Commit 66e282ed authored by Stephane Glondu's avatar Stephane Glondu
Fix formulas in verify_disjuncts
parent 5d887698
...@@ -103,9 +103,8 @@ let verify_disjunct pk big_g big_h proof_item = ...@@ -103,9 +103,8 @@ let verify_disjunct pk big_g big_h proof_item =
a = Z.rem a p && a = Z.rem a p &&
b = Z.rem b p && b = Z.rem b p &&
dp_challenge = Z.rem dp_challenge q && dp_challenge = Z.rem dp_challenge q &&
(* dp_response = Z.rem dp_response q && *) (* FIXME *) g ** dp_response = big_g ** dp_challenge * a &&
(* g ** dp_response = big_g * a && *) (* FIXME *) h ** dp_response = big_h ** dp_challenge * b &&
(* h ** dp_response = big_h * b && *) (* FIXME *)
true true
let verify_disj_proof pk big_g big_hs proof = let verify_disj_proof pk big_g big_hs proof =
