ocsipersist.remove election_pktokens st_token Ocsipersist.remove election_pktokens st_token
) old ) old
...@@ -661,7 +667,7 @@ let () = ...@@ -661,7 +667,7 @@ let () =
~service:election_setup_credentials ~service:election_setup_credentials
(fun token () -> (fun token () ->
lwt uuid = Ocsipersist.find election_credtokens token in lwt uuid = Ocsipersist.find election_credtokens token in
lwt se = Ocsipersist.find election_stable uuid in lwt se = get_setup_election uuid in
T.election_setup_credentials token uuid se () T.election_setup_credentials token uuid se ()
...@@ -681,7 +687,7 @@ let wrap_handler f = ...@@ -681,7 +687,7 @@ let wrap_handler f =
let handle_credentials_post token creds = let handle_credentials_post token creds =
if se.se_public_creds_received then forbidden () else if se.se_public_creds_received then forbidden () else
let module G = (val Group.of_string se.se_group : GROUP) in let module G = (val Group.of_string se.se_group : GROUP) in
let fname = !spool_dir / uuid ^ ".public_creds.txt" in let fname = !spool_dir / uuid ^ ".public_creds.txt" in
...@@ -707,7 +713,7 @@ let handle_credentials_post token creds = ...@@ -707,7 +713,7 @@ let handle_credentials_post token creds =
in in
let () = se.se_metadata <- {se.se_metadata with e_cred_authority = None} in let () = se.se_metadata <- {se.se_metadata with e_cred_authority = None} in
let () = se.se_public_creds_received <- true in let () = se.se_public_creds_received <- true in
Ocsipersist.add election_stable uuid se >> set_setup_election uuid se >>
T.generic_page ~title:"Success" ~service:home T.generic_page ~title:"Success" ~service:home
"Credentials have been received and checked!" () >>= Html5.send "Credentials have been received and checked!" () >>= Html5.send
...@@ -784,7 +790,7 @@ let () = ...@@ -784,7 +790,7 @@ let () =
~service:election_setup_trustee ~service:election_setup_trustee
lwt uuid = Ocsipersist.find election_pktokens token in lwt uuid = Ocsipersist.find election_pktokens token in
T.election_setup_trustee token se () T.election_setup_trustee token se ()
...@@ -798,7 +804,7 @@ let () = ...@@ -798,7 +804,7 @@ let () =
Lwt_mutex.with_lock Lwt_mutex.with_lock
election_setup_mutex election_setup_mutex
(fun () -> (fun () ->
let t = List.find (fun x -> token = x.st_token) se.se_public_keys in let t = List.find (fun x -> token = x.st_token) se.se_public_keys in
let pk = trustee_public_key_of_string G.read public_key in let pk = trustee_public_key_of_string G.read public_key in
...@@ -806,7 +812,7 @@ let () = ...@@ -806,7 +812,7 @@ let () =
if not (KG.check pk) then failwith "invalid public key"; if not (KG.check pk) then failwith "invalid public key";
(* we keep pk as a string because of G.t *) (* we keep pk as a string because of G.t *)
t.st_public_key <- public_key; t.st_public_key <- public_key;
Ocsipersist.add election_stable uuid se set_setup_election uuid se
) >> T.generic_page ~title:"Success" ) >> T.generic_page ~title:"Success"
"Your key has been received and checked!" "Your key has been received and checked!"
() >>= Html5.send () >>= Html5.send
...@@ -821,7 +827,7 @@ let () = ...@@ -821,7 +827,7 @@ let () =
| None -> forbidden () | None -> forbidden ()
if se.se_owner <> u then forbidden () else if se.se_owner <> u then forbidden () else
T.election_setup_confirm uuid se () >>= Html5.send) T.election_setup_confirm uuid se () >>= Html5.send)
...@@ -835,7 +841,7 @@ let () = ...@@ -835,7 +841,7 @@ let () =
begin try_lwt begin try_lwt
finalize_election uuid se >> finalize_election uuid se >>
Redirection.send (preapply election_admin (uuid, ())) Redirection.send (preapply election_admin (uuid, ()))
...@@ -853,7 +859,7 @@ let () = ...@@ -853,7 +859,7 @@ let () =
match site_user with match site_user with
lwt se = Ocsipersist.find election_stable (Uuidm.to_string uuid) in lwt se = get_setup_election (Uuidm.to_string uuid) in
lwt elections = get_finalized_elections_by_owner u in lwt elections = get_finalized_elections_by_owner u in
T.election_setup_import uuid se elections ()) T.election_setup_import uuid se elections ())
