Commit 63e096c6 authored by Stephane Glondu's avatar Stephane Glondu
Add {add,remove}_featured_election
parent 93ba37a6
...@@ -265,6 +265,8 @@ module type SITE = sig ...@@ -265,6 +265,8 @@ module type SITE = sig
featured:bool -> election_files -> (module WEB_ELECTION) option Lwt.t featured:bool -> election_files -> (module WEB_ELECTION) option Lwt.t
val set_main_election : string -> unit Lwt.t val set_main_election : string -> unit Lwt.t
val unset_main_election : unit -> unit Lwt.t val unset_main_election : unit -> unit Lwt.t
val add_featured_election : string -> unit Lwt.t
val remove_featured_election : string -> unit Lwt.t
val cont : (unit -> service_handler) Eliom_reference.eref val cont : (unit -> service_handler) Eliom_reference.eref
end end
...@@ -34,6 +34,10 @@ module type CONFIG = sig ...@@ -34,6 +34,10 @@ module type CONFIG = sig
val auth_config : auth_config list val auth_config : auth_config list
end end
let rec list_remove x = function
| y :: ys -> if x = y then ys else y :: (list_remove x ys)
let get_single_line x = let get_single_line x =
match_lwt Lwt_stream.get x with match_lwt Lwt_stream.get x with
| None -> return None | None -> return None
...@@ -105,6 +109,20 @@ module Make (C : CONFIG) : SITE = struct ...@@ -105,6 +109,20 @@ module Make (C : CONFIG) : SITE = struct
let import_election ~featured f = !import_election_ref featured f let import_election ~featured f = !import_election_ref featured f
let add_featured_election x =
lwt the_featured = Ocsipersist.get featured in
if List.mem x the_featured then (
return ()
) else if SMap.mem x !election_table then (
Ocsipersist.set featured (x :: the_featured)
) else (
Lwt.fail Not_found
let remove_featured_election x =
Ocsipersist.set featured (list_remove x the_featured)
let set_main_election x = let set_main_election x =
if SMap.mem x !election_table then ( if SMap.mem x !election_table then (
Ocsipersist.set main_election (Some x) Ocsipersist.set main_election (Some x)
Supports Markdown
