Commit 3157a9dc authored by Millian Poquet's avatar Millian Poquet
Indentation coherency: removal of all tabulations in source code
parent 84dc211b
...@@ -175,7 +175,7 @@ static int requestReplyScheduler(int argc, char *argv[]) ...@@ -175,7 +175,7 @@ static int requestReplyScheduler(int argc, char *argv[])
char sendDateAsString[16]; char sendDateAsString[16];
sprintf(sendDateAsString, "%f", MSG_get_clock()); sprintf(sendDateAsString, "%f", MSG_get_clock());
char *sendBuf = MSG_process_get_data(MSG_process_self()); char *sendBuf = MSG_process_get_data(MSG_process_self());
XBT_INFO("Buffer received in REQ-REP: '%s'", sendBuf); XBT_INFO("Buffer received in REQ-REP: '%s'", sendBuf);
...@@ -447,7 +447,7 @@ int server(int argc, char *argv[]) ...@@ -447,7 +447,7 @@ int server(int argc, char *argv[])
break; break;
} // end of case SUBMITTER_HELLO } // end of case SUBMITTER_HELLO
case SUBMITTER_BYE: case SUBMITTER_BYE:
nb_submitters_finished++; nb_submitters_finished++;
XBT_INFO("A submitted said goodbye. Number of finished submitters: %d", nb_submitters_finished); XBT_INFO("A submitted said goodbye. Number of finished submitters: %d", nb_submitters_finished);
break; break;
...@@ -463,7 +463,7 @@ int server(int argc, char *argv[]) ...@@ -463,7 +463,7 @@ int server(int argc, char *argv[])
size_m = snprintf(sched_message + lg_sched_message, schedMessageMaxLength - lg_sched_message, size_m = snprintf(sched_message + lg_sched_message, schedMessageMaxLength - lg_sched_message,
"|%f:C:%s", MSG_get_clock(), job->id_str); "|%f:C:%s", MSG_get_clock(), job->id_str);
lg_sched_message += size_m; lg_sched_message += size_m;
xbt_assert(lg_sched_message <= schedMessageMaxLength, xbt_assert(lg_sched_message <= schedMessageMaxLength,
"Buffer for sending messages to the scheduler is not big enough..."); "Buffer for sending messages to the scheduler is not big enough...");
XBT_INFO("Message to send to scheduler: %s", sched_message); XBT_INFO("Message to send to scheduler: %s", sched_message);
...@@ -479,7 +479,7 @@ int server(int argc, char *argv[]) ...@@ -479,7 +479,7 @@ int server(int argc, char *argv[])
"|%f:S:%s", MSG_get_clock(), job->id_str); "|%f:S:%s", MSG_get_clock(), job->id_str);
...@@ -513,9 +513,9 @@ int server(int argc, char *argv[]) ...@@ -513,9 +513,9 @@ int server(int argc, char *argv[])
s_job_t * job = jobFromJobID(jobID); s_job_t * job = jobFromJobID(jobID);
xbt_assert(job->state == JOB_STATE_SUBMITTED, "Invalid allocation from the scheduler: the job %d is either not submitted yet" xbt_assert(job->state == JOB_STATE_SUBMITTED, "Invalid allocation from the scheduler: the job %d is either not submitted yet"
" or already scheduled (state=%d)", jobID, job->state); " or already scheduled (state=%d)", jobID, job->state);
job->state = JOB_STATE_RUNNING; job->state = JOB_STATE_RUNNING;
nb_running_jobs++; nb_running_jobs++;
xbt_assert(nb_running_jobs <= nb_submitted_jobs); xbt_assert(nb_running_jobs <= nb_submitted_jobs);
nb_scheduled_jobs++; nb_scheduled_jobs++;
...@@ -621,7 +621,7 @@ int server(int argc, char *argv[]) ...@@ -621,7 +621,7 @@ int server(int argc, char *argv[])
task_free(&task_received); task_free(&task_received);
free(task_data); free(task_data);
if (sched_ready && (strcmp(sched_message, "") != 0)) if (sched_ready && (strcmp(sched_message, "") != 0))
char * sendBuf; char * sendBuf;
...@@ -629,10 +629,10 @@ int server(int argc, char *argv[]) ...@@ -629,10 +629,10 @@ int server(int argc, char *argv[])
int ret = asprintf(&sendBuf, "0:%f%s", MSG_get_clock(), sched_message); int ret = asprintf(&sendBuf, "0:%f%s", MSG_get_clock(), sched_message);
xbt_assert(ret != -1, "asprintf failed (not enough memory?)"); xbt_assert(ret != -1, "asprintf failed (not enough memory?)");
sched_message[0] = '\0'; // empties the string sched_message[0] = '\0'; // empties the string
lg_sched_message = 0; lg_sched_message = 0;
