Commit 5e505e2b authored by Stephane Glondu's avatar Stephane Glondu
Set window.onbeforeunload to force refresh when "Back" is pressed
Reference:
http://www.hunlock.com/blogs/Mastering_The_Back_Button_With_Javascript
parent eb398ddc
...@@ -87,7 +87,9 @@ module Make (S : AUTH_SERVICES) : TEMPLATES = struct ...@@ -87,7 +87,9 @@ module Make (S : AUTH_SERVICES) : TEMPLATES = struct
let base ~title ~login_box ~content = let base ~title ~login_box ~content =
Lwt.return (html ~a:[a_dir `Ltr; a_xml_lang "en"] Lwt.return (html ~a:[a_dir `Ltr; a_xml_lang "en"]
(head (Eliom_content.Html5.F.title (pcdata title)) []) (head (Eliom_content.Html5.F.title (pcdata title)) [
script (pcdata "window.onbeforeunload = function () {};");
(body [ (body [
div ~a:[a_id "header"] [ div ~a:[a_id "header"] [
div [ div [
