Commit 3c24ae96 authored by Stephane Glondu's avatar Stephane Glondu
Use a shared mutex in cast and update_cred
parent 3d1e773e
...@@ -185,7 +185,7 @@ module MakeBallotBox (P : Signatures.ELECTION_PARAMS) (E : LWT_ELECTION) = struc ...@@ -185,7 +185,7 @@ module MakeBallotBox (P : Signatures.ELECTION_PARAMS) (E : LWT_ELECTION) = struc
let cast rawballot (user, date) = let do_cast rawballot (user, date) =
let voting_open = match P.metadata with let voting_open = match P.metadata with
| Some m -> | Some m ->
let date = fst date in let date = fst date in
...@@ -273,7 +273,7 @@ module MakeBallotBox (P : Signatures.ELECTION_PARAMS) (E : LWT_ELECTION) = struc ...@@ -273,7 +273,7 @@ module MakeBallotBox (P : Signatures.ELECTION_PARAMS) (E : LWT_ELECTION) = struc
let turnout = Ocsipersist.length ballot_table let turnout = Ocsipersist.length ballot_table
let update_cred ~old ~new_ = let do_update_cred ~old ~new_ =
match_lwt Ocsipersist.fold_step (fun k v x -> match_lwt Ocsipersist.fold_step (fun k v x ->
if sha256_hex k = old then ( if sha256_hex k = old then (
match v with match v with
...@@ -285,6 +285,15 @@ module MakeBallotBox (P : Signatures.ELECTION_PARAMS) (E : LWT_ELECTION) = struc ...@@ -285,6 +285,15 @@ module MakeBallotBox (P : Signatures.ELECTION_PARAMS) (E : LWT_ELECTION) = struc
| Some x -> | Some x ->
Ocsipersist.remove cred_table x >> Ocsipersist.remove cred_table x >>
Ocsipersist.add cred_table new_ None Ocsipersist.add cred_table new_ None
let mutex = Lwt_mutex.create ()
Lwt_mutex.with_lock mutex (fun () -> do_cast rawballot (user, date))
Lwt_mutex.with_lock mutex (fun () -> do_update_cred ~old ~new_)
end end
module type WEB_ELECTION = sig module type WEB_ELECTION = sig