MSG_process_create("Sched REQ-REP", requestReplyScheduler, sendBuf, MSG_host_self()); MSG_process_create("Sched REQ-REP", requestReplyScheduler, sendBuf, MSG_host_self());
sched_ready = 0; sched_ready = 0;
...@@ -671,7 +671,7 @@ msg_error_t deploy_all(const char *platform_file, const char * masterHostName, c ...@@ -671,7 +671,7 @@ msg_error_t deploy_all(const char *platform_file, const char * masterHostName, c
xbt_assert(master_host != NULL,"Invalid SimGrid platform file '%s': cannot find any host named '%s'. " xbt_assert(master_host != NULL,"Invalid SimGrid platform file '%s': cannot find any host named '%s'. "
"This special host is the one on which the simulator and the job submitters run.", "This special host is the one on which the simulator and the job submitters run.",
platform_file, masterHostName); platform_file, masterHostName);
// Let's remove the master host from the hosts used to run jobs // Let's remove the master host from the hosts used to run jobs
msg_host_t host; msg_host_t host;
unsigned int i; unsigned int i;
...@@ -24,9 +24,9 @@ typedef enum ...@@ -24,9 +24,9 @@ typedef enum
typedef struct s_task_data typedef struct s_task_data
e_task_type_t type; //! Type of task e_task_type_t type; //! Type of task
int job_id; //! The job ID int job_id; //! The job ID
void *data; //! Either NULL or points to something else based on type void *data; //! Either NULL or points to something else based on type
} s_task_data_t; } s_task_data_t;
...@@ -34,7 +34,7 @@ typedef struct s_task_data ...@@ -34,7 +34,7 @@ typedef struct s_task_data
typedef struct s_lauch_data typedef struct s_lauch_data
int jobID; //! The job identification number int jobID; //! The job identification number
int reservedNodeCount; //! The number of reserved nodes int reservedNodeCount; //! The number of reserved nodes
int * reservedNodesIDs; //! The nodes on which the job will be run int * reservedNodesIDs; //! The nodes on which the job will be run
} s_launch_data_t; } s_launch_data_t;
This diff is collapsed.
...@@ -10,17 +10,17 @@ ...@@ -10,17 +10,17 @@
typedef struct typedef struct
FILE * f; //! The file stream FILE * f; //! The file stream
int bufferSize; //! The size of the buffer (octets) int bufferSize; //! The size of the buffer (octets)
char * buffer; //! The buffer char * buffer; //! The buffer
int bufferPos; //! The number of octets currently in the buffer int bufferPos; //! The number of octets currently in the buffer
} WriteBuffer; } WriteBuffer;
* @brief Creates a WriteBuffer * @brief Creates a WriteBuffer
* @param[in] filename The file name * @param[in] filename The file name
* @param[in] bufferSize The strictly positive buffer size * @param[in] bufferSize The strictly positive buffer size
* @return The newly created WriteBuffer * @return The newly created WriteBuffer
WriteBuffer * writeBuffer_create(const char * filename, int bufferSize); WriteBuffer * writeBuffer_create(const char * filename, int bufferSize);
...@@ -72,11 +72,11 @@ typedef enum ...@@ -72,11 +72,11 @@ typedef enum
PajeTracerState state; //! The current state of the PajeTracer PajeTracerState state; //! The current state of the PajeTracer
int logLaunchings; //! If set to TRUE, job launchings will appear in the Pajé file int logLaunchings; //! If set to TRUE, job launchings will appear in the Pajé file
WriteBuffer * buf; //! Handles the writings to the file WriteBuffer * buf; //! Handles the writings to the file
int colorCount; //! The number of different colors used for the jobs int colorCount; //! The number of different colors used for the jobs
char ** colors; //! The different colors used for the jobs (as C strings) char ** colors; //! The different colors used for the jobs (as C strings)
} PajeTracer; } PajeTracer;
/* Copyright (c) 2015. The OAR Team. /* Copyright (c) 2015. The OAR Team.
* All rights reserved. */ * All rights reserved. */
#pragma once #pragma once
#include <simgrid/msg.h> #include <simgrid/msg.h>
