GitLab
Support
Community forum
Keyboard shortcuts
O
orchestra
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
PERE Alexandre
orchestra
9f7b1d77
9f7b1d77
Alexandre Pere
Removes Warning
391d383a
10
10 changed files
19 additions
17 deletions
+19
-17
liborchestra/Cargo.toml
+2
liborchestra/src/lib/hosts/mod.rs
+1
-1
liborchestra/src/lib/mod.rs
+1
-1
liborchestra/src/lib/primitives.rs
+1
-2
liborchestra/src/lib/repository/mod.rs
+2
-1
liborchestra/src/lib/scheduler.rs
+0
-1
liborchestra/src/lib/ssh/config.rs
+1
-1
liborchestra/src/lib/ssh/mod.rs
+4
-4
liborchestra/src/lib/timer.rs
+6
-4
runaway-cli/src/subcommands/exec.rs
+1
-2
9f7b1d77
@@ -17,6 +17,7 @@ rust-crypto = "0.2"
uuid
version
"0.6"
features
"serde"
"v4"
rpassword
"0.0.4"
ssh2
"0.3.3"
shells
"0.2.0"
dirs
"1.0"
url
"1.7.2"
git2
version
"0.8"
@@ -27,6 +28,7 @@ walkdir = "2.2.7"
libc
"0.2"
globset
"0.4.4"
tracing
"0.1.10"
tracing-subscriber
"0.1.6"
tracing-attributes
"0.1.5"
tracing-futures
version
"0.1.0"
features
["futures-preview"]
derivative
"1.0.3"
9f7b1d77
@@ -759,7 +759,7 @@ async fn allocate_nodes(frontend: &Frontend,
// If the allocation failed we return an error
misc
compact_outputs
outputs
.result
.map_err
e
Error
AllocationFailed
format!
"Failed to allocate on command
.map_err
e
Error
AllocationFailed
format!
e
// We return the Allocation context
Ok
FrontendContext
context
9f7b1d77
#![feature(
trace_macros,
async_await,
result_map_or_else,
trait_alias,
try_blocks)]
#![feature(result_map_or_else,
trait_alias,
try_blocks)]
//! liborchestra/mod.rs
//! Liborchestra:
9f7b1d77
@@ -15,8 +15,7 @@ use crate::ssh::RemoteHandle;
use
globset
use
std
io
Read
use
std
fmt
use
tracing
self
error
trace
warn
instrument
trace_span
use
tracing_futures
Instrument
use
tracing
self
instrument
9f7b1d77
@@ -898,7 +898,8 @@ impl CampaignHandle {
_
dropper
Dropper
from_closure
Box
new
move
drop_sender
.close_channel
handle
.join
handle
.join
.unwrap_or_else
_
error!
"Failed to wait"
format!
"CampaignHandle"
9f7b1d77
@@ -29,7 +29,6 @@ use futures::channel::mpsc::{UnboundedSender};
use
std
fmt
Display
Debug
use
std
process
Command
use
crate
use
serde
Deserialize
Serialize
use
serde_json
use
std
os
unix
process
ExitStatusExt
use
tracing
self
error
trace
instrument
trace_span
9f7b1d77
@@ -671,7 +671,7 @@ impl<'s> Parser<'s> {
Some
Ok
Token
TokenType
Word
ib
if
ib
.as_str
"ProxyCommand"
self
.consume_proxycommand_clause
Some
Ok
Token
TokenType
NewLine
ib
Some
Ok
Token
TokenType
NewLine
_
ib
None
Some
Ok
Token
TokenType
Word
ib
9f7b1d77
@@ -348,7 +348,7 @@ impl ProxyCommandForwarder {
while
kf1
.load
Ordering
Relaxed
match
std
io
copy
mut
command_stdout
mut
socket1
Err
e
error!
"stdout forwarding failed
error!
e
break
Ok
@@ -373,7 +373,7 @@ impl ProxyCommandForwarder {
while
kf2
.load
Ordering
Relaxed
match
std
io
copy
mut
socket2
mut
command_stdin
Err
e
error!
"stdin forwarding failed
error!
e
break
Ok
@@ -600,7 +600,7 @@ impl std::fmt::Debug for OperationInput{
fn
fmt
self
f
mut
std
fmt
Formatter
'_
std
fmt
Result
match
self
OperationInput
Exec
c
write!
f
"Exec({:?})"
c
OperationInput
Pty
t
c
out
err
write!
f
"Pty({:?}, {}, {})"
c
stringify!
out
stringify!
err
OperationInput
Pty
_
c
_
out
_
err
write!
f
"Pty({:?}, {}, {})"
c
stringify!
_
out
stringify!
_
err
OperationInput
ScpSend
a
b
write!
f
"ScpSend({:?}, {:?})"
a
b
OperationInput
ScpFetch
a
b
write!
f
"ScpFetch({:?}, {:?})"
a
b
@@ -1394,7 +1394,7 @@ mod test {
init
let
proxy_command
address
from_command
"echo kikou"
.unwrap
let
mut
stream
TcpStream
connect
address
.unwrap
std
thread
sleep
_ms
1000
std
thread
sleep
1000
assert
TcpStream
connect
address
.is_err
let
mut
buf
as
u8
6
stream
.read_exact
mut
buf
.unwrap
9f7b1d77
@@ -15,7 +15,6 @@ use std::thread;
use
futures
channel
mpsc
UnboundedSender
use
std
fmt
Debug
use
std
process
Command
use
crate
use
tracing
self
warn
trace
instrument
trace_span
use
tracing_futures
Instrument
@@ -160,6 +159,7 @@ impl<T> Slot<T>{
/// Gives a handle to the inner.
#[inline]
#[allow(dead_code)]
pub
fn
as_arrayvec
self
ArrayVec
Timed
T
SLOT_LEN
self
.waiters
@@ -178,12 +178,14 @@ impl<T> Slot<T>{
/// Returns the duration of the slot.
#[inline]
#[allow(dead_code)]
pub
fn
duration
self
Duration
self
.end
self
.beginning
/// Returns the number of timed inside.
#[inline]
#[allow(dead_code)]
pub
fn
len
self
usize
self
.waiters
.len
@@ -337,10 +339,10 @@ impl<T> Timer<T>{
if
do_turn
let
slot
let
mut
current_wheel
mut
self
.0
w
let
current_wheel
mut
self
.0
w
current_wheel
.turn
let
mut
previous_wheel
mut
self
.0
w
let
previous_wheel
mut
self
.0
w
let
res
Result
Vec
usize
Timed
T
slot
.to_vec
.into_iter
.map
t
previous_wheel
.try_insert
t
@@ -363,6 +365,7 @@ impl<T> Timer<T>{
/// Returns the number of timed in the timer.
#[allow(dead_code)]
pub
fn
len
self
usize
self
.0
.iter
.fold
a
w
a
w
.len
@@ -473,7 +476,6 @@ impl TimerHandle{
match
receiver
.await
Err
e
Err
Error
OperationFetch
format!
e
Ok
OperationOutput
Sleep
Ok
Ok
e
Err
Error
OperationFetch
format!
"Expected RequestParameters, found {:?}"
e
.instrument
trace_span!
"SchedulerHandle::async_request_parameters"
9f7b1d77
@@ -18,8 +18,7 @@ use clap;
use
uuid
use
futures
executor
block_on
use
crate
to_exit
use
liborchestra
commons
EnvironmentValue
EnvironmentStore
substitute_environment
OutputBuf
push_env
use
liborchestra
commons
EnvironmentStore
OutputBuf
push_env
use
crate
misc
use
crate
exit
Exit
use
liborchestra
primitives
