Commit 4aeacd4b authored by Laurent Belcour's avatar Laurent Belcour
[CMake] Working 'data-io' test (passing env var with cmake)
parent 0d437a08
...@@ -90,3 +90,4 @@ target_compile_features(test_data_io PRIVATE cxx_range_for) ...@@ -90,3 +90,4 @@ target_compile_features(test_data_io PRIVATE cxx_range_for)
enable_testing() enable_testing()
add_test(data_io test_data_io) add_test(data_io test_data_io)
set_tests_properties(data_io PROPERTIES ENVIRONMENT "TEST_DATA_DIRECTORY=${CMAKE_SOURCE_DIR}/sources/tests")
