GitLab
Support
Community forum
Keyboard shortcuts
B
belenios
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Analytics
Analytics
Value Stream
belenios
belenios
8279bbfe
8279bbfe
Stephane Glondu
Do no longer rely on Ocsipersist for decryption tokens
010c6a65
4
4 changed files
22 additions
23 deletions
+22
-23
src/web/web_persist.ml
+9
src/web/web_persist.mli
+3
src/web/web_serializable.atd
+1
src/web/web_site.ml
src/web/web_site.ml
+9
-23
8279bbfe
@@ -106,6 +106,15 @@ let set_partial_decryptions uuid pds =
write_file
uuid
"partial_decryptions.json"
write_file
uuid
string_of_partial_decryptions
pds
pds
let
get_decryption_tokens
uuid
match
lwt
read_file
uuid
"decryption_tokens.json"
Some
x
return
Some
decryption_tokens_of_string
x
_
return_none
let
set_decryption_tokens
uuid
pds
write_file
uuid
string_of_decryption_tokens
pds
let
get_raw_election
uuid
let
get_raw_election
uuid
match
lwt
read_file
uuid
"election.json"
match
lwt
read_file
uuid
"election.json"
Some
x
return
Some
x
Some
x
return
Some
x
8279bbfe
@@ -42,6 +42,9 @@ val set_election_date : election_date -> uuid -> datetime -> unit Lwt.t
val
get_partial_decryptions
uuid
partial_decryptions
Lwt
t
val
uuid
partial_decryptions
Lwt
t
val
uuid
partial_decryptions
unit
Lwt
t
val
uuid
partial_decryptions
unit
Lwt
t
val
uuid
decryption_tokens
option
Lwt
t
val
uuid
decryption_tokens
unit
Lwt
t
val
get_auth_config
uuid
string
string
string
list
list
Lwt
t
val
get_auth_config
uuid
string
string
string
list
list
Lwt
t
val
get_raw_election
uuid
string
option
Lwt
t
val
get_raw_election
uuid
string
option
Lwt
t
8279bbfe
@@ -83,6 +83,7 @@ type election_state =
type partial_decryptions = (int * string) list
type decryption_tokens = string list
(** {1 Types related to elections being prepared} *)
src/web/web_site.ml
8279bbfe
@@ -42,9 +42,6 @@ module PString = String
open
Eliom_service
open
Eliom_service
open
Eliom_registration
open
Eliom_registration
(* Table with tokens given to trustees (in threshold mode) to decrypt *)
let
election_tokens_decrypt
Ocsipersist
open_table
"site_tokens_decrypt"
module
T
Web_templates
module
T
Web_templates
let
raw_find_election
uuid
let
raw_find_election
uuid
@@ -224,20 +221,10 @@ let validate_election uuid se =
Web_persist
set_election_state
uuid
`Open
Web_persist
set_election_state
uuid
`Open
Web_persist
set_election_date
`Validation
uuid
now
Web_persist
set_election_date
`Validation
uuid
now
let
cleanup_table
uuid_s
table
let
table
Ocsipersist
open_table
table
in
match
uuid_s
None
let
lwt
indexes
Ocsipersist
fold_step
fun
k
_
accu
return
k
accu
table
in
Lwt_list
iter_s
Ocsipersist
remove
table
indexes
Some
u
Ocsipersist
remove
table
u
let
delete_sensitive_data
uuid
let
uuid
let
uuid_s
raw_string_of_uuid
uuid
in
let
uuid_s
raw_string_of_uuid
uuid
in
let
lwt
cleanup_file
spool_dir
uuid_s
"state.json"
in
let
lwt
cleanup_file
spool_dir
uuid_s
"state.json"
in
let
lwt
cleanup_
table
uuid_s
in
let
lwt
cleanup_
file
spool_dir
uuid_s
in
let
lwt
cleanup_file
spool_dir
uuid_s
in
let
lwt
cleanup_file
spool_dir
uuid_s
in
let
lwt
cleanup_file
spool_dir
uuid_s
"extended_records.jsons"
in
let
lwt
cleanup_file
spool_dir
uuid_s
in
let
lwt
cleanup_file
spool_dir
uuid_s
"credential_mappings.jsons"
in
let
lwt
cleanup_file
spool_dir
uuid_s
in
@@ -1228,7 +1215,6 @@ let () =
let
let
Any
service
election_admin
Any
service
election_admin
fun
uuid
fun
uuid
let
uuid_s
raw_string_of_uuid
uuid
in
let
lwt
w
find_election
uuid
in
let
lwt
w
find_election
uuid
in
let
lwt
metadata
Web_persist
get_election_metadata
uuid
in
let
lwt
metadata
Web_persist
uuid
in
let
lwt
site_user
Web_state
get_site_user
in
let
lwt
site_user
Web_state
get_site_user
in
@@ -1236,14 +1222,14 @@ let () =
Some
u
when
metadata
e_owner
Some
u
Some
u
when
metadata
e_owner
Some
u
let
lwt
state
Web_persist
get_election_state
uuid
in
let
lwt
state
Web_persist
get_election_state
uuid
in
let
get_tokens_decrypt
let
get_tokens_decrypt
try
lwt
match
lwt
Web_persist
uuid
Ocsipersist
find
uuid_s
Some
x
return
x
Not_found
None
match
metadata
e_trustees
match
metadata
e_trustees
None
failwith
"missing trustees in get_tokens_decrypt"
None
failwith
Some
ts
Some
ts
let
lwt
ts
Lwt_list
map_s
fun
_
generate_token
ts
in
let
lwt
ts
Lwt_list
map_s
fun
_
generate_token
ts
in
Ocsipersist
add
uuid_s
ts
Web_persist
uuid
ts
return
ts
return
ts
in
in
T
election_admin
w
metadata
state
get_tokens_decrypt
Html5
send
T
election_admin
w
metadata
state
get_tokens_decrypt
Html5
send
@@ -1548,14 +1534,14 @@ let () =
let
find_trustee_id
uuid
token
let
find_trustee_id
uuid
token
try
lwt
match
lwt
Web_persist
uuid
let
lwt
tokens
Ocsipersist
find
raw_string_of_uuid
uuid
in
None
return
try
int_of_string
token
_
Some
tokens
let
rec
find
i
function
let
rec
find
i
function
raise
Not_found
raise
Not_found
t
ts
if
t
token
then
i
else
find
i
ts
t
ts
if
t
token
then
i
else
find
i
ts
in
in
return
find
tokens
return
find
tokens
Not_found
return
try
int_of_string
token
_
let
let
Any
service
election_tally_trustees
Any
service
@@ -1690,7 +1676,7 @@ let handle_election_tally_release (uuid, ()) () =
in
in
let
lwt
Web_persist
set_election_state
uuid
`Tallied
in
let
lwt
Web_persist
set_election_state
uuid
`Tallied
in
let
lwt
Web_persist
set_election_date
`Tally
uuid
now
in
let
lwt
Web_persist
set_election_date
`Tally
uuid
now
in
let
lwt
Ocsipersist
remove
uuid_s
in
let
lwt
cleanup_file
spool_dir
uuid_s
in
redir_preapply
election_home
uuid
redir_preapply
election_home
uuid
else
forbidden
else
forbidden
