Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit 09378e55 authored by Stephane Glondu's avatar Stephane Glondu
Remove unneeded forward reference
parent f844192c
......@@ -70,9 +70,6 @@ module Make (N : NAME) = struct
let auth_instances = Hashtbl.create 10
let auth_instance_names = ref []
(* Forward reference, will be set to eponymous template *)
let login_choose = ref (fun () -> assert false)
let user = Eliom_reference.eref ~scope None
let do_login_using user_domain cont =
......@@ -105,9 +102,9 @@ module Make (N : NAME) = struct
let auth_services = (module Services : AUTH_SERVICES)
let configure xs =
let auth_services = (module Services : AUTH_SERVICES) in
login_choose := Web_templates.choose auth_services links;
List.iter
(fun auth_instance ->
let {
......@@ -152,7 +149,9 @@ module Make (N : NAME) = struct
| None ->
match !auth_instance_names with
| [name] -> do_login_using name cont
| _ -> !login_choose () >>= Eliom_registration.Html5.send
| _ ->
Web_templates.choose auth_services links () >>=
in
match_lwt Eliom_reference.get user with
| Some u ->
