Commit 8599eb24 authored by Ludovic Courtès's avatar Ludovic Courtès
tests: Factorize 'spherical_to_cartesian'.
parent 681d8c1d
...@@ -90,17 +90,7 @@ struct PropCartToRusin: Property<Angle, Angle> ...@@ -90,17 +90,7 @@ struct PropCartToRusin: Property<Angle, Angle>
bool check(const Angle& theta, const Angle& phi) const bool check(const Angle& theta, const Angle& phi) const
vec v(3); auto v = spherical_to_cartesian(theta, phi);
v[0] = cos(phi) * sin(theta);
v[1] = sin(phi) * sin(theta);
v[2] = cos(theta);
// cart[3] = clamp(cos(phi) * sin(theta), 0., 1.);
// cart[4] = clamp(sin(phi) * sin(theta), 0., 1.);
// cart[5] = clamp(cos(theta), 0., 1.);
// Make sure V is on the hemisphere.
v.normalize();
vec cart(6); vec cart(6);
cart[0] = v[0], cart[1] = v[1], cart[2] = v[2]; cart[0] = v[0], cart[1] = v[1], cart[2] = v[2];
cart[3] = v[0], cart[4] = v[1], cart[5] = v[2]; cart[3] = v[0], cart[4] = v[1], cart[5] = v[2];
...@@ -50,6 +50,22 @@ namespace alta { namespace tests ...@@ -50,6 +50,22 @@ namespace alta { namespace tests
return degrees * d2r; return degrees * d2r;
template<typename T>
static Eigen::Matrix<T, 3, 1> spherical_to_cartesian(T theta, T phi)
Eigen::Matrix<T, 3, 1> v(cos(phi) * sin(theta),
cos(theta));
v.normalize();
return v;
template<typename T> template<typename T>
class angle_range class angle_range
