Commit 629b7141 authored by Stephane Glondu's avatar Stephane Glondu
Add explicit references to dependency-as-package-name lists
parent 7debdda9
...@@ -27,7 +27,9 @@ To run the web server, you will additionally need: ...@@ -27,7 +27,9 @@ To run the web server, you will additionally need:
* [Eliom](http://ocsigen.org/eliom/) version 3 * [Eliom](http://ocsigen.org/eliom/) version 3
On Debian and its derivatives, you can try the following: On Debian and its derivatives, you can find the list of packages to
install in the `stuff/belenios-deps-*.control` files. You can also
create meta-packages with `equivs` by using the following commands:
BELENIOS=`pwd` BELENIOS=`pwd`
cd /tmp cd /tmp
Supports Markdown
